Instrument panel options - Elcamino store vs Dixie Montecarlo - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > General BS Topics
Old 08-05-2010, 03:19 AM
79elky-resto 79elky-resto is offline
Junior Member
Gear Head
Year: 1979
Model: El Camino SS
Region: 1 (NY)
NECOA #: 16563
79elky-resto will become famous soon enough
Default Instrument panel options - Elcamino store vs Dixie Montecarlo
Hi all,
First......I really want to comment how helpful it is to be a part of this site. The amount and level of information and experience everyone is willing to share is invaluable. Thanks for all the advice so far. Ok.....enough with the mushy stuff....
So the instrument panel on my 79 needs work. Both the speedometer and odometer don't work. Neither does the clock. The oil gauge works sometimes when the needle isn't flapping back and forth. I thought to get them fixed but also to just upgrade the whole panel.
The elcamino store has a nice panel that I'm looking at:
http://www.elcaminostore.com/el-cami...1978-1981.html
Dixie Montecarlo also has a shadowbox cluster
http://www.dixiemontecarlodepot.com/items/DM00514.htm
Does anyone have any experience with either of these? Can you comment on the fit and look. How much did you like the result? If you have any pictures you can post, that would be helpful to see what it looks like in the dash.
Or.....if anyone has any other suggestions or options, that would be welcomed.
thanks.
Old 08-05-2010, 07:26 AM
johnmil's Avatar
johnmil johnmil is offline
Member
Knuckle Buster
Year: 1982
Region: 13(TX)
NECOA #: 16664
johnmil will become famous soon enough
Default Lot of $$$
I have experience with neither of the instrument panels you
suggest. They do look nice don't they? For that amount of
money, I'd sure remove the existing speedometer and clock,
take to a speedometer shop and get a quote on repairs.
IMHO you understand.
John '82 El Camino
Old 08-05-2010, 08:01 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan has a reputation beyond reputedarbysan has a reputation beyond reputedarbysan has a reputation beyond repute
Speedeometer may just be a cable or drive gear issue. Less than $50 to fix. The clock probably has the contacts inside welded together. Break apart and file with a point file. The Oil Pressure issue sounds like it might be the sender. If the guage is moving, it's getting some signal. Also, all of the guages ( except the speedo) run through one large contact, and the contacts can get bad over time. Cleaning these contacts might also solve your issues.
I'd try some simple maintenance before spending big bucks, just to find out you need to do the maintenance anyway.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 08-05-2010, 04:02 PM
1983SS454's Avatar
1983SS454 1983SS454 is offline
Year: 1983
Model: El Camino SS
Region: 6 (FL)
NECOA #: 13734
1983SS454 has a spectacular aura about
If you Like the look then build it urself for a 1/3 of the $ or less
"El Camino- the mullet of cars.... All business up front, and party in the back!"
1983 El Camino SS, 468 BBC, Muncie 4 speed, Quick performance 9" rear end[SIGPIC]http://i682.photobucket.com/albums/vv188/abigda/tonyspics009-1-1.jpg[/SIGPIC]
Old 08-05-2010, 04:12 PM
67ELK's Avatar
67ELK 67ELK is offline
Year: 1967
Region: 15(AZ,MN)
NECOA #: 17033
67ELK will become famous soon enough
Quote:
+1 On DIY it usually turns out even nicer and you can say you did it!!
Deputy Director
Region # 15
67 EL Camino "Currently in restoration"
2002 Dodge Dakota
I may not have it All together....But together we have it All!
Old 08-05-2010, 04:44 PM
mrwonterful's Avatar
mrwonterful mrwonterful is offline
Year: 1985
Region: 6 (FL)
NECOA #: 15985
mrwonterful will become famous soon enough
Im gonna be Redundant, just learned that word yesterday, Im working on my guages also, no deep pockets here. My oil pressure guage is the last one to fix.............yeah there dark and hard to see but...................my clock works great,I didnt have to fix but it ticks louder than the radio............................................. ......so Id say...................DIY
Age is Wisdom But there"s exceptions to every rule! JER at your service, (occasionally)
Old 08-05-2010, 04:48 PM
Year: 1985
Region: 6 (FL)
NECOA #: 15985
one more thing, they do sell just the white faces to stick on your guages but I understand thats a little bit of a task
  #8
Old 08-05-2010, 04:51 PM
Junior Member
Gear Head
Year: 1979
Model: El Camino SS
Region: 1 (NY)
NECOA #: 16563
thanks......is it easy to pull apart the dash and get to the gauges? I'm not really experienced with how to do that kind of work. I'd definitely like to save the money and do it myself. Any recommendations or guides somewhere on how to open the dash up and reach them?
regards.
  #9
Old 08-05-2010, 05:13 PM
Year: 1985
Region: 6 (FL)
NECOA #: 15985
if I remember correctly theres only six screws to take of the big trim panel to get at em, thats as far As I went,, and I just took it off to spray, and the headlight switch, then your at the clear plastic panel, had to wiglle around steering column, but was pretty easy, at that time I wasnt dealing with guages only paint
  #10
Old 08-05-2010, 05:38 PM
Rafael85's Avatar
Rafael85 Rafael85 is offline
Junior Member
Twisted Wrench
Year: 1985
Model: El Camino Classic
Region: 10(IL,MN,WI)
NECOA #: 16224
Rafael85 will become famous soon enough
Im just jealous you have gauges, my 85 just has dummy lights. any ideas where i can pick up a circuit board for converting to real gauges? what cars circuit boards would fit?
  #11
Old 08-05-2010, 05:56 PM
Year: 1985
Region: 6 (FL)
NECOA #: 15985
I really cant answer that but what I know monte carlo is very similar, I have gone to LKQ ,I understand there nation wide u pull it places ,cost 2 bucks to get in, no phone info given, but when I went there and told them what I was looking for they gave me a printout of all the cars that had that part.They gave me a bunch of small electrical items and the mirror control for 3 bucks and a price list for the big stuff, very reasonable, they print a list of cars they get in on craigslist everyday
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
