Positive Traction - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-02-2011, 04:13 PM
gman gman is offline
Member
Twisted Wrench
Year: 1985
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 12922
gman will become famous soon enough
Default Positive Traction
Can anyone tell me if a unit out of a S 10 will fit a 1985 El Camino
Old 03-02-2011, 05:16 PM
zach01s's Avatar
zach01s zach01s is offline
Year: 1983
Region: 15(AZ,MN)
NECOA #: 17821
zach01s will become famous soon enough
Yes. as long as theyre both the 7.5 (both elcaminos and s10s ran other size diffs but the most common were 7.5)
is it a factory s10 posi carrier youre looking to install? if its the factory one that will be a gov-lock unit and theyre weak and prone to breaking. not worth the install in my honest opinion. even when theyre working they stay unlocked more than they lock while driving.
if you want something worth putting in thats real posi look to 3rd gen V8 z28 and iroc camaros, some of them had a real clutch type posi carrier that parts interchange with g-body diffs in
'83 elCamino. steel crank kieth black forged pistons, pete jackson timing gears, VooDoo cam, World products votrec clone heads, Brodix intake, full msd ignition with Sniper nitrous wet shot system. built vette 700r4 with 2800 stall. 4.11 spooled rear end.
Its aways the second mouse that gets the cheese.
Old 03-02-2011, 06:55 PM
Yeast1's Avatar
Yeast1 Yeast1 is offline
Year: 1986
Model: Conquista
Region: 15(AZ,MN)
NECOA #: 15570
Yeast1 has a spectacular aura about
X2 on not using the S10 unit. If the Monte Carlo SS and Malibu folks aren't running them, then chances are they are not good.
Craig
Old 03-02-2011, 07:28 PM
Flaminmeano's Avatar
Flaminmeano Flaminmeano is offline
Year: 1978
Region: 14(AR,LA,MS)
NECOA #: 7482
Flaminmeano will become famous soon enough
Waste of Dinero
385 stroker, brodix, weiand super charger,
6' in rods, predator roller cam, duration 238 int
246 exh, lift 576 int / 592 exh, jackson gear
drive, compcams roller rockers 1.6, afterburner
headers, 3' in exhaust with x-pipe, 700r4 trans
and the latest addition; a winters quickchange rearend
Old 03-02-2011, 07:29 PM
Member
Twisted Wrench
Year: 1985
Model: El Camino SS
NECOA #: 12922
Thanks guys, a friend gave this one to me. I thought I'd try it since it is free, still looking for a better one.
Old 03-02-2011, 07:43 PM
Yeast1's Avatar
Year: 1986
Model: Conquista
Region: 15(AZ,MN)
NECOA #: 15570
We are all about 10 years too late for easy swaps. All the GM posi units for G bodies got snatched up and now we are basically buying $1000 Monte Carlo/ Buick GN hand me downs or going $2000 and hopping over to Moser and the specialists. You can stuff a nice Auburn unit into your stock rear unit and choose your ratio and know the rear end will fit.
Craig
Old 03-03-2011, 02:11 PM
DOUG213XRJ's Avatar
DOUG213XRJ DOUG213XRJ is offline
Year: 1978
Region: 9 (IN,KY,MI)
NECOA #: 13817
DOUG213XRJ has a spectacular aura about
I would run that posi. GM had two posi units, One is a Auburn cone style and one is a eaton Gov-lok style. Any one of them would be a good upgrade over the stock one wheel peel. Youll need one with 26 axle splines from a pre 1988 S10/15, Camaro/firebird, also GM minni vans.
78 El camino
79 Malibu (sold)
81 Malibu
  #8
Old 03-05-2011, 05:36 AM
David Dunbar's Avatar
David Dunbar David Dunbar is offline
Member
Twisted Wrench
Year: 1985
Model: El Camino SS
NECOA #: 15073
David Dunbar will become famous soon enough
The Eaton unit will work fine if you're not trying to jam 500 hp down on it.
  #9
Old 03-05-2011, 09:27 AM
wild bill wild bill is offline
Motor Mouth
Year: 1985
NECOA #: 6112
wild bill will become famous soon enough
Does this mean the S-10 rearend bolts into the elcamino?
Or does it mean the S-10 carrier bolts into the stock elcamino rearend housing?
They think I'm going through my second childhood but I'm not through my first one yet.
  #10
Old 03-05-2011, 12:58 PM
DOUG213XRJ's Avatar
Year: 1978
NECOA #: 13817
The complete S10 rear end will not bolt in to a G-body, Becouse the S10 uses leave springs and the G-body uses coil springs. The S10 Carriers (posi) with 26 spline axles will bolt in to the G-body rear end. The Gears from all the S10's will bolt into the G-body rearend if used with the right carrier. ( 2 series and 3 series). Doug
  #11
Old 03-05-2011, 02:43 PM
fixitman1's Avatar
fixitman1 fixitman1 is offline
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
fixitman1 has a reputation beyond reputefixitman1 has a reputation beyond repute
Buy you some Richmond Gears to Fit the Carrier ... your stock gears wont fit on the S10 locker With a 3 series Carrier Just Did the Same Swap went with 323 Richmond
  #12
Old 03-06-2011, 12:49 PM
DOUG213XRJ's Avatar
Year: 1978
NECOA #: 13817
I would use the gears that come with the S10 posi, If there is no Gears then find some gears at a local salvage yard, here or Ebaymotor.com . Doug
  #13
Old 03-09-2011, 09:33 AM
Motor Mouth
Year: 1985
NECOA #: 6112
Default Thanks for the info
This thread caught my eye when I posted my 3.73 posi for sale.
I am going back to the elcamino's original rearend I kept in storage.
The 3.73 really woke up the '85 elcamino with 700R4 and mild goodwrench 350. I can easily break traction through the first 3 gears. But at 64 years old I am going to start conserving rubber.
With this thread's info, I'm considering a mid-range ratio S-10 carrier for my stock 2.41 if I can find one for a reasonable price at the bone yard.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Rear Carrier Positive I.D. Dinosdad Transmission & Drive line 2 09-22-2010 06:51 PM
Positive batt cable pigtail -- what is it for? Pete Electrical Systems 9 01-03-2008 08:00 PM
Positive and negitive garage sale feedback forum? UnclesCamino General BS Topics 1 09-16-2007 01:22 AM
Hot positive terminal at battery maineman Electrical Systems 4 06-17-2006 07:20 AM
positive identification ElCafreak Tips & Tricks 2 05-14-2004 08:59 PM
