Idiots's Guide - El Camino Central Forum : Chevrolet El Camino Forums
Old 04-22-2004, 03:49 PM
2-Elkys 2-Elkys is offline
Year: 1971
Region: 13(TX)
NECOA #: 1192
2-Elkys will become famous soon enough
Default Idiots's Guide
I have a 1971 Elky with 350 and the old points ignition system.
I would like to upgrade to a HEI system.
i NEED the Idiot's guide to doing this a step by step procedure and all the needed parts to change.
Sure someone can help..
71-Elky
Work in progress.. Me and my ElkY!
Old 05-08-2004, 11:50 PM
dwindham dwindham is offline
Year: 1974
Model: El Camino SS
Region: 13(TX)
NECOA #: 2730
dwindham will become famous soon enough
Garage
put me down for the same thing but on a 74 with a sb400
Old 05-09-2004, 02:07 AM
greasy5thwheel greasy5thwheel is offline
Member
Loose Nut
NECOA #: 1737
greasy5thwheel will become famous soon enough
1st generation HEI distributor. it will still have a vacuum advance cannister on it. only takes 1 wire to hook it up. full 12 volts with no resistor if i remember right. hope this helps.
easier to laugh than cry, pass the bandaids !
Old 05-10-2004, 04:37 PM
Rick's Avatar
Rick Rick is offline
Year: 1972
Model: El Camino Classic
Region: 13(TX)
NECOA #: 149
Rick is a jewel in the rough
For some basics try this: http://www.chevelles.com/techref/ftecref5.html
The physical removal & replacement of the distributor is the hardest part.
1- Rotate motor to TDC with #1 firing. Make sure that the timing mark on the damper is about 5 degrees before TDC.
2- Remove Dist Cap & wires. Leave wires attached to plugs so you have easy guide for reinstallation. But realize that you will need a different set of wires - so buy them before you start .
3- Put a chalk mark on the intake manifold to mark where the rotor is pointed. Does not have to be exact, but close so you can start car later. Generally if you are looking down from the top, with #1 firing, the rotor will be at or about 7 o'clock. DO NOT ROTATE MOTOR from here on out.
4- Remove distributor hold down bolt. Pull dist staight up & out. As you pull the distributor out (the first inch or so) you will note that the rotor is turning backwards. Try to get an idea how much it turns. Try not to rotate the shaft yourself.
5-Once you get dist out, look at the bottom. Note that the bottom of the shaft looks like this (I) the I fits into a groove on the oil pump below. (This is what drives the oil pump.) Note the relationship between the (I) and the rotor.
5- Also note the gear at the bottom of the shaft. The teeth are beveled and this is what caused the rotor to rotate in step 4. Use a good flashlite to look down in the distributor hole - don't drop anything Note the groove on top of the oil pump where the dist matched up.
6- Now you are ready to install the new distributor. Try to align it like the old dist. With the rotor & (I) in the same general relationship. Lower the dist into its hole. As the gear on the bottom of the shaft starts to mate with the gear on the cam, the rotor will rotate slightly. You want it to end up in the same relative position as your original dist. So you may need to pull it out and rotate backwards and try again.
7 - It may not seat all the way once its in,DONT force it. Usually this happens cause the (I) on the dist is not aligned with the (I) on the oil pump. At this point you can rotote the motor slowly. Put slight pressure on top of the HEI as you rotoate motor by hand or by ignition. The rotor should rotate as soon as you start moving the motor. Within 180 degrees of rotation the HEI should "DROP" into place. STOP NOW! You don't want the HEI to jump back out of the oil pump groove.
8 - Install hold down bolt so its snug. Now its time for electrical hookup.
9- An HEI wire is available here: http://www.centechwire.com/Merchant4...uct_Code=HEI-1 or at many autoparts stores or get one from the junk yard.
10- The wire will connect to the B+ (or BAT) connection on the side of the HEI Cap. The other end will go to a connection that is HOT (12 Volts) when in both the crank & run position of your key. I went to the IGN post on my fuse box. The wire from the fuse box to the HEI cap should be 12 gauge or so. You will not need the original wires that come from your starter.
11- Try a google search I found this site: http://www.oldengine.org/unfaq/hei.htm and there are probably many others that explain it better than I. Maybe have pictures too.
I'm typed out , good luck.....Amnd what is this a TEXAS only post????
Rick Schaefer
72 TPI El Camino
Old 05-10-2004, 06:08 PM
Year: 1974
Model: El Camino SS
Region: 13(TX)
NECOA #: 2730
Garage
good info. Guess it is just us Texans in here.
Old 05-10-2004, 06:30 PM
Year: 1971
Region: 13(TX)
NECOA #: 1192
Thanks for the info i have done distrib swaps before points type so i uderstand that part. The different wires and coil needed is the part i was in the dark about.
Old 05-10-2004, 09:58 PM
Iceman Iceman is offline
Member
Knuckle Buster
NECOA #: 520
Iceman will become famous soon enough
Very good instructions! I have nothing to add to this and I don't want to. I'm just another Texan with a HEI equipped 3rd Gen.
Gudmundur Eyfells.
'68 El Camino
'69 El Camino
'04 Dodge Dakota
"I don't know where I'm going but they'll tell me when I get there."
  #8
Old 05-10-2004, 11:47 PM
elcamino74guy's Avatar
elcamino74guy elcamino74guy is offline
Year: 1974
Region: 15(AZ,NM)
NECOA #: 2321
elcamino74guy will become famous soon enough
THat was a good set of instrucitons. When I did mine on my 74 the one thing I had to make sure of was to get rid of the resistor wire (which was mentioned in the instructions )that actually feeds the distributor. Mine didn't have a resistor block it actually used a resistance piece of wire that I had to remove all the way back to the power block on the firewall.
Make sure the BAT wire gets a full 12V and you should be fine. No resistor blocks either. It's a lot cleaner install too.
74 El Camino Classic - project car #1
95 Pontiac Firebird Formula - Project car #2
96 Camaro - RIP, Traded 10-16-2007
2008 Mustang GT - RIP, Sold 10-12-2013 (Was the Elky or the 'Stang, Whaddya think I'd choose!)
  #9
Old 05-11-2004, 12:13 AM
Member
Loose Nut
NECOA #: 1737
hey rick! give me a holler. i am just out here in merkel. be nice to meet another elky nut. 725-0353. also, to all the rest of the texans out there watching, you need something give me a shout. might be laying on the yard. lol. bob
  #10
Old 05-11-2004, 12:53 AM
Year: 1974
Model: El Camino SS
Region: 13(TX)
NECOA #: 2730
Garage
anyone have a source for 4th gens at salvage yards? I may be needing a driver door, fender, and possibly front windshield. Thanks.
  #11
Old 05-11-2004, 10:28 AM
Member
Loose Nut
NECOA #: 1737
i might have a lead on some pieces like that. when you figure out what you need give me a shout. i'll see what is still available and shoot you some pics. i'm dealing in 5th gen myself but do have access to a little bit of stuff for the 4th genies. let me know.
  #12
Old 05-11-2004, 10:52 AM
Year: 1974
Model: El Camino SS
Region: 13(TX)
NECOA #: 2730
Garage
Well I'm pretty sure the door will need to be replaced. It got hit hard enough to form the outer sheet metal around the inner supports. The front fender can probably be straightened I hope. I've found one door so far up in OK but they were wanting $250 for it. My door panels are good. Glass is ok but has some paint overspray on it and the weatherstriping has seen better days.
  #13
Old 05-11-2004, 02:13 PM
ElkyPete's Avatar
ElkyPete ElkyPete is offline
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
ElkyPete is just really nice
Lots of yards in Ft. Worth to pick and choose from. Little Johns, Sargent's Auto Salvage and several along Business 287 (Mansfield Hwy.)
Home Site:
1972 El Camino Custom 400
1976 El Camino Classic
1980 El Camino Super Sport
E-Mail:
  #14
Old 05-11-2004, 03:22 PM
Year: 1974
Model: El Camino SS
Region: 13(TX)
NECOA #: 2730
Garage
thanks for the names. I'll have to give them a call and see if they have any 4th gens out there
  #15
Old 05-12-2004, 07:23 PM
Nailhead Nailhead is offline
Member
Knuckle Buster
NECOA #: 1579
Nailhead will become famous soon enough
One non-Texan chiming in. Remember also to get the full benefit from the HEI you can run wider gaps on the plugs. Set to similar for the year you took the HEI out of. It will definitely start and run better on cold mornings.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
The Wheel Buying Guide JimMayor007 General BS Topics 1 08-29-2007 06:00 PM
Restoration book / guide for 1964 64Lcamino General BS Topics 2 08-02-2007 08:47 PM
5th Gen Elky Spotters Guide Ehlien General BS Topics 3 05-16-2006 11:41 AM
Classic car value guide a73elkyss General BS Topics 6 03-11-2006 07:17 AM
ultimate elky guide? i_have_no_legs General BS Topics 7 11-06-2004 10:52 AM
