Engine Block ID question - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-09-2009, 04:50 PM
L Samino's Avatar
L Samino L Samino is offline
Junior Member
Twisted Wrench
Year: 1984
Model: Conquista
Region: 17(S.CA,S.NV)
NECOA #: 2248
L Samino will become famous soon enough
Default Engine Block ID question
Sort of a newb engine block id question:
I bought my Conquista from a gent who had upgraded to a 350- just don't exactly know what 350 however.
I looked in the driver's wheel well and found the following numbers:
GM 14007400 LHK 13 60 V- this was on the exhaust manifold
379- was on bottom of block
186 297 N was on side of block
are these numbers useful in identifying the block? After doing some research, it seems that maybe the passenger side might be the place to look
Sameer
2001 Porsche Carrera 996 TT
2001 Acura MDX
1984 Chevy El Camino El Conquista, 383 Stroker....!
Old 12-09-2009, 04:57 PM
CANTED's Avatar
CANTED CANTED is offline
Year: 1970
Region: 7 (AL,GA,TN)
NECOA #: 6858
CANTED is just really nice
Garage
Default block ID
The casting number is on the left bellhousing flange
The stamped number is on the right front of the block below the cylinder head
With those two you can ID the block.
Jim
70 ElCamino 461 solid M20 331eaton
Third gen gallery, page 13
Old 12-10-2009, 11:16 AM
L Samino's Avatar
Junior Member
Twisted Wrench
Year: 1984
Model: Conquista
NECOA #: 2248
I got this number off of the right front part of the block just behind the alternator:
V1109800
any idea what specific engine it is? or where I can find out?
Old 12-10-2009, 07:52 PM
thundercat2's Avatar
thundercat2 thundercat2 is offline
Year: 1978
Model: El Camino SS
NECOA #: 12606
thundercat2 has a spectacular aura about
try here
http://www.nastyz28.com/sbchevy/sblock.php
will give you the info
ron
My church is the open road...just me,God,and the highway
Old 03-18-2010, 07:45 AM
ManicMechanic ManicMechanic is offline
Motor Mouth
Year: 1976
Model: El Camino Classic
Region: 13(TX)
NECOA #: 14821
ManicMechanic will become famous soon enough
I have an engine number stamped into the block of V0519800. I went to that web site listed above and found the "V" is for Flint, 05 is for the month of May, 19 is for the 19th day but the "800" has me stumped. I see L Samino has the same "800" on his block. I suspect my engine is a Dart replacement and I wonder if the "800" indicates a "Dart" block. Anyone have any insights on this matter?
Time passes when your not looking.
Old 03-20-2010, 04:22 AM
Z71's Avatar
Z71 Z71 is offline
Year: 1972
Model: Sprint
Region: 9 (IN,KY,MI)
NECOA #: 4447
Z71 will become famous soon enough
V0519800 is a GM parts TargetMaster 350 crate engine (generic)
These are HD engines for use in cars and truck across the entire Chevy. There are not high-performance engines, just you average replacement engine complete less intake and dist. which you transfer from worn out engine or buy new.
V - manf. at the Flint Engine Plant
05 - Month
1 - Day of month
9800 - manf during the 1979 model year
Source for Info - 1976-1981 Chevrolet Chassis and Body Parts Catalog
Mike
Owned, to name a few
1966 Impala SS396 (new)
1970 Chevelle SS454 (new)
1972 El Camino SS350 (new)
1973 Chevelle SS350 (new)
1966 GTO (used)
1970 El Camino SS396 (used)
Old 07-19-2011, 05:52 PM
82_MeanO 82_MeanO is offline
Junior Member
NooB
Year: 1982
Region: 6 (FL)
NECOA #: 19688
82_MeanO will become famous soon enough
could anyone tell me what the engine number V0807CDD means...from the thread got that the V-Flint 08-August 07- the 7th but like the other guy im not sure about the CDD, i think it 1072 chevelle 350 with 175 hp.
Staring at the world through my rear view
  #8
Old 07-19-2011, 05:53 PM
Junior Member
NooB
Year: 1982
Region: 6 (FL)
NECOA #: 19688
could anyone tell me what the engine number V0807CDD means...from the thread got that the V-Flint 08-August 07- the 7th but like the other guy im not sure about the CDD, i think it 1972 chevelle 350 with 175 hp.
  #9
Old 07-19-2011, 06:12 PM
Z71's Avatar
Z71 Z71 is offline
Year: 1972
Model: Sprint
NECOA #: 4447
The Suffix CCD was used many times........
CCD - 1972 Camaro L48 350-200HP 4-bbl carb and TH350 A/T
CCD - 1985 Camaro LG4 305-175 4-bbl carb and TH700 A/T
CCD - 1972 Chevelle L48 350-200HP 4-bbl carb and TH350 A/T
CCD - 1982 Chevelle L39 367-115 HP, 2-bbl carb and TH350 A/T
CCD - 1985 Chevelle LG4 305-175 4-bbl carb and TH700 A/T
CCD - 1972 Nova L48 350-200HP 4-bbl carb and TH350 A/T
CCD - 1985 Pontiac LG4 305-175 4-bbl carb and TH700 A/T Firebird, Gran Prix
CCD - 1982 Impala L39 367-115 HP, 2-bbl carb and TH350 A/T
Look for another set of digits next to this code, that will be the VIN derivative and will match up with the original vehicle that got this engine.
Will look something similar to 12L500001 (just for example)
1 - GM Divisional Code, 1=Chevrolet, 2=Pontiac
2 - Model year of car, 72 in this case. 1980=A and so on...
L - Assembly plant code
500001 - match last 6 digits of cars vin to denote numbers matching engine
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
