Cowl Tag Decoding - El Camino Central Forum : Chevrolet El Camino Forums
Old 04-17-2009, 12:02 PM
bobby@lilesonline.com bobby@lilesonline.com is offline
Junior Member
Member
Year: 1977
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 14042
bobby@lilesonline.com will become famous soon enough
Default Cowl Tag Decoding
Tag is as follows:
Body By Fisher
ST 77 1AD80 R 241317 BDY
TR 19N AN7 19L 19T PNT
05A 06430
VIN # ia 1d80l7r461141
Any Help is appriciated.
Old 04-17-2009, 02:12 PM
gilby's Avatar
gilby gilby is offline
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
ok'here it is;
ST 77 =style "77"
1AD80 = 2-door El Camino custom pick-up delivery
R= Arlington,Texas {plant where built}
241317= factory tracking number
bdy= the letter "BDY". this refers to the assembly plant and sequential number
TR= trim
19n=interior trim code{knit cloth ,black} AN7=swivel bucket seats
19L= paint color,{black}
19t=...?..{ I'm not shure about this one,it might be the vinyl top,black}
PNT=paint code
05A=built date,may,first week
06430= accessory option code
1d80l7r461141
1=division{chevy}
D=series {El Camino classic/Chevelle Malibu classic}
80=body style {2-door pick-up delivery/El Camino}
L=engine code{LM1 350 V-8 4BBL 155H.P.}
7=year{1977}
R=plant{Arlington,Texas}
461141=build sequence numbers
I hope this will help you out.
this almost sound like a SS or a Classic..
Old 04-17-2009, 06:09 PM
welder5's Avatar
welder5 welder5 is offline
Name: Matt & Amy
Year: 1985
Region: 6 (FL)
NECOA #: 12463
welder5 is a jewel in the rough
Garage
hey Gilby
can you help with this?
78 1AW80 D024982
24V A51 29L 29U
10A 0875 D91 29L
22U
this car has me baffled, it's a 78 for sure but it has the newer type dash with the round gauges. nothing seems to be right for this 78 thanks
1985 Chevy El Camino LQ9 6.0L Tremec TKO 600 5 speed 13.8 at Gainesville Raceway
1999 chevy Tahoe
2005 toyota Camry
Auto to manual trans swap
Old 06-16-2009, 11:12 PM
One Nut One Nut is offline
Junior Member
Member
Year: 1970
Region: 17(S.CA,S.NV)
NECOA #: 14417
One Nut will become famous soon enough
Default Cowl tag #
Can anyone please decode my new project I'm not having much luck on the body tag #'s
I know its a 1970 built late May in L.A. calif but every thing else is ?
They are
st 70- 13680 dl 05544 bdy
tr 770 50 h pnt
05d 791779 220311
I'm trying to figure out the engine & trans combo
Thanks for the help
Old 06-17-2009, 10:12 AM
gilby's Avatar
Year: 1974
Region: 18(CA)
NECOA #: 10426
Garage
st70 =style 1970
13680 =model,2-door sedan pickup deluxe{el camino}
"DL"{this is not right,either its a "D" or "L"}
D=assembly plant,{Doraville.Georgia} L=assembly plant{Van Nuys,California}
05544=this number was a factory tracking code,with no correlation to the VIN sequence number.
BDY=this refers to the assembly plant and sequential numbers.
TR= trim
770=vinyl,saddle {bench seat}
50 H pnt=exterior paint code{gobi beige W/ vinyl top dark gold}
05D=build date{may,4th week}
791779=accessory codes
220311=?
on all 1969-1971.. trim tags,the engine identification portion of the model identification number always indicates a V-8 engine No 6-cylinder engine identification numbers are stamped on any trim tag .Engine verification must be made by checking the VIN engine.
Old 06-17-2009, 11:00 AM
gilby's Avatar
Year: 1974
Region: 18(CA)
NECOA #: 10426
Garage
for "welder 5",
24V=trim combo,vinyl,dark blue
A51=buket seats
29L=ext.pant,black sapphire met.{sec.color}
29U=primary color,ext.dark blue
10A=stripe color,accent,two tone,lt.grey/red
0875= ???
D91=paint,two tone
29L=sec.ext paint,dark blue
22U=primary color,ext.bahama blue met.
Old 06-18-2009, 04:12 AM
Z71's Avatar
Z71 Z71 is offline
Year: 1972
Model: Sprint
Region: 9 (IN,KY,MI)
NECOA #: 4447
Z71 will become famous soon enough
Also, the VIN will only denote a 6 cyl or 8 cyl engine. If the 3rd digit of the VIN is an odd number (3,5,7) then is came with a 6 banger. If on the other hand its a even number [4,6,8] then it came with a V8 engine. Optional engines are not coded in the VIN until 1972 model year and beyond.
Mike
Owned, to name a few
1966 Impala SS396 (new)
1970 Chevelle SS454 (new)
1972 El Camino SS350 (new)
1973 Chevelle SS350 (new)
1966 GTO (used)
1970 El Camino SS396 (used)
  #8
Old 05-03-2012, 05:13 PM
SINISTER's Avatar
SINISTER SINISTER is offline
Year: 1974
Region: 8 (OH,WV)
NECOA #: 21458
SINISTER will become famous soon enough
Help please!
st 74 1ad80 z 128822
tr 740 a65 1166
O1a 128822 860663
Thanks1
1971 Pontiac Le Mans 350
1973 Buick Centurion Rag top 455
1974 El Camino Classic 350
1976 Pontiac Trans Am 455
1997 Honda Valkyrie
  #9
Old 05-04-2012, 05:06 AM
Z71's Avatar
Z71 Z71 is offline
Year: 1972
Model: Sprint
NECOA #: 4447
Quote:
Originally Posted by SINISTER View Post
Help please!
tr 740 a65 1166
O1a 128822 860663
Thanks1
1974 El Camino Classic Pickup Delivery
Z - Fremont CA Assembly Plant Code
128822 - Serial Number of the Body and only the body, not meant to match the VIN.
740 - Medium Saddle Cloth Seat Trim
A65 - RPO code for Bench Seat with Arm Rest
11 - Lower color is Antique White
66 - Upper color is Bronze Metallic
2 different codes mean 2-tone paint
01A - Month and week produced, Jan, 1st week
128822 860663 - Data Processing Sequence Number. Just a computer generated number unique to this vehicle that was instrumental in the sequencing of the production process. Once the car left the assembly plant this number meant nothing.
  #10
Old 05-09-2012, 03:17 AM
SINISTER's Avatar
Year: 1974
Region: 8 (OH,WV)
NECOA #: 21458
Thank You.
Searching the net for all the paint and option codes is sometimes endless.
The sequence number starts with 1000000?..28,822 Chevelle car built?...first week of January?...Man they built a lot of cars...although the sequence number probably started in 1973?
Interesting.
  #11
Old 08-15-2012, 07:09 PM
396guy 396guy is offline
Member
Knuckle Buster
Year: 1967
Region: 12(MO,OK,KS)
NECOA #: 41
396guy will become famous soon enough
Quote:
Originally Posted by gilby View Post
st70 =style 1970
TR= trim
220311=?
Realize this is a very old thread but it's also very wrong.
* The DL is probably BL for Los Angeles (Van Nuys); 1970 Chevelles were not built in Doraville, GA.
* 791779 is not an accessory code but rather a data processing number used for internal tracking - of no real significance today unless you find a build sheet and this number corresponds to the first 6 numbers in block 24.
* 220311 is a concatenation of two different numbers from the build sheet; 03 is the SCHED NO. found in block 10 and on Van Nuys sheets this indicates the work day of the month - the 3rd day in this case; 0311 is, again, a data processing number found in block 24.
* The explanation about even/odd trim tag style numbers comes from Alan Colvan's book and it is wrong. Depending on the year and the assembly plant, some plants DID code a 6-cyl engine on the trim tag. I have a matrix of 1964-1972 Chevelles and all the production plants showing one of 4 things; (1) whether a plant in that year is known to have coded odd digit style numbers (such as 13380), (2) whether a plant in that year is not to have NOT coded odd digit style number (but the VIN may still show an L6 car), (3) plants and years where no even third digit style numbers have been found yet (all examples so far are even 3rd digits and all happen to be V8s as well), and (4) plants that did not produce Chevelles for a given year.
Quote:
The sequence number starts with 1000000?..28,822 Chevelle car built?...first week of January?...Man they built a lot of cars...although the sequence number probably started in 1973? Interesting.
No. First the number(s) on the trim tag is NOT a GM VIN sequence number. Second you have too many digits, sequence numbers are 6 digits long and for 1974 Chevelles/El Caminos/Monte Carlos in the U.S. begin with 400,001. You'd have to check your VIN tag (not the Fisher Body number plate) for the buid sequence number. If the last 6 digits of your VIN are, say, 410,125 then your El Camino is the 10,125th 1974 Chevelle (all models) built at Fremont that year.
NECOA #041 -
- 1966/1967 Chevelle/El Camino Reference CDs-Facts/Figures/Photos!
- Decoding & Tech info for 64-72 Chevelles & El Caminos
for 64-72 Chevelles & 59-88 El Caminos
  #12
Old 05-17-2016, 11:29 AM
fighter's Avatar
fighter fighter is offline
Junior Member
Member
Year: 1972
Region: 24(EUROPE)
NECOA #: 69049
fighter will become famous soon enough
Garage
Help
ST721338D FISHER 2
TR 701A52 B753931 BDY
2A 53 53 PNT
0654
  #13
Old 05-17-2016, 01:15 PM
Old Bear's Avatar
Old Bear Old Bear is offline
Site Contributor
Name: Gale and his cats
Year: 1970
Region: 18(CA)
NECOA #: 38617
Old Bear has a brilliant future
Garage
Quote:
Originally Posted by fighter View Post
Help
ST721338D FISHER 2
2A 53 53 PNT
0654
st72 =style 1972
13380 =model,2-door sedan pickup base or standard{el camino} and appropriate for a 6 cyl
B=assembly plant of Baltimore
753931=this number was a factory tracking code, with no correlation to the VIN sequence number.
TR= trim
701= vinyl black
A52= bench seat
BDY=this refers to the body assembly plant and sequential numbers.
2A= ??
53= Placer Gold for upper and lower body color
0654=possibly build date, yet does not fit format
See if you agree http://chevellestuff.net/qd/tags/197...bal_decode.htm
  #14
Old 01-29-2017, 07:00 PM
Jima Jima is online now
Site Contributor
Knuckle Buster
Year: 1981
Region: 5 (NC,SC)
NECOA #: 71810
Jima will become famous soon enough
Garage
Help please.
Body by Fisher
81 12c 1aw30 r 105390
23v 21L 21u L
am5
157843
  #15
Old 01-30-2017, 05:54 AM
Chris Nelson Chris Nelson is offline
Year: 1986
Model: El Camino SS
Region: 6 (FL)
NECOA #: 16658
Chris Nelson will become famous soon enough
81=model year (1981)- 12=DEC - C= 3rd week - 1= Chevrolet - AW= Malibu Classic - 30 (80?)=2 door pickup delivery ( El Camino)-R= Arlington plant - 105340= production sequence - 23V (26V?)= dark blue vinyl - 21L=light blue poly (paint) lower color - 21U=light blue poly (paint) upper color - L=lacquer- AM 5 (AM 6 ?) 55-45 seat.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
