How to install a new radio & subs? - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-22-2010, 11:50 PM
Shuey92's Avatar
Shuey92 Shuey92 is offline
Junior Member
Twisted Wrench
Year: 1982
Region: 25 (ALL OTHER)
NECOA #: 16710
Shuey92 will become famous soon enough
Default How to install a new radio & subs?
Okay I'm have problems installing my new radio and subs into my camino... Im not sure what to do because there arnt any of the wires there that im looking for.
http://picasaweb.google.com/lh/photo...eat=directlink
This is the dash opening w/ wires
(None of them seem to match up with the radio wires..)
Subs
Radio
Radio wires/connectors
I had one of my friends thats done radio installations for some of his cars and he wasnt sure eather..
1982 El Camino - - In Restoration
Old 06-23-2010, 12:40 AM
kevink kevink is offline
Member
Knuckle Buster
Year: 1969
Region: 18(CA)
NECOA #: 10057
kevink will become famous soon enough
Is that a stock reproduction radio? Are the speakers in the car factory or are you also upgrading to new speakers? Also, do you have an amplifier for the sub or do they have a built in amp?
I installed a complete new system in my camino. New radio, component 6' speakers in the doors, 6x9's in the rear, dual 12in subs in rear, and two amplifiers, one for subs and one for speakers. It looks like the main problem with your system is that your trying to mix new sub technology with original technology radio equipment and speakers. I'm not a audio system genius but as far as I know you can't hook up subs to a radio like that, you need a modern radio that has propper connections to hook up to an external amplifier which then powers your subwoofers. That repo radio doesn't have nearly enough power to power those subs.
Usually when you see cars with a stock radio like that in the dash and subs in the back at car shows it because the stock radio is just a fake and they have a modern radio hidden in the glove box or somewhere else that actually runs the system. Really we need more info about what your trying to do and all the components of your system to help you out
Old 06-23-2010, 01:02 AM
Shuey92's Avatar
Junior Member
Twisted Wrench
Year: 1982
NECOA #: 16710
The radio is basicly a new radio with the old classic look so it can connect to modern equipment and the speakers in the car are stock. My main problem though is I cant figure out how to connect the radio to my car, because if you look at the picture of the dash where the radio would go there doesnt seem to be the wires to hook up the radio. (When i got the car the radio was taken out)
Old 06-23-2010, 01:28 AM
burns's Avatar
burns burns is offline
Name: Johan Gressberg
Year: 1970
Region: 18(CA)
NECOA #: 11107
burns will become famous soon enough
SEARCH THE FORUM
1970 El Camino - Work in progress
1996 Dodge Ram 1500 4x4 - SOLD
1984 El Camino Conquista - TOTALED
- UPDATED!
Old 06-23-2010, 01:37 AM
Shuey92's Avatar
Junior Member
Twisted Wrench
Year: 1982
NECOA #: 16710
Quote:
Originally Posted by burns View Post
I have searched thank you very much & I found those links already
but thx anyway
Old 06-23-2010, 01:49 AM
burns's Avatar
Year: 1970
Region: 18(CA)
NECOA #: 11107
you need to pick up a wiring harness adaptor that fits your car and stereo, and as pointed out you'll need a amp to run those subs.
Old 06-23-2010, 11:41 PM
Shuey92's Avatar
Junior Member
Twisted Wrench
Year: 1982
NECOA #: 16710
http://picasaweb.google.com/10413160...26215355423378
Okay here... is this the radio wires & plug?
  #8
Old 06-24-2010, 12:41 PM
Member
Knuckle Buster
Year: 1969
Region: 18(CA)
NECOA #: 10057
It's really hard to tell in that picture. I'm also not familiar with the wiring or your cars year. Do you have wiring diagrams for the vehicle? Your best bet will probably be to look at wiring diagrams of the stock stereo system and then you can probably sort out the wires under the dash just by matching colors to the diagram.
  #9
Old 06-24-2010, 03:24 PM
jstanfield3306's Avatar
jstanfield3306 jstanfield3306 is offline
Year: 1987
Region: 13(TX)
NECOA #: 15333
jstanfield3306 will become famous soon enough
I also can't tell because of the fuzzy picture, but I DO have the factory electrical manual for an '87 and the wiring is probably the same. Here it is from my manual:
Yellow - Accesssory or Ignition - hot only when key is on
Orange - Hot all the time
Gray - Dash Lights
Brown - Hot all the time
Black - Ground
Speaker Wires:
Left Front Gray & Tan
Right Front Dark Green & Light Green
Left Rear Brown & Yellow
Right Rear Dark Blue & Light Blue
'87 Blue Under Interior Restoration
'79 Red for sale (Now running)
  #10
Old 07-29-2010, 12:03 PM
goodcruiser goodcruiser is offline
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
goodcruiser is a glorious beacon of light
Basically all you need from the original harness is power and ground,you did run new wire for the speakers right.If your head unit has memory you will need to a wire from the lighter to the memory or some other constant source with key off.Check your head unit installation instructions,any wires not used tie them up out of the way.My harness was chopped up like that so I went to the dismantlers and found the original connectors and spliced them in,then I did my install.Does your head unit have a feed wire to support subwoofers?
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
