Factory ground strap locations - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-31-2011, 08:35 AM
swangin50's Avatar
swangin50 swangin50 is offline
Motor Mouth
Year: 1978
Region: 12(MO,OK,KS)
NECOA #: 17542
swangin50 will become famous soon enough
Default Factory ground strap locations
Can anyone tell me where the factory ground straps are located? I'm doing a custom build and it didn't have a motor so I don't know exactly where they were orginally. Also where did the negative on the battery go? Just want to try to get that back to the way it was orginally, Thanks!
Old 03-31-2011, 10:49 AM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack has a reputation beyond reputeBillyJack has a reputation beyond repute
Garage
Originally, the negative battery cable went to the alternator bracket. I relocated mine to one of the unused front motor mount bosses, next to the fuel pump. There was also a branch line that went to the battery cable end to the fender. As far as ground straps, just make sure you have the engine grounded to the chassis, as well as chassis to body. Also, make sure you have a good ground to the blower motor, as it sits in a plastic enclosure.
Bill
Old 03-31-2011, 11:14 AM
swangin50's Avatar
Motor Mouth
Year: 1978
NECOA #: 17542
Thanks Bill, I will do that.
Old 03-31-2011, 12:07 PM
Terminator's Avatar
Terminator Terminator is offline
Heavy Wrench
Year: 1982
Model: El Camino SS
Region: 13(TX)
NECOA #: 16783
Terminator will become famous soon enough
You can use 2 ground straps for your engine, and also run a #12 ground wire from the negative post terminal to the inner fender. (Some neg. battery post come with this #12 wire molded in to the terminal. Just use an extension with and "eye" connector and splice connector).
Hasta la vista, Baby!
________1982 El Camino SS Custom_________
________2005 GTO Performance Ed.________
Old 03-31-2011, 12:52 PM
gilby's Avatar
gilby gilby is offline
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
this is how the grn strap is on my Elky...
First,the batt. ground inner fender well..
second,engine ground,BATT. to alt.
third,ground to body...
on "some" models, they will have a ground strap running between the frame and body... (NOT PICTURED)
hope this helps ya out..
ID:	1150   Click image for larger version
ID:	1151   Click image for larger version
ID:	1152   Click image for larger version
ID:	1154   Click image for larger version
..1974 Conquista
..1979 GMC Caballero
..2003 Impala
..2015 Spark
Old 03-31-2011, 02:07 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
Thanks for putting some pics up Gilby. Saves a lot of typing !
Old 03-31-2011, 07:14 PM
swangin50's Avatar
Motor Mouth
Year: 1978
NECOA #: 17542
Thanks for all the pictures, that helps out a lot!
  #8
Old 03-31-2011, 07:19 PM
zach01s's Avatar
zach01s zach01s is offline
Year: 1983
Region: 15(AZ,MN)
NECOA #: 17821
zach01s will become famous soon enough
isnt one ground strap from the back of the passenger head to the firewall? as long as you have a ground between the batt cable to the block and a strap to the fender, block to firewall, and if you deem fit block to frame youll be fine.
running your main battery cable from the neg batt post straight to the engine somewhere is the best idea. i prefer to go under the long bolt the alternator hinges on going into the head because it serves a few functions: i know its grounded to the block, it looks cleaner and keeps the soldered eye on the end of the cable a little further away from the heat of the block ( thats why gm put it on the alt. bracket.).
Heat kills electrical connections over time.
'83 elCamino. steel crank kieth black forged pistons, pete jackson timing gears, VooDoo cam, World products votrec clone heads, Brodix intake, full msd ignition with Sniper nitrous wet shot system. built vette 700r4 with 2800 stall. 4.11 spooled rear end.
Its aways the second mouse that gets the cheese.
  #9
Old 04-01-2011, 02:11 PM
gilby's Avatar
Year: 1974
Region: 18(CA)
NECOA #: 10426
Garage
Quote:
well,you know..!! A picture is worth a 1,ooo words...!
  #10
Old 04-04-2011, 07:47 AM
TRIK-56 TRIK-56 is offline
Year: 1982
Model: Conquista
NECOA #: 603
TRIK-56 will become famous soon enough
Tell me if you guys think these ground connections I have are OK. Everything seems to work fine but I'm just curious.
My neg. cable has the small ground to the fender as Gilby pictureed but the neg. batt. cable is grounded to a bolt on top of the FRAME near the fuel pump instead of the alt. bracket. I then put another ground cable from that same frame bolt to the engine block.
Does anyone see anything wrong with this plan?
Bobby
56 Chevy 2-door sedan
82 El Camino Conquista
  #11
Old 04-04-2011, 08:48 AM
gilby's Avatar
Year: 1974
Region: 18(CA)
NECOA #: 10426
Garage
yes,you want the big cable on the block,why..?? because of the amprage the starter draws from the battery,if you put it on the frame,you will fry the little ground wire up because it can't handle the amprage from the Battery when you start the engine.and remember,everything sits on a rubber mounts,the engine frame and body,so, hook it up correctley and you won't have a meltdown..
  #12
Old 04-04-2011, 09:10 AM
Year: 1982
Model: Conquista
NECOA #: 603
Thanks for that info Gilby! I'm not disputing your word at all and I'm certainly no wiring guru but I just thought that since the battery cable that goes to the bolt on the frame is also the same bolt the cable from the engine block goes to it would almost be the same thing as running the battery cable to the block since those two cables are touching each other on the ends where they are both attached to the same bolt. Is that incorrect?
Its been this way for several months now and nothing has fried. Have I just been lucky or would this take quite some time to get things in a melt down state as you mentioned?
  #13
Old 04-04-2011, 10:01 AM
goodcruiser goodcruiser is offline
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
goodcruiser is a glorious beacon of light
Quote:
Gilby has it right it comes down to resistance,the more resistance you have the higher the amperage draw,so you really want that ground on the engine for the starter.It also helps with sensors and alternator function.I'm not sure if they put it on the alternator bracket to avoid cable degeneration or more for ease of assembly since the cables haven't been soldered from the 40's or 50's and went to a mechanical crimp.
I have never seen a problem with too many grounds but have seen problems with improper placement and or use of the wrong gauge wire and not enough grounds because you have wiring harness grounds going to the frame and the body and sensors using the engine for ground so that gauges and computers can get the information that they need to operate.A good example of this is several postings on here where members removed the dash on 5th gens and forgot to reattach the ground to ebrake bracket and the gauge cluster doesn't work right.That doesn't mean a thousand ground straps are better because at a certain point more will not help it just becomes overkill.
  #14
Old 04-05-2011, 06:44 AM
Year: 1982
Model: Conquista
NECOA #: 603
Goodcruiser and Gilby,
Hey, thanks guys for your info. I do appreciate it!
  #15
Old 04-05-2011, 08:51 AM
Jack_K's Avatar
Jack_K Jack_K is offline
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Jack_K is a name known to all
Yes, that's correct, as long as both cables are of sufficient wire size and you have a good connection between them at the frame mounting point.
As far as resistance goes, having two cables in series might add a small fraction of an ohm. As long as you have no problem turning the starter over in cold weather, you'll be fine.
Jack (electrical engineer)
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Looking For 2 , Door Pull Strap Covers , See Picture Magicacorn Wanted Items 4 10-05-2010 07:29 PM
engine ground strap affecting performance? '81ELKYSS Engine Topics 21 03-02-2010 04:24 AM
86 Glove Box Strap? butch049 Interior Restoration 3 12-30-2008 12:48 PM
Where is ground strap? worldrallyoffrd Electrical Systems 2 08-24-2004 08:45 PM
Door Strap Ends elmpala Interior Restoration 1 06-26-2003 06:51 PM
