Need headliner for 1980. - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-21-2011, 02:56 PM
Jack_K's Avatar
Jack_K Jack_K is offline
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Jack_K is a name known to all
Default Need headliner for 1980.
Prefer black, but could dye it.
Jack
Old 01-21-2011, 03:00 PM
stev6343 stev6343 is offline
Year: 1982
Region: 5 (NC,SC)
NECOA #: 14194
stev6343 has a spectacular aura about
A good local body shop can do this on the cheap (~100)
Old 01-21-2011, 03:18 PM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead has a reputation beyond reputejarhead has a reputation beyond repute
I bought my headliner (ABS) from OPGI along with all of the clips for $220. It was a perfect fit and while the upholstery shop would do it for $150, I did not have the old headliner. It was broken and would not hold its shape. with the headliner I bought I never have to worry about the cardboard getting wet or cracking on the corners. It took 3 days from the time I placed the order til I installed it. No down time because my car was never in the shop. Perfect color also. And no, I do not work for OPGI, I'm just refering them because I got exactly what I wanted and have bought alot of items from them before and after.
1987 El Camino, aka Harper's cruck
1983 El Camino S
Dang, I miss Ronald Reagan
more and more every day..
Old 01-22-2011, 03:15 PM
Jack_K's Avatar
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Thanks. Now, what's OPGI?
Jack
Old 01-22-2011, 04:35 PM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
http://www.originalpartsgroup.com/
There you go.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 9 and really haven't had to work on it this year.
Link to Garage:
Old 01-22-2011, 05:13 PM
thundercat2's Avatar
thundercat2 thundercat2 is offline
Year: 1978
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 12606
thundercat2 has a spectacular aura about
also try dixie monte carlo depot. got mine for 165.00
ron
My church is the open road...just me,God,and the highway
Old 01-23-2011, 04:10 AM
DON BLACK's Avatar
DON BLACK DON BLACK is offline
Motor Mouth
Year: 1979
Model: El Camino SS
Region: 6 (FL)
NECOA #: 17449
DON BLACK will become famous soon enough
Try a regular auto upholstry shop. The shop I use charges me pnly $50. I had 2 Buick Reatas and a Chevy PU single cab done for 50 .
  #8
Old 01-23-2011, 07:25 AM
kyle_1979 kyle_1979 is offline
Year: 1979
Model: El Camino SS
Region: 12(MO,OK,KS)
NECOA #: 18332
kyle_1979 has a spectacular aura about
I paid 75 for mine at a local upholstery shop, and it only took them about an hour. (Most likely they will be excited to do one for an el camino instead of any other G body).
'79 El Camino SS factory 4 speed
'85 Choo Choo El Camino SS
'84 Monte Carlo SS 60k miles
'73 Camaro Type LT RS Z28
'73 Chevelle SS 454 Wagon
'73 Chevelle Laguna Estate Wagon
  #9
Old 01-23-2011, 04:37 PM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan has a reputation beyond reputedarbysan has a reputation beyond reputedarbysan has a reputation beyond repute
Farily easy DIY project, once you get the headliner out. You can buy fabric on line, or even at a local JoAnn Fabrics. Cost of Fabric is about $15, plus a can of adhesive $8. Scrape, Clean, Spray and Roll out the fabric. Trim the edge and re-install. Most ofo the cost at the upholstry shop is getting the headliner out and in. Also, expect to have to replace some of the clips- they are getting old and will likely break when trying to remove.
If you are ambitious, you can use the same material to recover your visors. Ask if you want more info.
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
  #10
Old 01-23-2011, 05:42 PM
Jack_K's Avatar
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Unfortunately the hardboard is all cracked and broken. If it were in good shape I'd do that.
  #11
Old 01-23-2011, 10:10 PM
'81ELKYSS's Avatar
'81ELKYSS '81ELKYSS is offline
Year: 1981
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 11486
'81ELKYSS will become famous soon enough
I got mine from OPGI as well, took me 20 mins to install and looks way better! The cloth looks better to me as well.
1981 SS 355 vortec motor. 3.73 gears. A lot done to it.
  #12
Old 01-24-2011, 06:22 AM
EdontheBeach's Avatar
EdontheBeach EdontheBeach is offline
Year: 1986
Region: 6 (FL)
NECOA #: 3688
EdontheBeach will become famous soon enough
National Parts Depot - same product, less expensive. be careful removing the clips or get some new ones before you start. mine took about 45mins
EdontheBeach
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
