Opinions on a 305 bored .030 over - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-22-2010, 03:55 PM
79 Caballero 79 Caballero is offline
Year: 1979
Model: Caballero
Region: 13(TX)
NECOA #: 1315
79 Caballero will become famous soon enough
Default Opinions on a 305 bored .030 over
Ok, so its gonna be down the road some time before I have the money to do this, but I've constantly said I would put a 350 in. However, I currently have a 305 with less than 15000 miles on it and I dont really want to replace an engine so new. So what are yall's opinions, would it be worth it to bore it and get bigger crank and longer rods. Also, bored over, would that make a 327 or 332 stroker. Just a thought, any opinions or info from somebody who knows more about this than me would be appreciated. Thanks.
Travis
Old 01-22-2010, 04:24 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster will become famous soon enough
Default opinions on a 305 bored .30 over
Bored .30 over = 310 cubic inches. Not too sure that the crack would work the block would have to be modified. On a 305 not really worth spending too much $$$$$$. Unless the parts you buy will be swapped over to the 350 engine..
Old 01-22-2010, 04:35 PM
Flaminmeano's Avatar
Flaminmeano Flaminmeano is offline
Year: 1978
Region: 14(AR,LA,MS)
NECOA #: 7482
Flaminmeano will become famous soon enough
Save your money
385 stroker, brodix, weiand super charger,
6' in rods, predator roller cam, duration 238 int
246 exh, lift 576 int / 592 exh, jackson gear
drive, compcams roller rockers 1.6, afterburner
headers, 3' in exhaust with x-pipe, 700r4 trans
and the latest addition; a winters quickchange rearend
Old 01-22-2010, 04:38 PM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
if it is a stroker you want, go with the 383 from a 350, the 305 will run ok with some trick parts but IMO your money will be spent better with the 383 kit. Go price a engine kit 350 vs the 305 the cost will go up as least 100.00+ for the 305,, performance wise I think the 383 will do better, matty man
Old 01-22-2010, 05:15 PM
kloudryder50's Avatar
kloudryder50 kloudryder50 is offline
Motor Mouth
Year: 1970
Region: 9 (IN,KY,MI)
NECOA #: 14730
kloudryder50 will become famous soon enough
Heads and upper breathing will restrict you a bunch and if you upgrade these your bottom end might not live thru it, there is a reason even GM went to another block and crank and heads to make it run and last
Old 01-22-2010, 06:12 PM
toms84ss toms84ss is offline
Year: 1981
Region: 15(AZ,MN)
NECOA #: 10934
toms84ss has a spectacular aura about
Run the 305 and find a builder 350 and go from there. 305's are OK for drivers. But the small bore size limits the power out put when you try to hot rod them. You just can't get big valves in there to get the airflow you need to make big power. Start with a 350 and don't look back. Good roller blocks are available along with Vortec heads for a good running engine on the cheap. You could get 400 HP from a set up like that and still be a reliable driver.
Old 01-22-2010, 06:20 PM
'81ELKYSS's Avatar
'81ELKYSS '81ELKYSS is offline
Year: 1981
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 11486
'81ELKYSS will become famous soon enough
If you rebuild your already new 305, then you wont want to save up for a 350 cause you went through the trouble to rebuild that 305.... again. Drive your car with the 305, built yourself a nasty 383 and then when your done with it drop it in. Save your 305 for a day when something might go wrong with 383, or sell it.
1981 SS 355 vortec motor. 3.73 gears. A lot done to it.
  #8
Old 01-22-2010, 07:10 PM
jk flash jk flash is offline
Motor Mouth
Year: 1985
Region: 10(IL,MN,WI)
NECOA #: 11142
jk flash will become famous soon enough
The difference in price between a 332 stroker kit and a 383 is only about $100. I agree with the above posts, just get the 350 and built a wicked smallblock. you can get SO much more out of a 383 for the same amount of money. I was thinking about doing 332 just to say I did, but now I plan on building a 383 and not looking back.
1985 El Camino- Custom color changing paint, LOTS of chrome, fun ride. 355 cu in roller cam and roller rockers aluminum heads. 281rwhp and 310 ftlbs of torque.
El Camino-
2006 GTO-
  #9
Old 01-22-2010, 07:27 PM
SsUpPoErRt's Avatar
SsUpPoErRt SsUpPoErRt is offline
Gold Contributor
Year: 1979
Model: El Camino SS
Region: 13(TX)
NECOA #: 13523
SsUpPoErRt will become famous soon enough
The 305 vis a good engine. It will get you there and get you back. But no power house. If your gonna put that kinda money into it go with the 350 block.
  #10
Old 01-22-2010, 09:23 PM
Tuggy24g
Posts: n/a
SAVE SAVE SAVE!!!! 3-5 are only meant to be driven around and not to be fast engines. JUst drive it around and then buy your self a 350 or a 400 small block and work from there. Best options on the block in my option
  #11
Old 01-22-2010, 09:48 PM
MIke76 MIke76 is offline
Junior Member
Member
Year: 1976
Region: 12(MO,OK,KS)
NECOA #: 15730
MIke76 will become famous soon enough
Great advice, keep the 305, buy a 350 and take your time and build it. Then when your ready, not stress.
  #12
Old 01-29-2010, 09:19 PM
Year: 1975
NECOA #: 13978
Save your money for "stuff" to use on your next engine. 305 is a small bore engine with very little possible up grades.
I put a Comp Cams 252 cam in my buddy's boat, 305, and it helped get skiers up on the water, but he really needed a 350.
AKA Pila
El Camino resto
The Malibu
  #13
Old 01-30-2010, 02:33 PM
mnunn's Avatar
mnunn mnunn is offline
Year: 1970
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 5673
mnunn is just really nice
Quote:
I agree with you Tom.
79 Cab,
It sounds like you're torn between two goals (a reliable, inexpensive driver engine and a SBC performance engine). In your circumstances, you'll need to decide which is more important to you. The 305 with only 15K miles on it will very likely provide you with another 100K or more economical (but less than thrilling) miles. On the other hand, a fresh crate 400 HP 383 long block can be had for less than 3K or 4K and will turn those future miles into much more enjoyable ones (IMO).
What I wouldn't do is put big $$ into modifying the low mileage 305. I'd sell it to someone in need of a reliable engine and use the proceeds to offset my 383 purchase.
Your call, but I think you'll be happier when you decide which aspect (Economy or thrill) is more important to you.
Either way, you'll win.
Mike
70 Elky (Non-SS) 454CID, TH700-R4
68 AMC Rambler
85 Elky SS
69 Chev C-10 Pickup (lost in the flood of 2010)
29 Model A (Sold).
You may not post new threads
You may not post replies
