rolling in park - El Camino Central Forum : Chevrolet El Camino Forums
Old 04-16-2011, 08:38 PM
1974ElCamino 454 ss's Avatar
1974ElCamino 454 ss 1974ElCamino 454 ss is offline
Motor Mouth
Year: 1974
Model: El Camino SS
Region: 21(CANADA (W. of ONT.))
NECOA #: 19105
1974ElCamino 454 ss will become famous soon enough
Default rolling in park
my t/400 transmission works great in all the gears but as soon as i put it into park i can roll the car forward and back, does the whole trans need pulled apart to replace the parking pin or is they're another option?
Old 04-16-2011, 08:59 PM
Flaminmeano's Avatar
Flaminmeano Flaminmeano is offline
Year: 1978
Region: 14(AR,LA,MS)
NECOA #: 7482
Flaminmeano will become famous soon enough
Try adjusting the linkage first, remove the arm and ensure its in park before you take it apart
385 stroker, brodix, weiand super charger,
6' in rods, predator roller cam, duration 238 int
246 exh, lift 576 int / 592 exh, jackson gear
drive, compcams roller rockers 1.6, afterburner
headers, 3' in exhaust with x-pipe, 700r4 trans
and the latest addition; a winters quickchange rearend
Old 04-16-2011, 10:40 PM
74 chick's Avatar
74 chick 74 chick is offline
Year: 1974
Model: El Camino Classic
Region: 17(S.CA,S.NV)
NECOA #: 8960
74 chick will become famous soon enough
Sounds to me as if it never gets to park.
Put the shifter in park and block the tires.
Jack up front and put on stands leave key in so you can move shifter
have 1/2 in & 9/16 with you.
Slowly take the bolt that holds the shift rods in place loose (not off)
put on transmission side to till it stops
tighten bolt check for park.
Being out of work sucks
There's no substitute for cubic inches.
(Snake Eyes)
Thank a vet
Old 04-17-2011, 05:58 AM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack will become famous soon enough
The park mechanism of a TH400 is very simple and not usually prone to failure. The likely problem is a bind or obstruction in the shifter or linkage that doesn't allow the shift lever(the link on the side of the trans) to cycle completely into the park position. Removing the pan will expose the entire park mechanism. No removal or disassembly of the trans required.
Bill
You may not post new threads
You may not post replies
1980 Rolling project borjawil Parts for sale 0 11-05-2010 08:32 AM
Fender rolling? 82lko Body Restoration 5 07-27-2010 03:01 AM
Getting the ball rolling! Richp85ElCO Body Restoration 18 03-04-2010 10:53 PM
Rolling Fenders? OCTO13ER Suspension & Steering 4 01-25-2008 10:47 AM
Rolling Fenders GoGoPWR Suspension & Steering 4 10-18-2005 10:39 AM
