73 Elco with IROC Wheels that dont come off!!! - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Body & Chassis > Wheels & Tires
Old 07-19-2011, 06:13 PM
Rattlehead07's Avatar
Rattlehead07 Rattlehead07 is offline
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 18(CA)
NECOA #: 7501
Rattlehead07 will become famous soon enough
Garage
Default 73 Elco with IROC Wheels that dont come off!!!
Hey guys,
I cant actually believe I'm having this problem, but judging by a bit of research, me and my mechanic might have missed a crucial step or two in this little process.
We installed IROC 2 fronts and 2 rears on my el camino, all stock suspension and axles, no modified studs, or anything else for that matter. just put rubber on em, and bolted em to the car.
So now its time to change my brake pads, and the front wheels dont come off. Due to the factory short wheel studs, the wheel nuts are screwed way deep in the wheel cavity, and nothing seems to be able to get a good grasp on them...
how in the world do i fix this problem, because sooner or later my brakes are gona go to sh*t and im just gonna do more damage in the long run...
Thanks for all the help in advance, i appreciate it!
1973[SS]462ci
Old 07-20-2011, 07:12 PM
Cargasm Cargasm is offline
Motor Mouth
Year: 1971
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 12788
Cargasm will become famous soon enough
thin wall sockets? how did your mechanic get em on in the first place? maybe you should give him a call or maybe a plasma torch? ya that will get em off!
Old 07-22-2011, 11:02 AM
DOUG213XRJ's Avatar
DOUG213XRJ DOUG213XRJ is offline
Year: 1978
Region: 9 (IN,KY,MI)
NECOA #: 13817
DOUG213XRJ has a spectacular aura about
Hey. Your El Camino looks great with those wheels. Try a thin wall socket. But what ever you do Don`t use anything that will mess up the rims. Doug
78 El camino
79 Malibu (sold)
81 Malibu
Old 07-22-2011, 02:02 PM
Carr7640's Avatar
Carr7640 Carr7640 is offline
Year: 1980
Region: 13(TX)
NECOA #: 16399
Carr7640 will become famous soon enough
That happened to me the lugs nuts dug into the rim tried everthing to get them out .I had the factory acorn nuts temp. Till I bought correct ones ,anyway I only had 2 that dug in I had to drill the lugs thru .Discount tires got me the standard lug nuts chrome and cheaper than gm dealer.
Old 01-13-2012, 03:42 PM
crazybuffalocb crazybuffalocb is offline
Junior Member
Gear Head
Year: 1967
Model: El Camino SS
NECOA #: 20972
crazybuffalocb will become famous soon enough
i had this problem on a really hideous set of wheels that were on my 04 silverado when i bought it, i ended up taking a trip down to my local advance auto back when they sold autovalue or whatever crap brand they had at the time (though im really a big fan of the new gear wrench line they are carrying) and bought 6(all they had) of the size socket i needed, then the next size down in standard. i took my bench grinder and cut the sides of the socket down till i made a super thin, ready to crack socket, broke two, but over all they worked, the smaller sockets are great too if you absouluetly cant do anything else u can beat them on to the lug nut with a 3lb hammer and sacrafice the socket. works though. and albeit ugly, advance does cary two different types of slim lug nuts, one that is just reduced diameter acorn style, and the other that looks basically like a socket on one end and threads on the other.(my favorite)
Old 01-13-2012, 06:09 PM
getfacsw getfacsw is offline
Junior Member
Twisted Wrench
Year: 1985
Region: 3 (DE,NJ,PA)
NECOA #: 19339
getfacsw will become famous soon enough
Not sure if this would work, but I used this method to take off a set of wheel locks when I lost the key.
Figure out the approximate dimension of the lug nut and then go to Home Depot or Lowe's and get a small piece of pipe. I banged the pipe over the lug nut then I was able to use that to twist the lug nut off.
Bill
Old 01-13-2012, 09:00 PM
dougs85 dougs85 is offline
Year: 1987
Model: Conquista
Region: 16(CO,MT,WY,UT)
NECOA #: 9322
dougs85 is a glorious beacon of light
Using a stick or mig welder, and welding through the hole of a nut, weld another nut on top of the lug nuts.
Doug
85 El Camino 305, TH350, K&N, dual exhausts (Sold 2-21-09)
87 El Camino 305, 2004R, K&N, dual exhausts
1964-1/2 Mustang conv, 260 V8, dual exhausts
2003 Jaguar XJ8, 2000 Harley Road King
66 Austin-Healey BJ8
Lakewood, CO
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Iroc Wheels.... One more time.... 86ELKDOGG Suspension & Steering 7 02-21-2010 10:06 AM
wtb 20inch iroc wheels LeatherMan Wanted Items 4 03-07-2009 05:51 PM
Iroc Wheels Fyjimo Suspension & Steering 7 12-31-2008 04:40 PM
lookin 4 iroc wheels amp88fan Wanted Items 1 08-25-2008 07:14 AM
Iroc 16" wheels gumby Suspension & Steering 4 03-07-2006 07:19 PM
