LS1 Engine installation in 87 El Camino Conquisa -- HELP - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > LT1/LS1/EFI Tech
Old 05-24-2008, 04:18 PM
BuckeyeDave's Avatar
BuckeyeDave BuckeyeDave is offline
Junior Member
Gear Head
Year: 1987
Model: Conquista
Region: 7 (AL,GA,TN)
NECOA #: 11030
BuckeyeDave will become famous soon enough
Default LS1 Engine installation in 87 El Camino Conquisa -- HELP
Will a Chevy LS1 engine fit in a 1987 El Camino Conquista without making modifications? Would appreciate hearing from anyone who has experience in this area.
Old 05-25-2008, 10:04 PM
greywolf's Avatar
greywolf greywolf is offline
Year: 1984
Region: 12(MO,OK,KS)
NECOA #: 64
greywolf has a spectacular aura about
Garage
You'll need to notch the front cross member to clear the oil pan. That's been done before, check other LS1 threads in this forum for info.
Also you'll need high pressure fuel pump and return line from the pressure regulator.
And you need to figure out how to supply power to the computer, and where to mount it. Computers are sensitive to voltage, so I used the ignition switch to control a relay to feed the computer instead of feeding it straight from the ignition switch.
I don't recall seeing anything in this forum about a radiator fan, but you'll need an electric one since the LS1 doesn't have a fan belt.
That's the main stuff, then there are a bunch of smaller bits. Browse the forum for info. Also try Ls1.com web site.
Old 05-27-2008, 04:29 PM
1BadElky's Avatar
1BadElky 1BadElky is offline
Year: 1986
Model: Conquista
NECOA #: 6381
1BadElky will become famous soon enough
it may be possible to swap wiothout cutting the xmember. there are some production pans out there that may work. I know for a fact the alpha 5.3 Hummer pan works on s10's.
try ls1tech.com and hit up "g-body". I'm over there too.
edit: just to avoid confusion g-body is not me, I use this name.
Currently undergoing resto.
Mods:
-355/200-4R/3.42 posi 8.5"
-ZQ8 wheels
-Blazer brakes
-12.7:1 steering
-Lowered 2"
-HIDs
Old 05-28-2008, 01:24 PM
Andreas Andreas is offline
Motor Mouth
Year: 1986
Region: 24(EUROPE)
NECOA #: 8487
Andreas will become famous soon enough
caddy cts-v pan ....try lstech.com
Old 07-20-2008, 07:55 PM
juced211s juced211s is offline
Junior Member
Twisted Wrench
Year: 1986
Region: 3 (DE,NJ,PA)
NECOA #: 12147
juced211s will become famous soon enough
I believe that some of the LS setups used a self regulated pump so there was no need for a return line. Not sure if they are interchangable though. I have also read of nightmares with getting the factory accessories to clear the frame, I guess it depends what vehicle the engine is coming out of. Definitely would be a cool swap though.
Jon
Old 11-09-2008, 04:07 PM
EL S ONE's Avatar
EL S ONE EL S ONE is offline
Year: 1987
Model: El Camino SS
Region: 18(CA)
NECOA #: 10110
EL S ONE is just really nice
Default LS1 into Elcmanio
Go to John Bzdel's site. http://home.earthlink.net/~bzdel/ I bought his motor mounts and oilpan mod. He proved his work by drag racing his engine change.I did notch the cross member so i could run the air con pump in its stock acessory drive location.I went with a Corvette fuel filter/pressure regulator so a short return is required.
Original owner. "04" LS1.Built 4L60E. GN 8.5 3.73's.Detroit Tru-Track. Dual 2.5 Tubes,"H"pipe & Flowmaster 50's.Full SC&C suspension.C-5 brakes. Electric antenna. Zinc plated Spurving bearings.Maggy. C.A.R.B approved
Old 12-31-2008, 02:59 AM
85ELCO83's Avatar
85ELCO83 85ELCO83 is offline
Junior Member
Member
Year: 1985
Model: El Camino SS
Region: 18(N.CA,N.NV)
NECOA #: 13301
85ELCO83 will become famous soon enough
oil pan motor mounts and cross member i have 85 elco and its done with 13" vette disc brakes
  #8
Old 12-31-2008, 10:03 AM
1BadElky's Avatar
Year: 1986
Model: Conquista
NECOA #: 6381
pics of 13" discs?
  #9
Old 09-30-2012, 02:32 PM
Elke87Vette62 Elke87Vette62 is offline
Junior Member
Twisted Wrench
Year: 1987
Model: Conquista
Region: 8 (OH,WV)
NECOA #: 20697
Elke87Vette62 will become famous soon enough
Garage
cutting the crossmember is not the way to go.. We are just finishing installing a 2000 corvette into my 87 Elky. We used an oil pan off a cts v caddy and it has worked fine.
The motor mounts came from holly. The computer was mounted on the fender-well on the passenger side.
We used the wiring harness that came with the motor out of Bristol pa. Also the gas pedal.
Did have to change the gas tank and fuel pump. I hope to post pictures soon..
I purchased a new aluminum radiator to get the fresh look.
Trans was from a 2005 Colorado, had to change the bell housing and input shaft
  #10
Old 11-09-2012, 06:12 PM
Reddiedad Reddiedad is offline
Junior Member
Member
Year: 1983
Model: Conquista
Region: 13(TX)
NECOA #: 16134
Reddiedad will become famous soon enough
My son and I put an LS1 out of a 2000 Z28 in an 1983 Conquista it is a tight fit. the Caddy oil pan is the way to go. We mounted the computer to the passanger side fender well. I wish we had spen more time and put the computer in the cab where the original one was. we also used the manual six speed and it get around 22 mpg.
  #11
Old 11-14-2012, 10:03 AM
vwporschegt3's Avatar
vwporschegt3 vwporschegt3 is offline
Motor Mouth
Year: 1987
Model: Conquista
Region: 17(NV)
NECOA #: 12876
vwporschegt3 will become famous soon enough
Horsepower on the powerblock did a LS1 install on a 88 Monte Carlo SS , i would check that out first to see what they did
The Fastback is Put away till the Kids are gone, the Jeep has died.. , The Bug is still in service, and I am trying desperately to keep the El Camino use to a minimum so I can fix some things... so far.... the plan ain't workin..
  #12
Old 03-09-2013, 08:51 AM
Junior Member
Twisted Wrench
Year: 1987
Model: Conquista
Region: 8 (OH,WV)
NECOA #: 20697
Garage
I finally got some pictures posted on the 2000 LS1 Corvette installed into my 87 Elky. I did not cut anything. CTS-V oil pan did the trick. I changed the AC unit so it would make it easier to hook up and service. The shop that did the work suggested this and I'm glad that we did it that way because of thr final product. Check it out in my garage........Good luck with your swap! Do check out John's threads though because he is the one that inspired me. In fact I gave the garage all my coraspondence with John from a few years back when I first started planning my change over. I'm glad that I bit the bullet... The car is a fantasic driver. My next project is a Corvette LS7 into a 62 vette. Looking at new frames now.
  #13
Old 05-15-2013, 10:05 AM
jca1972's Avatar
jca1972 jca1972 is offline
Junior Member
NooB
Year: 1970
Model: El Camino SS
Region: 13(TX)
NECOA #: 24100
jca1972 will become famous soon enough
Garage
I just Installed a 5.3 in my 70 Camino, there is a lot of great info on www.lt1swap.com
  #14
Old 09-02-2013, 10:54 AM
smnit92 smnit92 is offline
Junior Member
Member
Year: 1981
Region: 19(AK,ID,OR,WA)
NECOA #: 24089
smnit92 will become famous soon enough
I know this thread is old, but there is a sticky on ls1tech in the conversions/hybrids section that lists the dimensions of all the ls oil pans. I notched my crossmember because I already had the f-body pan. 98-02 f-body longtubes will fit but some modification is required to one tube on the passenger side, either dent it or cut a section about a foot long out and weld a new piece in. You can run a belt driven fan if you use a truck water pump, but I'm not sure how centered it will be on the radiator. I used a single puller fan off of a ford taurus the cfm on those fans is better than most dual aftermarket setups. Also checkout speedway motors for wiring harness, they have a reasonably priced harness that is simple plug and play and works great I've used them on two different ls swaps. Stock 98-02 fbody radiator will work, I'm using a griffen. I mounted the ecu inside the cabin with the speedway harness and had plenty of wire for it to reach.
  #15
Old 11-30-2013, 05:47 PM
Motor Mouth
Year: 1986
Region: 24(EUROPE)
NECOA #: 8487
Here are some pics of my CTS-V pan
No notching anywhere.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
1972 El Camino-LS1 Installation obster1 LT1/LS1/EFI Tech 1 10-13-2006 06:49 PM
'81 El Camino Speaker Installation Addickt Audio 3 09-27-2005 11:05 PM
Stereo Installation ElCaminoSS85 Audio 0 01-18-2005 11:08 AM
67 el camino header installation x75 Engine Topics 1 11-24-2004 10:15 PM
Center Cap Installation? tplyons Body Restoration 1 11-14-2004 05:02 AM
