2012 NECOA Calendar Competition Rules - El Camino Central Forum : Chevrolet El Camino Forums
Closed Thread
Old 07-15-2011, 03:40 PM
kenrogers1's Avatar
kenrogers1 kenrogers1 is offline
National Director Supporting Member
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12751
kenrogers1 is a glorious beacon of light
Exclamation 2012 NECOA Calendar Competition Rules
2012 NECOA Calendar Contest Rules
The 2012 NECOA Calendar contest will begin soon, with a target date for the submissions, voting, and calendar completion by the middle of November. To facilitate the calendar competition this year, we are implementing the following rules. These rules are meant to level the playing field for all, and to spread the riches around by allowing more finalists from a much wider spectrum of the membership. In the past, voting blocks in larger Regions unduly affected who was fortunate enough to “make the show” to some degree. By limiting the number of finalists from each Region, we hope to gather a more representative collection of worthwhile Elkies for our calendars.
1. All submissions should include a full or 3/4 front or rear view, along with either a full left or full right side profile of the Elky. Variations from those quartering shots are not often found on calendars and will generally be disqualified. See these locations for photography suggestions: http://www.elcaminocentral.com/showthread.php?t=30210&highlight=Photography ,
http://www.cobracountry.com/fototips/fototips-condensed.pdf , or, for more extensive help,
http://www.cobracountry.com/fototips/home.html.
2. No more than two (2) digital images may be submitted for each member’s Elky. All images submitted MUST be a minimum of 2400 X 1800 pixels in size. However, it’s much better to submit the image just as it came from your digital camera – full size. Images that are not of high quality, and suitable for printing, will be rejected at the sole discretion of the Calendar Committee. Per Item 1, all images with a portion of the car cut off will be disqualified.
3. Absolutely NO PhotoShopping of the Elky’s image. Images that have been altered through the use of PhotoShop, or similar software, will be disqualified. Adjustments to the background or areas surrounding the Elky’s image will be allowed, within reason.
4. Each photo submitted MUST have the member's Name, the member's user name on the Forum, the member's NECOA number, the Year, Make & Model of the car, and the City & State where the car is based. Enter this information into the "Caption" area of the entry screen in the order shown above. Submissions will be accepted during the period from midnight July 31, 2011 until midnight, August 31, 2011. All images not meeting the quality requirements of Items 1 and 2, above, will be disqualified without further notice. Resubmissions will be allowed if corrections for quality have been made.
5. Voting will commence at midnight on September 10, 2011, and will end at midnight on September 30, 2011. Only one (1) vote per member per image. Violations of this rule will result in immediate disqualification of all of the member’s submissions in all categories. Violations of the rules made with the intention of improperly influencing the calendar competition outcome will result in a permanent ban of the member from the Forum.
6. Three (3) calendars are planned for this year: a 1st, 2nd, & 4th Generation calendar, a 3rd Generation calendar, and a 5th Generation calendar.
7. No more than three (3) images from any individual Region will be included in any of the calendars. If more than three (3) Elkies from one Region obtain a higher number of votes than those from other Regions, only the first three (3) will appear in the calendar. The next highest vote-getters from other Regions will be moved up for the final result. Final numbers may be adjusted by the Calendar Committee if necessary because of finalists’ limitations, and editorial privilege may be implemented to fulfill the Board’s desire for a balanced representation of the Association’s membership.
8. Best of luck to all, and let’s begin searching out that “just right” photo setting!
.......................Ken Rogers - for the NECOA Board
Old 08-07-2011, 07:04 AM
kenrogers1's Avatar
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12751
Arrow Please Adhere to the Rules
Let me remind everyone to please read and comply with the rules above for size and composition of your photos . Only two (2) photos per entry! Each photo submitted MUST have the member's Name, the member's user name on the Forum, the member's NECOA number, the Year, Make & Model of the car, and the City & State where the car is based. Enter this information into the "Description" area of the entry screen in the order shown above.
Those of you who have trouble entering your photos, or need help with editing your information after entry, please contact myself, acauth1, or John Harris. Those who do not find an "ADD ITEMS" option along the left side of the Calendar screens, please forward your photos, along with the required information, to myself at kenrogers1@sbcglobal.net , or acauth1 (Robert More) at acauth1@gmail.com , or to John Harris (John Harris) at necoa@verizon.com . It is much easier for us to deal with the photos transmitted through the eMail process, and easier for you to send the images.
If we all follow the rules, and ask for help when needed, this year will have the best ever crop of calendar Elkies!
National Director
"I've never seen a hearse towing a U-haul "
See my '68 SS
Old 08-13-2011, 01:41 PM
Mrbud's Avatar
Mrbud Mrbud is offline
Member
Loose Nut
Year: 1982
Model: El Camino SS
Region: 9 (IN,KY,MI)
NECOA #: 14758
Mrbud will become famous soon enough
Silly Question.Where do i find my NECOA number?
1982 El Camino
Original 305 Upgrade cam
Holley Port Fuel Injection
Choo Choo Conversion Package
1949 Chevy Sport Coupe
Camaro Clip 327 30 over
Holley 4 barrel
1940 Dodge Coupe in Progress
318 with a 727 auto
Small Stable
Old 08-13-2011, 02:58 PM
Elky 83's Avatar
Elky 83 Elky 83 is offline
Location: San Antonio, Texas, after living in Hawaii for 31 years.
Year: 1983
Model: Conquista
Region: 13(TX)
NECOA #: 5
Elky 83 will become famous soon enough
Garage
Look over in the right hand top corner of the post you made today. Sixth line down.
[SIGPIC]
[/SIGPIC]
MyGallery
Old 05-28-2012, 10:46 PM
83 custom 83 custom is offline
Junior Member
Member
Year: 1983
Model: Conquista
Region: 19(AK,ID,OR,WA)
NECOA #: 21875
83 custom will become famous soon enough
Default hmm
this is interesting
Closed Thread
Tags
2012 necoa calendar, calendar submissions, elcaminocentral.com, necoa, photography suggestions
You may not post new threads
You may not post replies
2011 Official Chevrolet El Camino Calendar competition! membercalendars General BS Topics 5 11-11-2010 10:46 AM
2011 NECOA Calendar $3 off NECOA memberscalendars General BS Topics 2 10-20-2010 03:01 AM
Calendar voting rules & methods skinyfisher General BS Topics 4 10-12-2009 11:20 AM
Read the rules! Calendar Pictures. 70ELCO Site Topics 3 12-11-2003 06:55 PM
ECC/NECOA El Camino/GMC Calendar ElkySS General BS Topics 0 11-17-2003 06:23 AM
