interior resto-mod - El Camino Central Forum : Chevrolet El Camino Forums
Old 08-08-2008, 08:32 AM
vandal's Avatar
vandal vandal is offline
Member
Twisted Wrench
Year: 1982
Region: 19(AK,ID,OR,WA)
NECOA #: 11981
vandal will become famous soon enough
Default interior resto-mod
started my interior resto last nite, installed new carpet from trim parts inc. went well fit good with just normal trimming and tugging. was worth the extra money, used no name on buick whoo what a pain!! started dyeing interior with sem vynil in can works well if prepped right, although i had some uv damage but a pocket knife took care of that ! [scraped off dry stuff then lightly sanded with400 grit, then wiped with acetone then sprayed them] turned out alright... anywhoo my qwestion is other than purchasing a headliner [previos owner tore out whole interior other than seats] does anyone know a slick way to build one ? all of the "donors" at local yards are gone or dust.... dont really wanna go the fiberglass routine, has anyone tried foam or foam board? figured you could carve em... will post pics tonite or tommorow have some good [well i think so lol] ideas.... V
1964 buick skylark, my first car [finished] sorta
1982 el camino [in progress]
1991 nissan p/u [daily driver]
Old 08-08-2008, 02:41 PM
PaPa Johns 77 PaPa Johns 77 is offline
Year: 1977
Model: El Camino Classic
Region: 10(IL,MN,WI)
NECOA #: 6188
PaPa Johns 77 is a glorious beacon of light
If you can find a good headliner board. They make a recover kit for it!
Old 08-09-2008, 10:57 PM
Low75's Avatar
Low75 Low75 is offline
Year: 1975
Region: 18(N.CA,N.NV)
NECOA #: 4203
Low75 will become famous soon enough
There's all kinds of options. You could use 1/8" HDF or masonite, or that cardboard stuff used for door panels. I've also heard of people using ABS plastic. I believe RodDoors uses ABS for their door panels and headliners. Then like PaPa John said, throw a recover kit on it or you could wrap it yourself in your choice of material. The foam idea sounds interesting too though...
1975 El Camino
Old 08-10-2008, 09:08 AM
theelcaminofactory theelcaminofactory is offline
Year: 1984
Model: Conquista
NECOA #: 572
theelcaminofactory is of outstanding character
Use the old board (if good) and recover it. I'm not a 4th owner...but I imagine the 4th gen board is styrofoam and it was pressed into shape, similarly to that of a 5th gen. Using a flat board (no matter what it's made of) just doesn't work as good, because it doesn't have those curves pressed into it. If an aftermarket ABS board is made for 4th gen Elkys, and you plan on keeping your Elky for all eternity, then spend the extra money and go with the ABS board...you may still have to recover it...but the ABS board itself will still last much longer than a styrofoam board...they crack. You'd be surprised how easy it is to recover a board whether it be the OEM (usable) board or an ABS plastic board.
Old 08-10-2008, 10:15 AM
Year: 1977
NECOA #: 6188
Quote:
Sorry Mike! We have a "real" headliner!
Old 08-10-2008, 10:56 AM
Year: 1984
Model: Conquista
NECOA #: 572
8O Oh...that suxs...see I learned something new today. I can replace my headliner in about 2 hrs now, plus the time it takes for the 3M glue to dry...see I knew there was some logical reason why I liked 5th gens better.
Old 08-10-2008, 11:14 AM
vandal's Avatar
Member
Twisted Wrench
Year: 1982
NECOA #: 11981
ok heres some pics of interior so far http://elcaminocentral.com/gallery-a...als-page2.html
some of the ideas for the speaker box were modified from drawing from another thread, thx !!
covered a donor back trim piece with carpet [if you dont have apolstery stapler get one they are handy !!]
bent some brackets to mount a piece of brushed aluminum for future amp mounting [if you plan right and leave wire access holes all wires can be hidden..] then with a little care glued carpet [3m super trim adhesive] on the bottom expozed metal.
carved a piece of foam to fill remainder then covered with carpet
i did have to remove a bracket that i assume was for jack...
ended up boxing 6x9 speakers after making front panel [it has a flange on 2 sides for mounting] i found some door clips left over from the buick ,they snapped right in the slots for the velcro mounts !! [u could also use fuzzy tree clips just as easily]
if anyones interested ill take more detailed pics...
havent got to the headliner yet but its next !! thinkin overhead console any opinons? V
ps now gotta build box for 2 10" subs...
You may not post new threads
You may not post replies
Interior floorpan resto: hawaii1984 Interior Restoration 2 07-07-2008 11:27 AM
83 Total resto 83Machine Body Restoration 8 01-27-2008 07:33 PM
Resto Rides Elky-holic General BS Topics 1 03-06-2007 06:33 AM
3rd Gen Resto update Billybob Body Restoration 16 05-12-2006 06:47 AM
60 Body off resto drvax Body Restoration 9 01-02-2004 01:12 PM
