Remove DashBoard - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-19-2008, 08:00 PM
BennyVilla BennyVilla is offline
Junior Member
Member
NECOA #: 11324
BennyVilla will become famous soon enough
Default Remove DashBoard
Anyone know what screws i need to remove to ge tthe dash out ? I dont want to bend or break what I already have, I bought the dash cover which glues right on but I would rather take it out and glue it then to leave it in the car and glue it. any ideas ? has anyone installed a dash cover without taking the dash out ? and if so what should I be looking out for when doing this ? Should I just leave it in and add the cover ?
Benny Villa
Old 03-19-2008, 08:03 PM
Junior Member
Member
NECOA #: 11324
Default by the way
by the way I have a 1981 sorry forgot to mention.
Old 03-19-2008, 08:55 PM
hemi57's Avatar
hemi57 hemi57 is offline
Venerated Member
Year: 1975
Model: El Camino Classic
Region: 25 (ALL OTHER)
NECOA #: 9074
hemi57 has a spectacular aura about
Benny, firstly let me say that I have a '75 and I have never fitted a dash cap, I have however stripped my El Camino back to the firewall by removing the whole dash.
On mine there is no specific way to explain how to approach the removal other than to state how to do it in concept.
Remove the instrument cluster assembly
Remove all/any airconditioning ducts
Remove the plastic interior moldings which go around the front of the door openings
Remove all screws, nuts or bolts that retain the dash to the body (on the 4 gen there are two bolts from the steering column mount into the back of the dash which are pigs to get to and very difficult to remove)
Drop the steering column to give yourself clearance
Make sure all wiring clamps, attachments, brackets are freed from the dash
Lift out
Hang in there and I am sure another member who is familiar with the 5th gen will chime in with what to watch out for specific to those
John (from Down Under)
'75 El Camino Classic ("EARLE")
'75 Harley Davidson Electraglide
'82 Holden Ute
'06 Chrysler 300C SRT8
Old 03-19-2008, 09:10 PM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
Here is a post from last year on the subject for 5th gens.
Here
This should help.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 9 and really haven't had to work on it this year.
Link to Garage:
Old 03-19-2008, 09:20 PM
Junior Member
Member
NECOA #: 11324
Default Thanks for the help guys !
hey thanks guys, i started removing everything and once i removed the speedo cable and removed the cluster it seemed easier to just fit the cover at this point, I took the cover and it fits perfect, just need to clean, glue and i'm done. I think it is easier to just remove all the inner components and Sc ducts as well as the cluster to do this. Removing the whole dash I think would be too much work and not really neccesary.
Thanks guys. I have more to do tomorrow.
Hey also i have not been able to find the exterior trim for my 81 el camino. (all the metal parts that go around the windows and well the whole car really)
Any ideas of where to look ? Also I have no tow yards around here to go fishing for it.
Old 03-19-2008, 11:35 PM
elcamino74guy's Avatar
elcamino74guy elcamino74guy is offline
Year: 1974
Region: 15(AZ,NM)
NECOA #: 2321
elcamino74guy will become famous soon enough
When I have to pull my dash pad on my 4th gen I have to pull out about a dozen screws.
4 in the back of the defroster vents by the window
about 6 in the top of the glove box
2 in the top of the ashtray area
4 in the top of the instrument panel bezel
2 on either side of the pad's "ears" that face the door.
The ones near the glove box can be a pain since a couple of them are kind of hard to get to and you have to feel for them behind the dash.
74 El Camino Classic - project car #1
95 Pontiac Firebird Formula - Project car #2
96 Camaro - RIP, Traded 10-16-2007
2008 Mustang GT - RIP, Sold 10-12-2013 (Was the Elky or the 'Stang, Whaddya think I'd choose!)
Old 06-06-2012, 10:12 AM
Junk Collector Junk Collector is offline
Year: 1980
Region: 5 (NC,SC)
NECOA #: 21689
Junk Collector will become famous soon enough
Garage
Quote:
Yes - I know this is an OLD post - but - do you recall anything you wish you knew when you did it?
I am about to do the pad on my 1980
  #8
Old 06-06-2012, 11:37 AM
jpmdaddy's Avatar
jpmdaddy jpmdaddy is offline
Site Contributor
Year: 1966
Region: 13(TX)
NECOA #: 20314
jpmdaddy is of outstanding character
bennyvilla hasn't logged in since 2008. I've read in other posts that you should fill any deep cracks in your dash with silicone, try to get it as smooth as possible. Your cover will fit better and not collapse into deep cracks over time.
this is hearsay, however, as my dash pad just sits on top of metal dash on 66
  #9
Old 06-06-2012, 01:21 PM
Year: 1980
Region: 5 (NC,SC)
NECOA #: 21689
Garage
wonder what I need to do over the speaker area - that is some of the bigger damage on mine.
  #10
Old 02-09-2013, 05:58 AM
bugsyc's Avatar
bugsyc bugsyc is offline
Year: 1985
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 23383
bugsyc will become famous soon enough
Quote:
Here
This should help.
When you click on HERE,it's not there....I'm putting on a DixieMonte 100% dash cover...If anyone has directions or tips,please post them...Tips and tricks...Dash adventures wasn't much help...For those of you who have bought the same dash cover,Do complete instructions come with it???Do I remove air vents first and then put them in new one???Do the side speaker grills need to be removed and installed on new one???Anything else I need to know????Thanks for any help....85 Elky...
  #11
Old 02-27-2013, 03:59 AM
Skylarkul's Avatar
Skylarkul Skylarkul is offline
Director, Region 13
Year: 1983
Region: 13(TX)
NECOA #: 22327
Skylarkul has a reputation beyond reputeSkylarkul has a reputation beyond repute
Garage
Look here:
http://www.elcaminocentral.com/showt...=removing+dash
I haven't done it yet but, this sounds like good info. I'll let you know next week.
Les
1983 El Camino (Daily Driver)
1986 GMC Caballero Project (Finished and up for sale at Gateway Classics)
1965 El Camino (LS2 Project)
2004 Corvette Commemorative Convertible
2014 Chevy Cruze
  #12
Old 01-23-2015, 10:42 AM
Irish Irish is offline
Junior Member
NooB
Name: Shaun skeffington
Year: 1985
Model: Conquista
Region: 9 (IN,KY,MI)
NECOA #: 51729
Irish will become famous soon enough
Hi, Can you tell me.What is a Dixie monte dash cover is?And who handles them.
Thank You.
  #13
Old 01-23-2015, 11:41 AM
MikeTheDraftsman's Avatar
MikeTheDraftsman MikeTheDraftsman is offline
Year: 1984
Model: Conquista
Region: 6 (FL)
NECOA #: 2801
MikeTheDraftsman will become famous soon enough
Garage
Quote:
Thank You.
Its the Dixie Monte Carlo Company.
http://dixiemontecarlo.com/Product/Search.aspx
Folks ask me why I like El Camino's.
I tell them that if they have to ask they wont understand!
  #14
Old 01-26-2015, 10:44 AM
Chris Nelson Chris Nelson is offline
Year: 1986
Model: El Camino SS
Region: 6 (FL)
NECOA #: 16658
Chris Nelson will become famous soon enough
I just got a new one from Dixie Monte Carlo Depot , it was made by Accu-form plastics .
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
dashboard vwfreak Performance Modifications 10 02-27-2011 04:06 AM
dashboard swap exoauto Interior Restoration 0 09-14-2008 09:59 PM
Dashboard lights? '78-banjamin Interior Restoration 7 08-07-2005 03:50 PM
dashboard value pagsjohn General BS Topics 0 03-15-2005 09:57 PM
Dashboard??? :( 79Suzy Interior Restoration 14 11-13-2004 12:13 PM
