Rear wheel cylinder clip question for 87 - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-22-2008, 05:56 AM
jmchevy's Avatar
jmchevy jmchevy is offline
Year: 1987
Region: 4 (MD,VA)
NECOA #: 7649
jmchevy will become famous soon enough
Garage
Default Rear wheel cylinder clip question for 87
Just spent over an hour getting the round spring retaining clip on a new rear wheel cylinder on my 87. The wheel cylinder is tight against the backing plate but it is loose and I can twist it. Is this ok? A guy I work with said as long as the clip is holding it flush to the plate its ok. I see that the ears at the top of it cant let it turn but so much. Maybe a dumb question but I had to ask
Old 01-22-2008, 05:05 PM
L K meano biker L K meano biker is offline
NECOA #: 9215
L K meano biker will become famous soon enough
perfectly normal, I thought the same thing myself, horrible design on GM's part, so much a PITA next time a wheel cylinder needs replacing I will take it to a brake shop.
I can't remember and I did a search on here, maybe was another GM forum but I belive you can change out the backing plate from an earlier style and use the wheel cylinder that is held in place by a nut- much easier/quicker to change them out!!
Funniest post ever- QUOTE "ok heres the ting take a corner at 35 or 45racing a honda had a blow out sled into the crub hit 2 fents 2 burshes 4 brick and a trash can but anywho now I have a load cam knock it sounds like"
Old 01-22-2008, 07:41 PM
jmchevy's Avatar
Year: 1987
Region: 4 (MD,VA)
NECOA #: 7649
Garage
I think Ill do that next time too..I did get a tip today from a guy at our local NAPA store, he said that some new wheel cylinders are machined so that one clip ear isnt as deeply notched as the other, and makes getting the clip on alot easier. Anyway, like you said they are a PITA to change
Old 01-27-2008, 07:06 AM
MEvang's Avatar
MEvang MEvang is offline
Year: 1969
Region: 8 (OH,WV)
NECOA #: 7317
MEvang will become famous soon enough
Here's a good tip for getting those clips in. First wedge a large chisel or block of wood between the wheel cylinder and axle flange. The will hold the WC tight against the backing plate.
Next get a 1 1/8" thin wall socket. Craftsman 12 point chrome 3/4 drive works the best. This socket will fit right in the back over the clips as long as the rust build up is not too bad. Tap the socket with a hammer until the clips completely seats.
Now if the clip is on there and doesn't seem to be completely seated on one side, simply place a screwdriver against the non-seated side and tap with a hammer to seat.
Remember the real trick here is to have that WC wedged tight against the backing plate. Makes all the diference.
Mike
"That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced." (Scientific American January 2, 1909).
Old 01-27-2008, 09:04 AM
hel98's Avatar
hel98 hel98 is offline
Year: 1982
Model: Conquista
Region: 4 (MD,VA)
NECOA #: 10617
hel98 will become famous soon enough
A large 'c' clamp along with the thin wall socket works good too. Rick
Old 05-02-2013, 07:59 PM
joab joab is offline
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23735
joab will become famous soon enough
5 year old thread , but it came in handy
Just had to change out my wheel cylinder today.
Used the socket and C clamp method, took about 15 minutes total time.
Old 05-02-2013, 08:18 PM
woody31 woody31 is offline
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
Default retaining clip
try this,,its a clip that goes over the wheel cylinder,,you drill 2 lil holes in the backing plate and use the supplied 2 self tapping screws,,the brand is ,,united,,,the part # is 25851,,try napa or a good quality parts store,,find the oldest guy behind the counter,,,the 18 yr old with bad acne cant help you on this one,,,
most places can order one in a few days,,keep this in mind for next time,,cheers...
  #8
Old 05-03-2013, 01:54 PM
Lindsay's Avatar
Lindsay Lindsay is offline
Year: 1982
Model: Conquista
Region: 14(AR,LA,MS)
NECOA #: 14482
Lindsay has a spectacular aura about
I followed the socket and C-clamp method, but used a piece of PVC to press on the clip because I did not have a thin wall socket.
'82 Conquista 350/TH350
'91 Syclone
  #9
Old 05-03-2013, 03:49 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
Just use the proper tool...
Amazon Amazon
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modifications to transmission, #3 son is a trans tech...
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu wagon with 9C1 drivetrain...parts?...or drive?
"Too many parts cars to mention....."
  #10
Old 05-03-2013, 03:51 PM
rnhart3's Avatar
Year: 1979
NECOA #: 17856
Garage
And use the retaining bracket...
Amazon Amazon
  #11
Old 05-03-2013, 05:14 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster has a spectacular aura about
Garage
Back clamp : Raybestos GMB25851 Professional Grade Drum Brake Wheel Cylinder Bracket
  #12
Old 05-04-2013, 09:09 AM
rnhart3's Avatar
Year: 1979
NECOA #: 17856
Garage
Here's the bracket...
Amazon Amazon
  #13
Old 05-04-2013, 10:35 AM
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23735
I had to use a socket because my backing plate was not true and the clip would not quite seat. I had to wedge large chisel between the wheel cylinder and the axle flange and then use a very large C clamp to not only seat the clip, but too also flatten out the plate
I originally used a piece of a drain pipe from a sink cut down to size. It fit perfectly but the walls were not strong enough to take the strain of flattening out the plate
Hopefully there won't be a next time. I'm hoping to go disc before that happens
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Rear end/ wheel question drews0311 Wheels & Tires 4 01-24-2008 07:28 PM
Bleeder wrench for rear drums (cylinder) swimman Brake Systems 7 07-09-2006 04:08 PM
Master cylinder question tampaelcamino Brake Systems 8 05-05-2005 08:54 AM
Replaced rear cylinder, but can't bleed it RanCid Brake Systems 11 03-22-2005 07:24 AM
Rear Disc Master Cylinder for 83? CmdrRiker Transmission & Drive line 3 09-01-2004 04:13 AM
