damn v6 problems - El Camino Central Forum : Chevrolet El Camino Forums
Old 10-29-2009, 08:17 PM
big2003viper big2003viper is offline
Junior Member
Twisted Wrench
Year: 1979
Region: 10(IL,MN,WI)
NECOA #: 15169
big2003viper will become famous soon enough
Default damn v6 problems
Just bought a 79 el camino and it hates me. it's supposed to be 8 degrees BTDC. However, as soon as I get it there, it starts to sputter and idle like crap. any advice or ideas?
Old 10-29-2009, 09:27 PM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack will become famous soon enough
Have you disconnected the vacuum advance while checking timing?
Bill
Old 10-29-2009, 09:36 PM
dougs85 dougs85 is offline
Year: 1987
Model: Conquista
Region: 16(CO,MT,WY,UT)
NECOA #: 9322
dougs85 is a glorious beacon of light
Yeah, and plug the vacuum hose.
Doug
85 El Camino 305, TH350, K&N, dual exhausts (Sold 2-21-09)
87 El Camino 305, 2004R, K&N, dual exhausts
1964-1/2 Mustang conv, 260 V8, dual exhausts
2003 Jaguar XJ8, 2000 Harley Road King
66 Austin-Healey BJ8
Lakewood, CO
Old 10-29-2009, 09:42 PM
Junior Member
Twisted Wrench
Year: 1979
NECOA #: 15169
yes, i did all that
Old 10-29-2009, 09:50 PM
El_Ron84's Avatar
El_Ron84 El_Ron84 is offline
Member
Knuckle Buster
Year: 1984
Model: Conquista
Region: 18(N.CA,N.NV)
NECOA #: 9663
El_Ron84 will become famous soon enough
You might check to see if carb bolts need to be tightened, along with the intake manifold bolts, may take care of it.
Old 10-29-2009, 10:01 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
Does the harmonic balancer have any run-out or wobble ?? That scenario is common when the rim of the balancer has slipped on it's rubber mounting on the hub. The timing marks on it will be useless if it has slipped. I would just back off the timing until it runs good, and see how it works on the road.
Otherwise, if you find that it's slipped, get a new one.
Old 10-29-2009, 10:07 PM
woody31's Avatar
woody31 woody31 is offline
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
Garage
you may also have slop in the timing chain, try setting it by ear then road test if it knocks under heavy load take some timing out of it till it quits. hope this helps woody out
  #8
Old 10-29-2009, 10:37 PM
Junior Member
Twisted Wrench
Year: 1979
NECOA #: 15169
also, i might want to ad that the carb pops when i bring the rpms up from idle.
  #9
Old 10-30-2009, 03:15 AM
Junior Member
Twisted Wrench
Year: 1979
NECOA #: 15169
i have not done anything to the distributor since i got it, just try and time it. I tried to time it cuz the carb was poping gas out the top.
  #10
Old 10-30-2009, 03:45 AM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
I have not done anything to the distributor since i got it, just try and time it. I tried to time it cuz the carb was poping gas out the top.
Since you just bought this car then start with a complete tune up, new plugs wires, cap, rotor, plugs, air filter, canister filter, oil change, and if this was done before you bought it check all of the basic items, dont go by "the prevoius owner had it all done before". Check the firing order, if its popping through the carb its either a plug wire crossing over to another, firing order is off or a burnt valve or broken rocker arm. Check all of that, wont take long or bring the car to us and we will install a crate GM engine for ya, 350 or 383 stroker or a 502 if you want, let us know on what ya find, matty man
  #11
Old 10-30-2009, 03:56 AM
Junior Member
Twisted Wrench
Year: 1979
NECOA #: 15169
matty, were are you located exactly?
  #12
Old 10-30-2009, 04:15 AM
matty man's Avatar
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
We are in Columbus, Ohio, Grove City, just below the city, I work 2 jobs, first is the Ohio Air National Guard working on the KC-135R Aircraft and then part time at Classic Resurrection Hot Rod shop, 2160 Southwest Blvd in Grove City, I see your a little bit of a drive away from us, but we have cars from all over the US in the shop, you can check their web site, I think it is www.classicresurrection.com
let us know what you find out on your V-6 and give me a call in the evening if you need any info or help, my cell is 614-595-2875 or the shop # is 614-539-5658, matty man
  #13
Old 10-30-2009, 04:20 AM
Junior Member
Twisted Wrench
Year: 1979
NECOA #: 15169
damn, I was hoping you were closer to me than ohio. I'm in sacramento, ca. what I'm really looking for is a place or person that can let me use a garage to do a 350 swap on my el camino.
  #14
Old 10-31-2009, 01:49 PM
bonos40's Avatar
bonos40 bonos40 is offline
Year: 1980
NECOA #: 8754
bonos40 will become famous soon enough
Matty:
check the compression, and possibly do a leak down test. My v-6 ran the same way, lo,and behold the cam had eaten itself. I guess this was a part of the soft cam craz in the late70's and 80's. On day it was running fine ,than it began to lose power,started to sputter, and ran terrible over the course of two weeks,pulled the cam two lobes rounded, two plugs fouled .......Total Rebuild !
  #15
Old 10-31-2009, 02:07 PM
woody31's Avatar
Year: 1981
Region: 13(TX)
NECOA #: 14520
Garage
if all else fails find a good used 350 if you can or if your budget allows pop for a crate motor cant go wrong any horsepower you can afford plus a warranty.
You may not post new threads
You may not post replies
