How to remove control arm bushings? - El Camino Central Forum : Chevrolet El Camino Forums
Old 04-22-2011, 11:28 AM
Jack_K's Avatar
Jack_K Jack_K is offline
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
Jack_K is a name known to all
Default How to remove control arm bushings?
I need to replace the bushings in my front and rear control arms. None of the auto stores has a loaner tool for that.
Any advice on how to remove and replace the bushings?
Jack
Old 04-22-2011, 11:39 AM
philipsr24's Avatar
philipsr24 philipsr24 is offline
Member
Knuckle Buster
Year: 1984
Region: 17(S.CA,S.NV)
NECOA #: 16631
philipsr24 will become famous soon enough
i did my upper they came out with a pipe wrench and a lil back and fourth motion came out easy enough but (this is just me)and putting the new ones in i used a socket big enough to cap the rubber but small enough to stay on the flange that my hurt somthing in shape but the rite way to do them is have them pressed in my mechanic said like 40$ for each arm and that was bringing them to him with a arms off the car and the old bushings taken out
84 el camino 350 (running project)
85 gmc caballero(impounded and auctioned)
DOUG213XRJ's Avatar
DOUG213XRJ DOUG213XRJ is offline
Year: 1978
Region: 9 (IN,KY,MI)
NECOA #: 13817
DOUG213XRJ has a spectacular aura about
I just replaced the rear control arm bushing in my 78 El Camino. I used a air hammer/chisels to remove them and a big hammer to install them. I have heard of a few people using a lower ball joint press tool to remove them. You could find a shop/garage in your area with a press and see if they will press them in and out. Doug
78 El camino
79 Malibu (sold)
81 Malibu
Old 04-22-2011, 11:41 AM
philipsr24's Avatar
Member
Knuckle Buster
Year: 1984
NECOA #: 16631
i forgot to add that i hammered them in with the socket but thats just me but so far they feel ok
Old 04-22-2011, 12:43 PM
buzz buzz is offline
Motor Mouth
Year: 1978
Region: 8 (OH,WV)
NECOA #: 16397
buzz will become famous soon enough
I used to do them everyday before a tool was made for them by holding the control arm upright on the end of an anvil and striking it with a BFH 4 to 5 strikes and their out, and like said before use a socket to pound them back in. I later bought the tool and I can still install them quicker without it.
Old 04-22-2011, 01:26 PM
M Zeigler's Avatar
M Zeigler M Zeigler is offline
Year: 1972
Model: Sprint
Region: 16(CO,MT,WY,UT)
NECOA #: 17119
M Zeigler will become famous soon enough
Garage
The easiest way I have removed teh front control arm bushings is to secure the control arm in a vise, the use an air chisel with about a one inch flat blade bit in it, work your way around the bushing so it come sout fairly even, press the new ones in on a press.
I have used 3/4 inch drive sockets on both sides to press the new ones in when the proper tool wasn't availible. Don't forget the safety glasses and ear plugs, it gets rather noisey doing them this way but it is fast.
Mike
Old 04-22-2011, 01:43 PM
welder5's Avatar
welder5 welder5 is offline
Name: Matt & Amy
Year: 1985
Region: 6 (FL)
NECOA #: 12463
welder5 is a jewel in the rough
Garage
I just did mine last week
I took a sawzall an cut thru the bushings on the inward side of the control arms, then I poped out the ring that was left with a screwdriver an hammer. Putting back in, I used a little grease an a BFH. Just like that there in... Good luck
1985 Chevy El Camino LQ9 6.0L Tremec TKO 600 5 speed 13.8 at Gainesville Raceway
1999 chevy Tahoe
2005 toyota Camry
Auto to manual trans swap
  #8
Old 04-22-2011, 04:02 PM
zach01s's Avatar
zach01s zach01s is offline
Year: 1983
Region: 15(AZ,MN)
NECOA #: 17821
zach01s will become famous soon enough
using a chisel and a sledge hammer cave the iold one in a bit so it comes out, then just press them back in with a bottle-jack press.
ive also replaced the uppers with the front control arm in place on the car, use the shaft they pivot on and some extra washers under the nut, tighten it in while you wiggle the a-frame untill it centers itself then tap on the a-frame around the bushing with a normal ball-peen and run the nut down. pull the extra washers then re run down the nut.
'83 elCamino. steel crank kieth black forged pistons, pete jackson timing gears, VooDoo cam, World products votrec clone heads, Brodix intake, full msd ignition with Sniper nitrous wet shot system. built vette 700r4 with 2800 stall. 4.11 spooled rear end.
Its aways the second mouse that gets the cheese.
  #9
Old 04-22-2011, 06:24 PM
Jack_K's Avatar
Site Contributor
Year: 1980
Model: Conquista
Region: 13(TX)
NECOA #: 18056
You totally lost me with that one.
  #10
Old 04-22-2011, 06:36 PM
zach01s's Avatar
Year: 1983
Region: 15(AZ,MN)
NECOA #: 17821
upper control arms, front of the car. to replace the bushings without actually removing them from the car. you know the deal that bolts to the frame that you adjust the camber you put the shims under? its the bar the upper a-frames actually pivot on. you basically use it to draw the bushing in place by tightening the nut with a couple extra washers under the nut.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Rear control arm bushings Mrapii Suspension & Steering 19 12-15-2012 04:36 AM
Flaired Control Arm Bushings MEvang Suspension & Steering 3 09-17-2007 05:39 AM
lower control arm bushings. mk1264 Suspension & Steering 14 01-27-2007 09:41 PM
Replacing control arm bushings ipatrick69 Suspension & Steering 8 04-14-2005 03:47 PM
Rear control arm bushings Malice in Wonderland Suspension & Steering 5 06-05-2004 05:26 AM
