turbo 400 - El Camino Central Forum : Chevrolet El Camino Forums
Old 05-17-2011, 05:58 AM
nitroraptor2's Avatar
nitroraptor2 nitroraptor2 is offline
Junior Member
Gear Head
Year: 1987
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 14809
nitroraptor2 will become famous soon enough
Default turbo 400
I got my 1987 El Camino 2 years ago and it has a turbo hydro-matic 400 in it (Stamped into pan) I need to know 2 things the first being if the 1987 came with that, the second being what it cam out of because the shape of the pan does not match any in my shop manuals (I will post pictures when I get home tonight). It is possible that the old owner had it installed because he was using it to haul large trailers but I cant be sure.
thanks
nitroraptor2
My El Camino follows only one law...Murphy's law
Old 05-17-2011, 06:18 AM
baxter2w2 baxter2w2 is offline
Member
Twisted Wrench
Year: 1979
Region: 15(AZ,MN)
NECOA #: 19184
baxter2w2 will become famous soon enough
TH400 the pan looks kinda like the state of texas(shape anyways). the 87 should have come with an overdrive tranny. there is also no kick down/throttle valve cable on a th400, just a single wire on the side to control the psaaing gear. lastly the th400 has a large output shaft yolk compaired to a th350 or 700R4.
383,W/C T-5, lotta suspension work.
"IF YOU'RE NOT FIRST YOU'RE LAST!!!"
Old 05-17-2011, 06:29 AM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
Deputy Director, Region 18
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike is of outstanding character
That trans was a conversion at some time. It's one of the most durable trannys ever built, but it won't get you great gas milage. It came in cars with big block motors most of the time or a truck. The truck models had a "bolt-on" yoke, the cars had a slip yoke.
Mike
Old 05-17-2011, 09:08 AM
Junior Member
Gear Head
Year: 1987
NECOA #: 14809
that explains why I get bad gas mileage. is that tranny known to have slow acceleration from the line because I have an awful time trying keep up with traffic until it changes gears.
Old 05-17-2011, 11:41 AM
goodcruiser goodcruiser is offline
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
goodcruiser is a jewel in the rough
http://www.elcaminocentral.com/showthread.php?t=31362
The th400 does use more HP to make them go but they can be built to take the slip out and then it comes down to HP and rearend gear.It sounds to me that you have a bad match for what you want out of your vehicle.
If you know someone that has a set of tires one size smaller than yours on the rear that will fit see if you can borrow them then take a drive to see if you get an improvement in reaction.By going to a smaller tire you reduce the overall drive ratio,keep in mind this probably won't improve fuel mileage any but you should be able to offset it a little by not slamming your foot to the floor(I know thats no fun).The change in feel will be slight but it should give you direction of where you want to go.
Old 05-17-2011, 11:57 AM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
A 400 does use up about 25HP more to run it. That's probably why it feels like you don't have much get up and go. That's also why it's mostly used on big block motors. They have that extra power to run it better.
Old 05-19-2011, 07:05 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
The TH400 is also around 60 lbs heavier than a TH350, for example. So the extra weight and the power it soaks up make it more of a big block item.
AKA Pila
El Camino resto
The Malibu
  #8
Old 05-19-2011, 09:18 PM
centex396's Avatar
centex396 centex396 is offline
Year: 1970
Region: 13(TX)
NECOA #: 17362
centex396 is a jewel in the rough
This link might help you out. It shows the "typical" gear ratio for a given trans.
http://www.maliburacing.com/auto_tranny_id.htm
It takes alot of cheeze to feed a RAT
  #9
Old 05-19-2011, 09:24 PM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
That's a great chart for reference!
  #10
Old 05-19-2011, 10:34 PM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
So which will take more abuse, a 400 or a 700r4? I have both in my El Caminos and I'm wondering which I'll be replace first?
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
  #11
Old 05-19-2011, 10:40 PM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
Quote:
Donny I'm sure that YOU can destroy ANY tranny, but the 400 is tougher without a doubt!
  #12
Old 05-19-2011, 10:43 PM
Year: 1982
Model: Caballero
Region: 18(CA)
NECOA #: 17105
In my opinion the th400 will stand up better because it has a dedicated center support that is bolted down to the case ,the bolt is accessed by removing the valvebody and plates.By having it bolted down it doesn't move near as much keeping the transfer of power in a more lineal direction without internal deflection.
  #13
Old 05-20-2011, 02:43 AM
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
Garage
Quote:
Thats why I'm gonna make you my friend!!!!
It figures the 400 will hold up better cause it's in the 68 that I don't dog on (much)
The 700R4 is the one catching all the abuse!!
  #14
Old 05-20-2011, 06:48 AM
TrannyMike's Avatar
Year: 1985
Region: 18(CA)
NECOA #: 18805
Yea, I'll be here to help when you blow your trans to smithereens!
  #15
Old 05-20-2011, 09:05 AM
Dinosdad's Avatar
Dinosdad Dinosdad is offline
Year: 1980
Model: Caballero
Region: 3 (DE,NJ,PA)
NECOA #: 15809
Dinosdad has a spectacular aura about
Yup... I can vouch for TrannyMike doin' that for DDD...He!!, He did it for Me!
Best Regards,
Tony
Tags
elcamino, hydramatic, swap, transmission, turbo
You may not post new threads
You may not post replies
turbo 350 to turbo 400? zach133 Transmission & Drive line 6 07-21-2008 05:37 AM
TURBO 400 INTO '66 the rooster Transmission & Drive line 1 05-03-2008 05:53 AM
Is turbo 400 same length as a turbo 350 blue81elcamino Transmission & Drive line 2 06-03-2007 12:55 PM
400 w/400 turbo in my 1980 elco smooth swap?or no go? dealz on wheels Engine Topics 4 02-14-2007 06:23 PM
Turbo 400 Ratski Transmission & Drive line 2 12-06-2006 11:35 AM
