driveshaft question - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-11-2010, 02:00 AM
Midnight87
Posts: n/a
Default driveshaft question
Some time back I installed a 700R4 into my '87, it originally had the METRIC 200 in it. I had to shorten the driveshaft 3 inches and I thought all was well. I recently swapped in a 3:73 posi out of an '86 Monte Carlo and now I get a slight vibration at high speed. The shaft must be just a tad out of balance which wasn't noticeable with the 2:40 gears. I also have the shaft out of the Monte Carlo, is there any chance that shaft would be the proper length?
Thanks.
Old 03-11-2010, 04:03 AM
Millard Millard is offline
Motor Mouth
Year: 1984
Model: Caballero
Region: 6 (FL)
NECOA #: 15709
Millard will become famous soon enough
Check that your u joints are not out of phase.
Old 03-11-2010, 05:40 AM
moterhead's Avatar
moterhead moterhead is offline
Year: 1970
Region: 3 (DE,NJ,PA)
NECOA #: 15488
moterhead will become famous soon enough
Pinion bearing? Possibly crush sleeve not torqued enough? Just a couple of things I'd check. Good Luck!
It's easier to get forgiveness than it is to get permission.
Old 03-11-2010, 07:30 AM
Midnight87
Posts: n/a
u joints are oriented proper and the differential was never apart, it is "from the factory" set up. Like I said, this was not an issue until the lower gears started spinning the driveshaft faster. Does anyone know if the El Camino & Monte Carlo shafts are the same length?
Old 03-11-2010, 08:06 AM
georgiamadman georgiamadman is offline
Year: 1983
Region: 7 (AL,GA,TN)
NECOA #: 9248
georgiamadman will become famous soon enough
No...the monte had a 200R4 from the factory its the same lenghth as a 350 or metric 200.
Old 03-11-2010, 12:30 PM
Midnight87
Posts: n/a
Quote:
Thank you.
Old 03-11-2010, 12:42 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
Make sure the bushing in the 700R4 tail housing is tight on the slip yoke. If it's not tight, you will be chasing other things to get the vibration issue solved. The higher ratio, and drive shaft RPM may be enough to set it off. That bushing is the same one as the TH350.
  #8
Old 03-11-2010, 02:06 PM
stev6343 stev6343 is offline
Year: 1982
Region: 5 (NC,SC)
NECOA #: 14194
stev6343 has a spectacular aura about
Midnight, rotate the driveshaft 180 degrees. That may be an easy fix for balance.
  #9
Old 03-11-2010, 09:43 PM
Year: 1975
NECOA #: 13978
Good call. When the balance is OK, it's a good idea to mark the shaft and companion flange when removing the shaft, so it goes back where it runs best.
  #10
Old 03-11-2010, 10:57 PM
Midnight87
Posts: n/a
Thanks guys.
  #11
Old 03-12-2010, 10:56 AM
old_coot old_coot is offline
Year: 1983
NECOA #: 3943
old_coot is just really nice
All drive shafts have a harmonic speed at which they will "wobble". Having higher gears will make it show up at a lower speed. the best way to alter it to a higher rpm is to change the material to a lighter weight shaft --as in aluminum or carbon fiber....It may be perfectly balanced and just be the harmonic doing it. remember the El camino drive shaft is longer than and other---short of trucks, and they usually use a two peice driveshaft to avoid the harmonic there. This is a fairly common complaint on a long wheel base vehicle...........Dan
I don't think I have ever had a car that was "FINISHED"........unless it was totaled.
  #12
Old 03-12-2010, 11:20 AM
Year: 1975
NECOA #: 13978
Here is a place that has all the info,
http://www.iedls.com/ Inland Empire drive line service. All you ever wanted to know about drive shafts, engine and trans angles, pinion angle on rear etc,
When I'm ready for a new drive shaft for my Elco/Caddy 500 project, that's where I'm gonna get one made.
  #13
Old 03-12-2010, 11:41 AM
PaPa Johns 77 PaPa Johns 77 is offline
Year: 1977
Model: El Camino Classic
Region: 10(IL,MN,WI)
NECOA #: 6188
PaPa Johns 77 is a glorious beacon of light
Quote:
Have done this many times and it worked!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
