700R4 Floor Shifter Whats the Best ? - El Camino Central Forum : Chevrolet El Camino Forums
Old 05-22-2011, 04:09 AM
fixitman1's Avatar
fixitman1 fixitman1 is offline
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
fixitman1 has a reputation beyond reputefixitman1 has a reputation beyond repute
Default 700R4 Floor Shifter Whats the Best ?
I want to install a Floor Shifter, what would be a good choice
Cable or Linkage and if i would go with a LOKAR FLOOR MOUNT SHIFTER i see they have a sw mounted for N and P what about Back up Lights ?
Old 05-22-2011, 05:10 AM
thundercat2's Avatar
thundercat2 thundercat2 is offline
Year: 1978
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 12606
thundercat2 has a spectacular aura about
hopefully next spring i will be getting an overdrive trans and this is what i will be doing. like the old school horseshoe shifters and these seem to be built well.
http://www.kilduffmachine.com/
ron
My church is the open road...just me,God,and the highway
Old 05-22-2011, 05:40 AM
TrannyMike's Avatar
TrannyMike TrannyMike is offline
TrannyMike
Year: 1985
Region: 18(CA)
NECOA #: 18805
TrannyMike has much to be proud of
ron
I saw that shifter mentioned on another site last night. Looks like it works pretty well. The video is a sight to see, with the creator of the shifter smacking it with a baseball bat showing how well the ratchet works. I was cracking up, although it held up to his abuse and made his point!
Mike
Old 05-22-2011, 06:26 AM
ECRider's Avatar
ECRider ECRider is offline
Site Contributor
Year: 1979
Region: 6 (FL)
NECOA #: 14143
ECRider will become famous soon enough
I run the ratchet shifter you showed from B&M with the trigger on my 1979 w/a 700r4.It's a cable connection and it works great, just wish the black surrounding cover was taller it doesn't reach the floor tight.
1979 El Camino
2006 Harley Electra Glide Classic
1969 Triumph Bonneville
Too Much Of A Good Thing...Is A Good Thing
Old 05-22-2011, 06:43 AM
ALAsh's Avatar
ALAsh ALAsh is offline
Year: 1979
Model: El Camino SS
Region: 11(IA,NE,ND,SD)
NECOA #: 17592
ALAsh will become famous soon enough
I am using the B&M in my 79 and it was a great fit incorporating it into the standard SS floor console.
I welded up a the original Rube Goldberg linkage system that controls the back up lights and gear position indicator. The indicator at least reads correctly for Park, reverse, and Drive, and the key shift lock works.
BTW you can order that B&M shifter in two lever heights.
68 !!! ****, if I had known I was going to live this long I would have taken better care of my body !!
Old 05-22-2011, 08:55 AM
texaselky's Avatar
texaselky texaselky is offline
Year: 1984
Region: 13(TX)
NECOA #: 10419
texaselky will become famous soon enough
I have the Kilduff shifter in my car and just love it! It works flawless and nobody else has one at the cruise in! I just love to be a little different!
1984 El Camino
Kyle, Texas
Old 05-22-2011, 09:52 AM
fixitman1's Avatar
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
Default Floor Shifter
Quote:
Guess i cant get one now , i do want to connect the back up lights right now stock Column shift i do have a Floor Shift column i can install w/ tilt
  #8
Old 05-22-2011, 09:55 AM
texaselky's Avatar
Year: 1984
Region: 13(TX)
NECOA #: 10419
Well if you do get one, just dont park next to me? The Kilduff shifter has switches in it for back up lights and a neutral safety switch.
  #9
Old 05-22-2011, 10:08 AM
fixitman1's Avatar
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
Default Shifter
I can order mine with a different style what doess your shifter look like than we both will be different !!
  #10
Old 05-22-2011, 10:33 AM
hotrodpc's Avatar
hotrodpc hotrodpc is offline
Senior Member, NECOA Contributor
Year: 1965
Region: 12(MO,OK,KS)
NECOA #: 18060
hotrodpc has a spectacular aura about
When I do one, I am likley going with a B&M Quicksilver ratchet. I used a Quicksilver for years and loved it. Also the Quicksilver can be used for 3 speed or 4 speed, can also be used for reverse vavle body if you ever choose to go that route, and it also has its own gear selector with light, P N safety switch IF you choose to hook it up, and also have back up light provisions if you choose to hook them up. So the Quicksilver is fairly versitle in hooking up just about any way you'd want to. You can also leave your factory gear selector, back up lights and P N safety switch hooked up if you choose and do it right. You'll have to use a bracket off a console cable shifted car like an older Cutlass or camaro to do that.
  #11
Old 05-22-2011, 10:37 AM
texaselky's Avatar
Year: 1984
Region: 13(TX)
NECOA #: 10419
I have the standard shifter (all he made at the time), with a long handle and the top plate that lites up. with the brass knuckles!
  #12
Old 05-22-2011, 11:59 AM
hotrodpc's Avatar
Year: 1965
NECOA #: 18060
BTW, I noticed you asked which shifter is better. I don't know that any are any better than others. It will come down to personal preference and the features you want or need. As said, I go with the Quicksilver or Mega because I change my mind and go back to 3 speed or back to 4 speed and keep the same shifter. And in the event I decide I need a reverse valve body for racing, I can also use the same shifter.
I knew there was another B&M that had the same features too as the Quicksilver. Its the Megashifter. Only reason I went with the Quicksilver over the Megashifter was the stick is taller and I had it installed in a truck. Now B&M makes the truck Mega shifter but its just a taller base I beleive. Not a taller handle. Here are some links to the B&M Quicksilver and Megashifter if you go that route.
http://www.bmracing.com/PRODUCTS/Per...rs/Megashifter
http://www.bmracing.com/PRODUCTS/Per...rs/Quicksilver
  #13
Old 05-22-2011, 02:44 PM
fixitman1's Avatar
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
Default Shifter
Well i want a straight cut not the saw tooth /and no knuckles for me just the Bar
  #14
Old 05-22-2011, 02:47 PM
fixitman1's Avatar
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
Default Shifter
I would like a shifter that shows all gears 1/2/3/4/ Yes P / N & R also !
If my wife drives it i want it to be where she knows what gear its in .I want to do a good quality job /You know when you open the door you just stand there and Look !!
  #15
Old 05-22-2011, 02:59 PM
DONE DEAL DONNY's Avatar
Year: 1984
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a reputation beyond reputeDONE DEAL DONNY has a reputation beyond reputeDONE DEAL DONNY has a reputation beyond repute
Garage
Quick Sliver in mine and I love it!!!!!
If I watched the video right you have to raise the handle each time you wanta change gears on the Kilduff, one extra step you don't need to do with the Quick Silver, however you can lock the Kilduff, I liked that idea.
Still like my Quick Silver though!!!!
#12, 1984 El Camino "Bumping Uglies"
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
700R4 Shifter Issue.. ALAsh Transmission & Drive line 11 04-03-2011 04:43 PM
Floor Shifter -> Column Shifter PeterWabbit General BS Topics 7 12-20-2009 03:28 AM
1980 Stock Shifter with a 700R4? PearBear Transmission & Drive line 3 02-08-2007 07:58 AM
Billet Floor shifter or Carbon Fiber look alike shifter EGOKILR Wanted Items 2 12-11-2006 09:05 PM
Bench/coloum shifter to bucket/floor shifter 78CaminoBen Interior Restoration 2 03-05-2006 04:07 PM
