5th gen parts needed -- denmark - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-01-2010, 02:40 PM
Troubleis's Avatar
Troubleis Troubleis is offline
Member
Loose Nut
Year: 1987
Region: 24(EUROPE)
NECOA #: 16651
Troubleis will become famous soon enough
Default 5th gen parts needed -- denmark
Hi there..
I need tan seatbelts that work.. Mine wont lock as i brake thereby not holding me back when i brake.
Also, if anyone has glasfiber bumbers please write me.
Headers for my 305 possibly. With thick flanges please. preferrably LT's. No shorty ones.
A new rear end that will hold up to some abuse also.. MCSS rear end if it's a straight fit wich im told..
New shocs in front, springs in front, and a complete bushing set front to back. Not urethane, they will squeak im told.
Let me know if you have any of these and are willing to send them to the other side of the world
Old 06-01-2010, 03:11 PM
speedy86 speedy86 is offline
Year: 1970
Region: 11(IA,NE,ND,SD)
NECOA #: 2591
speedy86 will become famous soon enough
On the seatbelts, take out the black handle in the lower door jamb and see if that turns freely.
If it does I can pull a set of tan seatbelts out of an 86 that has a full bench seat.
Jeff J
70 El Camino long time resto
81 Monte Carlo
85 El Camino 4.3L
Many more A/G bodys
Old 06-02-2010, 12:49 AM
Troubleis's Avatar
Member
Loose Nut
Year: 1987
Region: 24(EUROPE)
NECOA #: 16651
Not sure i understand!
Without taking them out, I can turn the black handles freely in both sides. Is that enough to verify the seatbelts don't work? Or do i have to take them out and turn them?
What do you want for the seatbelts?
/Tim
Old 06-02-2010, 04:37 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute
Troubleis, I can't help you with any of the parts but here is a tip on the seatbelt not locking.
Remove the interior trim to get access to the belt mechanism. Remove the two screws from the "black handle under the door mechanism". Unbolt the belt so it is easily accessible. Move, or try to move the weight mechanism. You can usually spray a little penetrating oil and work it some and it will free up. Be careful to keep the spray off the belt material.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
Old 06-02-2010, 03:22 PM
Year: 1970
NECOA #: 2591
Do like 464Elky said, both the "black handle" and the part it connects to gets gummed up with dirt and sometimes rust. Just because the handle moves in the door jamb doesn't always mean it's working properly.
If you still want to buy the seatbelts I'll do $50 + shipping to you for the full set.
Old 06-04-2010, 04:37 PM
Troubleis's Avatar
Member
Loose Nut
Year: 1987
Region: 24(EUROPE)
NECOA #: 16651
this is why i like this site so much! Very helpfull
I will do so in the morning. If it's not working I will buy those seatbelts from you if they are still around.
Old 06-05-2010, 07:55 AM
Year: 1970
NECOA #: 2591
I'm sure they will be still around, let me know either way.
You may not post new threads
You may not post replies
