Custom center console - El Camino Central Forum : Chevrolet El Camino Forums
Old 10-26-2009, 06:15 PM
Dumbell Dumbell is offline
Member
Loose Nut
Year: 1969
Region: 9 (IN,KY,MI)
NECOA #: 9685
Dumbell will become famous soon enough
Default Custom center console
I have a '69 with a 4 speed and I'm looking to build a custom center console. I thought about going with a stock one, but figured I could make a custom one and put gauges, speakers, a CB radio, and more in it.
I was just looking for a book I could buy/get from the library that would help me out with the details. Does anyone know of one? I looked today at the library but didn't find much.
BTW I'm 15 so I'm not trying to get myself over my head. I was planning on using a plywood type material that my dad has used before to make a subwoofer box for the trunk of his Camaro.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Old 10-26-2009, 09:43 PM
Tuggy24g
Posts: n/a
Here are some info about custom center sections. I know it might not be what you want to do, but it will give you some idea on what you need to do or what it takes to make one
http://www.explorerforum.com/forums/...d.php?t=199794
http://www.mp3car.com/vbulletin/fabr...o-journal.html
http://www.louish.com/imports.console.html
http://www.jonsteiger.com/www/barracuda/console/
Old 10-27-2009, 05:39 PM
Member
Loose Nut
Year: 1969
NECOA #: 9685
Thanks, that last one looks pretty similar to what I'd like to do. Except I planned on using a bit lighter wood and covering it with a small layer of padding and then leather.
Old 10-29-2009, 03:16 PM
just plain john just plain john is offline
Year: 1981
Region: 13(TX)
NECOA #: 11645
just plain john will become famous soon enough
I'm not trying to bash or discourage you young man, but it takes a certain skillset to fabricate something like that. Be careful around that table saw! IMO, all the homebuilt interior components I've seen look getto. The edges are square and all surfaces are flat, unlike the rest of the interior whis is rounded and curved. The overall effect just doesn't work for me. There are many different consoles out there, and they generally blend in better. Before you commit to building one out of wood, look around the junkyard and see if there's something you like. Be aware that there's no point of attatchment on the floor. G bodies that were factory console equipped have this attatchment point welded in. These can be found at several vendors cheap. Drilling a hole for a through bolt means trying to put a nut on the bolt on top of the trans where it's hard to see, but it can be done. Good luck and post a pic when you get it done.
Turbo Buick/Grand National powered
Old 10-29-2009, 04:52 PM
Member
Loose Nut
Year: 1969
NECOA #: 9685
Quote:
I'm just going to experiment. If I don't like it, I'll probably just find a stock one.
Thanks for the tip on the attachment point.
Old 10-30-2009, 02:59 PM
VAFLASH's Avatar
VAFLASH VAFLASH is offline
Member
Knuckle Buster
Year: 1967
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 15132
VAFLASH will become famous soon enough
It is all in the up front planning and having the "rigtht stuff handy" along with a full measure of patience. Lay it out, measure more than once, and plan on making some mistakes along with way (and in some cases starting over). The old cardboard template trick is key too . . . and hopefully, if you use the best material, and take your time . . . you will be proud of the final product and no one else will have one like it. I've seen plenty of junk work too, but have also seen just as much of the "beautiful personal work". You will see quickly if you have the ability for this kind of thing or not. If not, don't beat yourself up, just move on and find a aftermarket (or OEM) piece for your ride. At the end of the day, this is the way we learn. Just one guys opinion.
Old 11-05-2009, 06:37 PM
'81ELKYSS's Avatar
'81ELKYSS '81ELKYSS is offline
Year: 1981
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 11486
'81ELKYSS will become famous soon enough
I think if you have the time it would be an excellent idea, you have to learn somewhere right?, tuggy found some great pictures, just be careful working with the tools, you said your dad has made a speaker box, so im sure you'll have some help, and if you mess up, its only wood, but if it comes to, just go to aftermarket.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
