6.0 in a 5th gen - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-02-2010, 03:10 PM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead is just really nice
Default 6.0 in a 5th gen
I've searched this site but got zero results so I need some help. I just bought an 82 SS beater for $500. This is a father son project. I bought my son an '03 2500HD silverado last year and it has the 6.0/auto in it. We want to get another 6.0 and install it in the SS with a th400 , carb and what all we can afford. Is there any info on here that can help me?
Old 12-02-2010, 03:47 PM
sandblaster's Avatar
sandblaster sandblaster is offline
Year: 1985
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 727
sandblaster will become famous soon enough
Try street and performance ,you need different motor mount brackets to install this motor. Some of those motors have a tall intake manifold,(possible clearance issues.) Certain oil pans different may be a problem. Also the computer harness $$$ ...
Old 12-02-2010, 03:51 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is offline
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
I don't think this is that common a swap. Undoubtedly it has been done more than once, and you will find some tips/help on it, but in the meantime, maybe you could work on the other areas that a $500 elco will need to have addressed. I am sure there are 1 or 2!
Have you checked out the floors, glass channels, and rear frame rails yet? These are the most common problem areas. And don't forget the wiring!
Just saying that while you are looking for the 6.0 info, procede in other areas.
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 12-02-2010, 06:06 PM
1983SS454's Avatar
1983SS454 1983SS454 is offline
Year: 1983
Model: El Camino SS
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 13734
1983SS454 has a spectacular aura about
Maliburacing.com has tons of info on LSX swaps, thats the place to see about Elco 5th gen engine swaps. Got all my info for my big block 4 speed swap there.
"El Camino- the mullet of cars.... All business up front, and party in the back!"
1983 El Camino SS, 468 BBC, Muncie 4 speed, Quick performance 9" rear end[SIGPIC]http://i682.photobucket.com/albums/vv188/abigda/tonyspics009-1-1.jpg[/SIGPIC]
Old 12-02-2010, 06:17 PM
1BadElky's Avatar
1BadElky 1BadElky is offline
Year: 1986
Model: Conquista
Region: 7 (AL,GA,TN)
NECOA #: 6381
1BadElky will become famous soon enough
and ls1tech.com has a massive thread devoted to G-body swaps
Currently undergoing resto.
Mods:
-355/200-4R/3.42 posi 8.5"
-ZQ8 wheels
-Blazer brakes
-12.7:1 steering
-Lowered 2"
-HIDs
Old 12-02-2010, 06:21 PM
CF's Avatar
CF CF is offline
Year: 1984
Region: 1 (NY)
NECOA #: 11434
CF will become famous soon enough
like 1983ss454 said check out maliburacing.com ther is a fresh post with video there right now.
http://www.youtube.com/watch?v=Jo_fI-5q4D4
84 e/c 454/200r4
Old 12-03-2010, 04:22 PM
ssr71's Avatar
ssr71 ssr71 is offline
Year: 1972
Region: 4 (MD,VA)
NECOA #: 13902
ssr71 has a spectacular aura about
Quote:
This is the site with the expertise you need.
The guys on "Horse Power TV" did just this on an '85 Monte Carlo. Should be able to buy the DVDs... but not like they really show you much.
Yes, a truck intake could potentially have clearance issues, but you can simply pick up a used LS1/LS6 factory intake from ebay to resolve that problem. Also, don't plan on using any of the factory accessory drive systems on a G-body as there are clearance problems on both sides.
3 Chevys and counting...
1972 El Camino (SS Clone)
1999 Silverado 1500
2005 SSR w/6 speed
  #8
Old 12-03-2010, 04:39 PM
merc2u's Avatar
merc2u merc2u is offline
Year: 1985
Region: 4 (MD,VA)
NECOA #: 16485
merc2u will become famous soon enough
I have a 454 in my 85. I didn't have any clearance issues until I got the bright idea of going to a serpentine system. I got it in there, but it wasn't a lot of fun. I had to make new brackets to lower the right and left sides, then I had clearance issues with the power steering and steering box. You might have the same problem. What I finally had to do was shim up the radiator support and shim the cowl. There just isn't enough room in there....merc
  #9
Old 12-04-2010, 02:09 AM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
melissadunagan will become famous soon enough
Yes the pick up intake is too tall. you will need one far a F Body or a Corvette. And you will need the fuel rail, fuel injectersand the throttle body. Also you have to change all of the front accessory to the F Body, you also have the use the F Body harmonic balancer. You can you the pickup A C compressor if you make the holes longer in the bracket. The pickup oil pan will work though the ground clearance needs to checked. I think in the long run it would be easyer and maybe less money to use a Corvette engine. Lest parts to have to change.
the ferret lady
  #10
Old 12-04-2010, 04:33 AM
zach01s's Avatar
zach01s zach01s is offline
Year: 1983
Region: 15(AZ,MN)
NECOA #: 17821
zach01s will become famous soon enough
Quote:
You said carb.... so you want to convert it to a carburated motor? i dont know if its possible since they dont have a conventional type distributor. its all computer controlled and the computer relys on a throttle position sensor and/or MAF. do they make kits to convert them?
'83 elCamino. steel crank kieth black forged pistons, pete jackson timing gears, VooDoo cam, World products votrec clone heads, Brodix intake, full msd ignition with Sniper nitrous wet shot system. built vette 700r4 with 2800 stall. 4.11 spooled rear end.
Its aways the second mouse that gets the cheese.
  #11
Old 12-04-2010, 08:50 AM
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
They do make a carburated intake, both GM and Edelbrock make them. My question is why would someone want to use old tech on a new tech engine?
  #12
Old 12-04-2010, 06:59 PM
ssr71's Avatar
Year: 1972
Region: 4 (MD,VA)
NECOA #: 13902
Quote:
Quote:
And GM also produces a complete new front timing cover that contains a distributor drive, so you can convert it over to "old tech". This topic's been covered before (sudden recollection that I had posted the part numbers for that dizzy drive stuff before).
http://www.elcaminocentral.com/showthread.php?t=33718&
  #13
Old 12-06-2010, 07:32 AM
jarhead's Avatar
Year: 1987
Region: 13(TX)
NECOA #: 11248
I just like the carb's better because i'm more familiar with them. I guess i need to stretch myself and learn more about the EFI system or just build a regular engine instead. Not sure if I want to take the time to learn about all of the items that go into making the EFi and computer controlled devices work. My 87 Elky has the electronic carb and i'm thinking about switching it to a regular carb. Not that i'm lazy, it's just easier for me to work on. Just sayin...
  #14
Old 12-06-2010, 11:01 AM
old_coot old_coot is offline
Year: 1983
Region: 9 (IN,KY,MI)
NECOA #: 3943
old_coot has a spectacular aura about
+2 why take one step forward and two steps back? I'm 63 years old and so I know a bit about carbs but I'll never own another one. With the controls and speed a computer had retune an engine---it can save one a lot better than lifting your foot when things go wrong. Plus the drivability factor being so much better. ....Dan
I don't think I have ever had a car that was "FINISHED"........unless it was totaled.
  #15
Old 12-06-2010, 11:13 AM
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
I think if you went with FI engine you would be a lot happy with it and injoy driving it more. It would also get better gas mileage, start easiers, run better, and be cleaner runing.
You may not post new threads
You may not post replies
