Computer in a 78??? And more! - El Camino Central Forum : Chevrolet El Camino Forums
Old 07-05-2009, 09:12 AM
nipper87 nipper87 is offline
Junior Member
Twisted Wrench
Year: 1978
Region: 12(MO,OK,KS)
NECOA #: 8021
nipper87 will become famous soon enough
Default Computer in a 78??? And more!
Hi,
I have a 78 with 350 4barrel auto and enjoy this Forum very much. I am not able to do any of the work on my vehicle but here is what I have learned from you guys.
1. Search is my friend. Almost all issues with my vehicle have been covered and explained on this Forum. Sure makes it easier to communicate with a mechanic.
2. Find a mechanic you can trust and treat them well.
There are a couple of things which I cannot find.
1. Some Gen 5 owners have talked about computer codes, check engine lights etc. Is there any of this on a 78? Mine runs well most of the time, with no evidence of any computer controls when it is not running right.
2. I have full gauges, but there is also a stack of blank bars on the RHS of the instrument cluster. Two of mine are active. One shows red when ebrake on and the other is blue when the hi beams are on. So, what if anything are the others supposed to show?
Thanks, and have a great day.
David Argent
St. Louis
USA
Old 07-05-2009, 09:27 AM
Mike P's Avatar
Mike P Mike P is offline
Year: 1983
Region: 15(AZ,MN)
NECOA #: 13493
Mike P has a spectacular aura about
I'm not sure, but the 78s may not be computer controlled. I have a 78 Monte Carlo parts car for my 83 El Camino project and have pulled the under dash harnesses out of it (haven't gotten to the under hood harness yet), no computer. I was pretty surprised and happy as the harnesses will help clean up the enigne compartment a lot.
It's good to live in a place with no emissions testing.
Old 07-05-2009, 09:36 AM
speedy86 speedy86 is offline
Year: 1970
Region: 11(IA,NE,ND,SD)
NECOA #: 2591
speedy86 will become famous soon enough
The computer wasn't used until 81 so your 78 won't have it.
On the lights, one is FASTEN SEATBELTS, another should be CHECK ENGINE or CHOKE. I'll have to check on the rest.
Jeff J
70 El Camino long time resto
81 Monte Carlo
85 El Camino 4.3L
Many more A/G bodys
Old 07-05-2009, 02:07 PM
gilby's Avatar
gilby gilby is online now
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby is a jewel in the rough
Garage
I'm not quite sure on this one,but,it may also have "tailgate ajar" light too..for station wagons..
Old 07-05-2009, 02:10 PM
Bobby78's Avatar
Bobby78 Bobby78 is offline
Year: 1978
Region: 1 (NY)
NECOA #: 8173
Bobby78 has a spectacular aura about
Garage
Quote:
That's the best thing about the "A" bodies!
Old 07-05-2009, 07:11 PM
mgs72elky's Avatar
mgs72elky mgs72elky is offline
Year: 1972
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 6423
mgs72elky has a reputation beyond reputemgs72elky has a reputation beyond repute
Hey Nipper, Maybe if you get a super powerful flashlight and shine it up under and behind the dash it may cast just enough light through the cracks and crevices to possibly read the markings on those lights. Maybe??? Don't cost anything to try.
Shaking off the winter cobwebs - Video..
<object width="400" height="300" ><param name="allowfullscreen" value="true" /><param name="movie" value="
" /><embed src="
" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="300"></embed></object>
Old 07-05-2009, 09:15 PM
CoyoteOn2's Avatar
CoyoteOn2 CoyoteOn2 is offline
Name: Coyote aka Larry
Year: 1977
Region: 16(CO,MT,WY,UT)
NECOA #: 7195
CoyoteOn2 has a reputation beyond reputeCoyoteOn2 has a reputation beyond repute
Mark, Come on now, THAT would be too EASY.
No guesses like maybe "Oil Slick or Ejection Seat" ?
No longer in SIN CITY
Now in GODS COUNTRY
COLORADO
Larry
(but hay ~ What do I know?)
I'll chew on some Awhile
  #8
Old 07-05-2009, 09:22 PM
mgs72elky's Avatar
Year: 1972
NECOA #: 6423
"Broken Canifelin Pin" perhaps???
  #9
Old 07-05-2009, 09:43 PM
CoyoteOn2's Avatar
Year: 1977
NECOA #: 7195
THAT's Good !!
  #10
Old 07-06-2009, 06:12 AM
Junior Member
Twisted Wrench
Year: 1978
NECOA #: 8021
Thanks guys.
So, no computer on my 78 is a good thing. Seems like simpler is better, especially in a 30 year old truck.
Tried to shine a flashlight behind the bars on the dash but there is not enough room. However, in a dark garage it worked fine by shining the light on the front of the bars. Here is what I have - from bottom to top:
Fasten seat belt
Brake
Brights
Choke
Four blanks
So there is room for ejection seat, oil slick etc
Anyone got anything different on their 78??
Have a great day
David Argent
St. Louis
USA
  #11
Old 07-06-2009, 06:21 AM
Dead End Kid Dead End Kid is offline
Member
Knuckle Buster
Year: 1980
Region: 17(S.CA,S.NV)
NECOA #: 13881
Dead End Kid will become famous soon enough
Just so someone in the future doesn't go down the wrong path, my '80 305 does have a computer. The diagnostic's work different different from the later computer controlled Elky's. No ECM port...must ground test lead off of the computer, but that's for a different post.....
  #12
Old 07-06-2009, 09:26 AM
rushgator's Avatar
rushgator rushgator is offline
Director, Region 13 Texas
Year: 1972
Region: 13(TX)
NECOA #: 2834
rushgator is a jewel in the rough
My '86 did have the oil slick feature, but I fixed it.
Join the
"Wind-In my hair-Shifting and drifting-Mechanical music-Adrenalin surge"--Rush, Red Barchetta
You may not post new threads
You may not post replies
