Blank roll pans. Steel or fiberglass? - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-17-2004, 08:54 PM
Strebor Strebor is offline
Junior Member
Gear Head
NECOA #: 2569
Strebor will become famous soon enough
Default Blank roll pans. Steel or fiberglass?
Which one would be easier to adapt to mount your own taillights? I guess for steel I'd have to weld a bit of metal to mount the stuff, but what would I have to do to a fiberglass one? And if steel would be easier, where can I find a blank one with the license plate cutout?
Old 03-17-2004, 10:10 PM
nowukno's Avatar
nowukno nowukno is offline
Year: 1978
Region: 18(CA)
NECOA #: 2160
nowukno will become famous soon enough
I used a fiberglass blank rollpan from lauren engineering you can see the pic in the 5th gen section album nowukno on the 10th page..
Old 03-18-2004, 08:50 AM
ElkyPete's Avatar
ElkyPete ElkyPete is offline
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
ElkyPete is just really nice
Here is Lauren Engineering's address http://www.laureneng.com/
I can recomend them and they do, in my opinion, good quality work.
Home Site:
1972 El Camino Custom 400
1976 El Camino Classic
1980 El Camino Super Sport
E-Mail:
Old 03-18-2004, 11:22 AM
ElkySS's Avatar
ElkySS ElkySS is offline
NECOA Founder
Year: 1987
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 1
ElkySS will become famous soon enough
This one if from Lauren. http://www.elcaminocentral.com/modul...bum.php&page=2
Had to split one end and spread it to make it fit perfectly. It was off about 1/2" on the Pass. side.
This is the second Lauren panel we did this to.
NECOA member Bill Waxler and I made the t/l housings from round pipe and he then "boxed" a housing around them, then we fiberglassed the housings to each side of the rolled pan after cutting the holes for the housings to match up.
We had trouble with the original plan to use "Red LED" bulbs and clear lenses...couldn't get my sequential turn signal controls to draw enough juice to run the large LED bulbs. So, we went with "Plan-B" and used red Corvette Sting Ray lenses and regular 1157 bulbs. The sequential turn signals are "trick". It's off to the painter for spraying the filled in tailgate the rolled pan and respraying the custom hood inserts this weekend.
Dan Smith
'87 ChooChoo SS (w/LT1) (sold)
'59 El Camino (sold)
'84 ChooChoo SS (sold)
'02 Corvette
Old 03-18-2004, 02:54 PM
elmpala elmpala is offline
Motor Mouth
Year: 1985
Region: 12(MO,OK,KS)
NECOA #: 4
elmpala will become famous soon enough
I don't think its a question of which one is easier. You won't find a steel rollpan for the Elky. My fist one was from Lauren without a plate cutout, the second one had the plate cutout. Both of them required modification to fit my car. On the first one I used the standard taillamps. On the second one I modified the stock taillights by removing the backup lignts, rotated them 180 degrees and cut in some KC Hiliter halogen backup lights. I epoxied in some stainless steel bolts to allow attachment of the taillamps from the rear. Over time you could see the outline of the bolt heads. I never tried to mould it in because a friend tried and eventually it started to crack. When I did my rear end for the third time, after another accident, I looked high and low for a steel rollpan. A fullsize is to long a S10 is to short and they both need extensive metal work to match up with the bumper bump on the rear quarters. I was lucky enough to find a bodyman who works in steel who rolled me a pan and got rid of the bumper bumps at the same time. Good luck in your quest. Check out my construction pictures in 5th members gallery page 9 sheet 2.
NECOA MEMBER #004
Old 03-18-2004, 08:12 PM
86camino 86camino is offline
NECOA #: 2166
86camino will become famous soon enough
we made the one on my elky it took the better part of the day but it's a one of a kind.
Old 03-24-2004, 09:28 PM
Furious82 Furious82 is offline
Year: 1982
Model: Caballero
Region: 13(TX)
NECOA #: 2725
Furious82 will become famous soon enough
I bought a steel one for my 81 but i dont remember what company i bought it from. They didnt stock them so they made me one. I got a solid one with the liscense plate mount in the middle and put some 97 cadillac taillights in. The nasty humps on the corners of the quarter panals i shaved off and made them flush with the rest of the body. If i fure out who i got it from ill let you know.
81 El camino (BIG project)
90 Celica Alltrac (project)
01 Silverado
You may not post new threads
You may not post replies
5'th generation "blank' faceplate oldelky80 Interior Restoration 13 01-09-2009 07:50 AM
Steel Roll Pan for my 82 gr8efx Body Restoration 4 11-18-2007 07:50 PM
ROLL PANS HW BAG Body Restoration 9 08-23-2006 05:02 PM
Roll Pans Ehlien Body Restoration 16 05-18-2006 07:41 AM
Steel Roll Pan LCaminoCJ Body Restoration 6 03-12-2005 08:47 AM
