HEI in a 71 - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-14-2004, 06:08 AM
racefan racefan is offline
Junior Member
NooB
NECOA #: 2613
racefan will become famous soon enough
Default HEI in a 71
I have a 1971 Elk. I am thinking about putting an HEI dist. in it. I have heard that sometimes the dist. will hit the firewall does anybody know if this is true?Also are there any other problems known of? thanks, Mike
71 Rules!
Old 03-14-2004, 07:54 AM
dennis68 dennis68 is offline
NECOA #: 2629
dennis68 will become famous soon enough
Default hei
Not in a bodies, some nova's and camaros have firewall interfierence but A bodies have lots of room
Old 03-14-2004, 10:44 AM
Tommy's Avatar
Tommy Tommy is offline
Year: 1978
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 14
Tommy will become famous soon enough
Garage
You should not have any clearence problems. Just remember to use a new wire for power. Your stock wire will not handle the power requirements of an Hei. A Hei is a good choice for power & reliablity.
78 Camino SS, new built 357,built 700r4,3.23 posi
93 S10 4x4, 4.3, 5 speed
83 280zx turbo, 5 speed
99 Maxima SE-L, 5 speed
MSGT 145 AW
NECOA #14
Old 03-14-2004, 01:44 PM
Mrapii's Avatar
Mrapii Mrapii is offline
Venerated Member
NECOA #: 2314
Mrapii will become famous soon enough
Yes Tommy is right about the wiring. Do not use the old ignition wire because the voltage goes thru a ballast resistor which reduces the voltage. The engine will start and run but the spark output will be low and the engine will run poorly. Trace the wire and remove the ballast resistor or you can bridge across it.
1979 El Camino\r\n1955 Chevrolet Del Ray\r\n1962 Corvette\r\n1966 Corvette Coupe
Old 03-20-2004, 02:04 PM
Mama Mayhem's Avatar
Mama Mayhem Mama Mayhem is offline
Year: 1971
Region: 7 (AL,GA,TN)
NECOA #: 2540
Mama Mayhem has a spectacular aura about
I have a GM HEI in my 71, there is not a lot of room left but it fits fine. I also put in an MSD HEI kit (cap, coil, rotor, module) that I bought from Summit for about $139, works great. But you definitely need 12 volts to the dist, and don't try running too far on low voltage (bad alternator) with the MSD, it requires lots of juice.
Old 03-23-2004, 09:45 AM
ElkyPete's Avatar
ElkyPete ElkyPete is offline
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
ElkyPete is just really nice
Quote:
I have the MSD 6A they call it the HEI Super conversion kit. According to the manual the MSD ignitions will run on as little as 5v DC. Maybe that is not true for the normal HEI kit or maybe the manual is just misleading the user?
Home Site:
1972 El Camino Custom 400
1976 El Camino Classic
1980 El Camino Super Sport
E-Mail:
Old 03-23-2004, 01:13 PM
Mrapii's Avatar
Venerated Member
NECOA #: 2314
Maybe the MSD box will still work at 5v but I doubt very much the ignition coil would function at that low voltage and provide enough secondary voltage to the sparkplugs to fire them. If your electrical system only puts out 5v then you better fix it.
  #8
Old 03-24-2004, 11:29 AM
ElkyPete's Avatar
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
Quote:
If the ignition will run on from the trickle voltage through the Dash Alternator light, when the key is in the off position, then I would say the statement made by MSD about needing as little as 5 volts is true and they are not talking about power just to the MSD Electronic Module Box.
Racers use only a Battery no Alternator. I am sure that in some cases by the end of the night it is possible to have a very small charge left over and it could be as little as 5V.
However I would feel comfortable knowing that in the event my Alternator goes out on a rainy night that I'll have a little extra from the ignition to help me get to someplace I can fix it. I don't think their point was that you "should run it at 5V". just that if it happens then it will still function.
  #9
Old 03-25-2004, 12:37 AM
Mrapii's Avatar
Venerated Member
NECOA #: 2314
MSD makes good stuff, if they say the ignition will still work at 5v then I'll believe them. But I know my electric fuel pump won't so I'll have to fix the charging system anyway.
  #10
Old 03-25-2004, 09:57 AM
Year: 1971
NECOA #: 2540
Ever notice that almost all the Nascar stock cars run MSD ignitions and when one loses the alternator they end up losing the race, voltage in translates directly to voltage out. It might well run on as little as 5 volts, but it won't run good or far. I a problem with pulley trouble for a while and kept losing belts and I could nurse it home from a futher distance with the stock HEI than I could after I converted to the MSD. That's why I said about having a good alternator and battery.
  #11
Old 03-25-2004, 12:59 PM
Mrapii's Avatar
Venerated Member
NECOA #: 2314
The fact that an MSD ignition will operate on as little as 5v is interesting but not really helpful. Many mechanics think that the car's electrical system runs off of the battery which is incorrect. The battery is there to store electricity to start the car only; when the engine is running the electricity is provided by the alternator. Drag racing cars sometimes use only a battery but it is kept fully charged. Go thru the pits and you will find that many racers now use very small racing alternators or 16v batteries because they need to keep system voltage at 12v. We street rodders need to keep voltage above 12v because ignition systems, electric fuel pumps and cooling fans don't work well much below 12v.
  #12
Old 09-22-2004, 07:35 AM
MI2600 MI2600 is offline
Year: 1972
Region: 9 (IN,KY,MI)
NECOA #: 3881
MI2600 will become famous soon enough
When I bought my '72, it had an HEI in it. The problem was it was so close to the firewall I couldn't turn it to set the timing. I went back to a points type.
'72 El Camino - 406
'86 El Camino - 406
'67 Chevy Biscayne - 383
  #13
Old 09-22-2004, 01:22 PM
John_Muha John_Muha is offline
NECOA #: 534
John_Muha will become famous soon enough
Quote:
I have a GM HEI in the 72 350/350 Elky. Came out of a 78 truck. There is about 1 inch between the rear of the unit and the firewall. Biggest problem I have is trying to get a wrench under it to adjust it.
You may not post new threads
You may not post replies
