700R4 tranny mount - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-12-2009, 03:39 PM
johnrebbb's Avatar
johnrebbb johnrebbb is offline
Motor Mouth
Year: 1978
Region: 12(MO,OK,KS)
NECOA #: 14811
johnrebbb will become famous soon enough
Default 700R4 tranny mount
Howdy all,
I did a quick search but didn't find the answer to my peticular question. Anyway, I have a crossmember coming from Dixie Monte Carlo to replace the ho-made one that came with it.
http://www.dixiemontecarlodepot.com/items/DM94030.html
My question is does a TH350 tranny mount work or what exactly should I ask for at O'Reilly or Autozone? They get kind of a lost look when I tell them what's in it since that's not an option in their system.
Once I get this in, I can get the Hotchkis rear upper control arms dialed in. But that's a conversation for another day. Progress report coming soon!
-john r
1976 BMW R75/6
1978 El Camino
2001 1200 Sportster
Old 12-12-2009, 07:37 PM
toms84ss toms84ss is offline
Year: 1981
Region: 15(AZ,MN)
NECOA #: 10934
toms84ss has a spectacular aura about
Well you could ask for a tranny mount out of a 3rd gen (82-92) Camaro. I don't think there is any difference between them and the TH350 mount.
Old 12-12-2009, 07:51 PM
Ted Dubree Ted Dubree is offline
Year: 1982
Model: Caballero
Region: 7 (AL,GA,TN)
NECOA #: 13380
Ted Dubree is just really nice
Exclamation 700r4 transmission mount
I do believe that the 700r4 transmission cross member bolt hole is 3/4" to the rear of the 350 bolt hole.
Ted Dubree
El Tanko, the Caballero
Old 12-12-2009, 07:57 PM
Year: 1981
Region: 15(AZ,MN)
NECOA #: 10934
Correct as far as location. But the mount itself should be the same.
Old 12-12-2009, 08:39 PM
johnrebbb's Avatar
Motor Mouth
Year: 1978
NECOA #: 14811
I just spent some time fooling around on a couple web sites. Summit's being one. It looks like the Energy Suspension mount would be the same for the 700R4 as well as the 350. I'm not sure about the 400. I guess it's just an issue of springing for it and hoping for the best. I did read when I searched the threads that there may be a height issue of the mount. I will know more as the week unfolds. It's due in on the 16th and I'm hoping for some decent weather!
Thank you for the input! It's hard to justify buying parts when I haven't gone Xmas shopping yet!
-john r
Old 12-13-2009, 01:56 AM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
The bolt centers seem to be the same on most GM stuff. My 400 tail housing fits the TH350 mount. I have another mount here that has the bottom stud off-set about 3/4 of an inch to the front or rear, which ever way it's bolted on.. Forgot what I bought it for. All the TH350s don't use the same mount I found out. Something about the tail shaft housing casting differences versus the flange on the mount. Had to rummage through the shelves in the parts store to get one to fit. Hope you figure it out OK.
Old 12-17-2009, 04:44 PM
johnrebbb's Avatar
Motor Mouth
Year: 1978
NECOA #: 14811
Thumbs up
Well, it looks like the Energy Suspension mount, 3.1108G, will do the trick! The crossmember acts like it's about 3/8" too short per side and the gussets that sit on the frame are a little rearward, but it'll do! The one that was in it was just holding the tranny up by resting the speedo housing section of the tail cone on the crossmember bar it's self. Thankfully nothing's broken!
Back to it over the weekend I reckon. Weather permiting. Then I'll be pickin' the brains of the collective on the best way to adjust the rear upper control arms to set the pinion angle. That's another area though.
Cheers,
-john r.
You may not post new threads
You may not post replies
