noisy speedo - El Camino Central Forum : Chevrolet El Camino Forums
Old 02-02-2004, 11:28 AM
robucko robucko is offline
Junior Member
NooB
NECOA #: 1794
robucko will become famous soon enough
Default noisy speedo
1986 Caballero V/6. I seem to have a "spinning" sound coming from the speedo, it doesn't happen all the time and the needle is slow to return to zero. One mechanic told me I need either a new head or a new sending cable. The speedo is accurate and always registers. Ideas???
Thanks!
Proud owner of a 1986 Caballero in the process of being "reborn!"
Old 02-02-2004, 04:31 PM
Tommy's Avatar
Tommy Tommy is offline
Year: 1978
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 14
Tommy will become famous soon enough
Garage
Sounds like maybe the cable needs some lubrication. You can pull the inner cable out of its sleeve & put some moly lube on it .Then reinsert cable.
78 Camino SS, new built 357,built 700r4,3.23 posi
93 S10 4x4, 4.3, 5 speed
83 280zx turbo, 5 speed
99 Maxima SE-L, 5 speed
MSGT 145 AW
NECOA #14
Old 02-27-2004, 12:53 AM
81 CAB 81 CAB is offline
Junior Member
Twisted Wrench
NECOA #: 1913
81 CAB will become famous soon enough
Default noise
Had the same sound on my 81 cab took the cable off sprayed some grease and it stopped the noise
You may not post new threads
You may not post replies
need to repair noisy speedometer- cables are lubed! sandman Interior Restoration 4 08-18-2008 07:12 PM
NOISY COOLING FAN Ruti Heating & Air Conditioning Systems 9 12-01-2003 02:28 PM
noisy starter when starting motor resq302 Engine Topics 5 10-22-2003 01:18 PM
noisy air cond. compressor, what is it? TRIK-56 Heating & Air Conditioning Systems 3 10-16-2003 03:35 PM
Noisy AC compressor spoonplugger Heating & Air Conditioning Systems 3 08-16-2003 09:52 PM
