Tire Size Question - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-22-2011, 03:35 PM
webbd's Avatar
webbd webbd is offline
Year: 1986
Region: 16(CO,MT,WY,UT)
NECOA #: 12929
webbd will become famous soon enough
Default Tire Size Question
I was at Discount Tires the other day where I usually buy tires. I am going to need some new summer (all season) tires and I gave them my size of P205/75/R14. I have stock rims. The tire people said that I should go with a P215/70/R14 because that wouldn't wear out as fast on the sides. They seemed to think that the 215/70s could handle the car's weight better in corners than the stock size of 205/75. Any opinions here? Would that mess with the speedometer readings?
Thanks,
David
P.S. It's an 86 with the 305 and stock rims.
Old 03-22-2011, 03:50 PM
rgraboske's Avatar
rgraboske rgraboske is offline
Deputy Director Region 9 (MI-IN-KY)
Year: 1983
Model: Caballero
Region: 9 (IN,KY,MI)
NECOA #: 4460
rgraboske will become famous soon enough
Garage
I personally prefer a little bigger tire than was specced from the factory. I've upsized the tires on all of my cars for years.
That said, looking at an online calculator http://www.miata.net/garage/tirecalc.html, The size they recommend will be a little taller (25.9" vs 25.3"), and a little wider. You speedometer may read a little slow (2.2% per the calculator).
As long as the price is similar, I wouldn't hesitate to go with the 215/70s
Old 03-22-2011, 03:52 PM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
Quote:
Thanks,
David
David, go to this website http://www.1010tires.com/tiresizecalculator.asp. They have a calculator that's easy to use. Just input the 2 tire sizes and it will give you a comparison that includes tire diameter. I hope this helps you out.
Mike
JBoz396's Avatar
JBoz396 JBoz396 is offline
Junior Member
Twisted Wrench
Year: 1967
Region: 6 (FL)
NECOA #: 18697
JBoz396 will become famous soon enough
According to the Tire Rack website, the 205/75/14 is 26.1" tall, and the 215/70/14 is 25.9" tall. That is a difference of 0.2" or less than 1% of the total height. Based on that, I would say your speedometer will not be affected by much if at all.
The difference in performance will be in the increased tread and section width. The sidewall height will be very close, roughly 0.1" per side. More rubber on the road is always good in my opinion.
If it were mine, I'd go for it.
1967 El Camino
L35 396, TH400
Old 03-22-2011, 03:59 PM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
Hell, that's a couple of good burn-outs worth! Get the 70's :>)
Old 03-22-2011, 05:29 PM
webbd's Avatar
Year: 1986
NECOA #: 12929
Sweet thanks for the info! I'll go for the 215s this summer then when I get the snows off!
Old 03-22-2011, 05:32 PM
rgraboske's Avatar
Year: 1983
Model: Caballero
NECOA #: 4460
Garage
Crap, I put the wrong sizes in when I did my calculation
You may not post new threads
You may not post replies
Tire size question. . . ChevelCamino Suspension & Steering 1 11-15-2006 05:35 AM
tire size thewayofdouce Body Restoration 3 02-20-2005 05:53 PM
tire size fulanoderock Suspension & Steering 0 09-09-2004 09:58 PM
tire size crash landing Suspension & Steering 3 06-04-2004 02:15 PM
What size tire? Chris85 Transmission & Drive line 13 05-24-2003 06:31 AM
