Should my sub go behind my seat or smugglers? - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > General Topics > Audio
Old 12-10-2011, 06:57 PM
ozzierod24's Avatar
ozzierod24 ozzierod24 is offline
Member
Twisted Wrench
Year: 1979
Region: 15(AZ,MN)
NECOA #: 19506
ozzierod24 will become famous soon enough
Default Should my sub go behind my seat or smugglers?
I currently have 2 10" (about 400rms together) subs in boxes in the smugglers box of my 79'. It rattles my bed like crazy. I have a few ideas about what i want to do next with my subs. im going to get a single 12" that puts out about 600rms and 1200 peak.
I either:
1. want to put the new sub in same spot and just use dynamat.
or
2. build a solid ground right behind my seats and put it there.
My worries are:
1. that the dynamat wont do much and it will still sound like crap with all the rattles.
and
2. if i put it behind my seat, will i still hear the music over the bass, being that the subs are closer to my ears.
Im pretty open to ideas, i just want to have some sweet sound, with some good bass to show off a little bit.
- Let me know what you think,
thanks
Old 12-10-2011, 07:05 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 has a brilliant future
Garage
Quote:
I either:
or
My worries are:
and
thanks
Check mine out.
(this post was written by a well used crash test dummy, on a closed course. No armadillos were harmed in the making of this post. Your mileage may vary. If you have a stiff upper lip lasting more than four hours, seek medical assistance. Reading this post may cause bleary eyes in men over 50, and is known to cause a significant reduction in brain cells....)
Knowledge before $$$$ is my new philosophy!!!!!!
Old 12-10-2011, 10:04 PM
84elcoconquista's Avatar
84elcoconquista 84elcoconquista is offline
Year: 1984
Model: Conquista
Region: 12(MO,OK,KS)
NECOA #: 20278
84elcoconquista will become famous soon enough
Garage
If I were you I would do it where you have it now. I have seen people take the back carpet curtain completely off and put there subs in there and smoothly transfer the rest of the interior look to a wall that goes infront of the spare tire and could be removed if the tire was ever needed. I have also seen people who have completely taken out the tire. Here's an example
http://www.google.com/search?hl=en&c...l1l0&mvs=0#p=0
1984 - El Camino Conquista~ 305;3-Speed; 2.41
Old 12-11-2011, 01:53 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
Originally Posted by HKDUP87 View Post
Check mine out.
use this from lowe's.$19.99 50foot roll.
HERES A VIDEO.
Old 12-11-2011, 06:48 AM
ALAsh's Avatar
ALAsh ALAsh is offline
Year: 1979
Model: El Camino SS
Region: 11(IA,NE,ND,SD)
NECOA #: 17592
ALAsh will become famous soon enough
I put an 8 inch Bazooka in the smugglers box with the speaker pointed into the corner.
I also fabricated a small flexible shaft which is connected to the gain knob and protrudes through the rear curtain. This allows me to easily fine tune the loudness of the sub by just reaching back and turning the knob. I can go from subtle to shaking the mirror effortlessly.
I think it sounds great.
Arnie in Iowa
68 !!! ****, if I had known I was going to live this long I would have taken better care of my body !!
Old 12-11-2011, 07:11 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Arnie in Iowa
THAT 8 INCH PACKS A PUNCH. WAS YOUR BRAIN SHAKING?
Old 12-11-2011, 12:39 PM
biggdogg73's Avatar
biggdogg73 biggdogg73 is offline
Junior Member
Gear Head
Year: 1973
Region: 7 (AL,GA,TN)
NECOA #: 15352
biggdogg73 will become famous soon enough
I have a 1973 elco and i cut hole in the wall where the smuggler box an the inside behind the seats.I used the smuggler as a small trunk for the woofers, i have two 12s.it sounds good very little rattle,and no dyna mat in the box yet.
  #8
Old 12-11-2011, 03:22 PM
my87custom's Avatar
my87custom my87custom is offline
Year: 1987
Region: 19(AK,ID,OR,WA)
NECOA #: 18082
my87custom will become famous soon enough
Garage
depends on if you want the car to remain looking stock, or if you want to be proud of it. if you want it to look factory, i'd put it behind the curtain so u have sound quality but cant see it, but me, i went with the custom look and built a shelf to bridge the hump in the middle, and goes behind both my seats, and extends into the sub box. pushing 2 twelves and 1 ten inside. sounds good. but my interior has recently been restored and is dynomatted everywhere.
and with 600 w rms, it shouldnt be too much trouble in your bed.
I miss 2.00 gas
  #9
Old 12-11-2011, 03:42 PM
ozzierod24's Avatar
Member
Twisted Wrench
Year: 1979
Region: 15(AZ,MN)
NECOA #: 19506
@ my87custom Yeah im not necessarily wanting it to be 100% factory looking. I definitely want it to look like a custom set up. I like the way yours sounds, do you have any pics of your set up?
  #10
Old 12-11-2011, 08:30 PM
Year: 1984
Model: Conquista
NECOA #: 20278
Garage
What exactly is the technical name for the "smugglers box"?
  #11
Old 12-13-2011, 09:05 PM
my87custom's Avatar
Year: 1987
NECOA #: 18082
Garage
i dont have a pic at the moment. my phone kinda took a dump on me.
but the elky is garaged anyway for a few weeks waitin for weather to improve.
so in the meantime, me and the girl are working on her camaro project.
i will try to get pics of it up tonight.
  #12
Old 12-14-2011, 03:04 PM
ozzierod24's Avatar
Member
Twisted Wrench
Year: 1979
Region: 15(AZ,MN)
NECOA #: 19506
alright i'd appreciate the pics, it helps put some more ideas together.
thanks
  #13
Old 12-16-2011, 12:08 PM
my87custom's Avatar
Year: 1987
NECOA #: 18082
Garage
cant seem to get them onto my computer.
they are on my phone and my camera. but cant upload it. i'll keep tryin.
  #14
Old 12-16-2011, 12:34 PM
Beepster's Avatar
Beepster Beepster is offline
Silver Contributor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 20479
Beepster is a jewel in the rough
My curtains have cutouts for speakers. But then, my spare isn't on the inside, it's in a custom kit in the bed for the spare, tools, and battery. This makes a clean area in the smuggler's compartment. I have two 7 1/2" speakers in boxes for that purpose on each side for the sound to go out thru the cutouts. I haven't messed around back there too much, as I've had too many other things to do to get things back in order after replacing my dash. This would be a consideration for you with the cutouts in the curtain.
Bruce
'87 Elkie: 350CID; 700r4; B&M shifter; buckets; AC; PS; PB; PW; PL; PM; Sony Blutooth; Kenwood rear spkrs.
'56 Chevy BelAir: 350CID; 5-spd Tremec; AC; PS
'10 VW Jetta: 2.5L, 5-cyl; 6-spd auto; AC; PS; PB; PW; PM; PL.
  #15
Old 12-16-2011, 12:37 PM
69 SS396's Avatar
69 SS396 69 SS396 is offline
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 19132
69 SS396 is just really nice
Garage
I have 2 10" Rockford Fosgates behind my seat.
Sounds great, I can hear all the highs and lows and everything in between.
I had to turn the subs down a little because I couldnt see out my rear view mirror though.
It THUMPS. Yeh I know, I'm a punk-arse kid of 51
I have pics of my install in my pic trail account, link in signature line.
Cheers, Sean
Proud owner of "Misty Meaner" 1969 Elky SS
1995 BMW M3 Convertible, triple black w/60k miles. Road tested to 135
1925 Model T Tudor. Getting a 4.3 V6/700R4 and 4.11 posi rear.
2005 Silverado crew cab named Betty(bam-ba-lam)Daily driver.
Fuzzy Wuzzy was a bear. Fuzzy Wuzzy had no hair. Fuzzy Wuzzy wasn't fuzzy was he?
Tags
smugglers box, sound quality, subs
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
smugglers box demonchild135 General BS Topics 20 03-26-2016 10:37 PM
Smugglers box BigStinky79 Body Restoration 2 05-15-2011 03:19 PM
SMUGGLERS BOX?????????? HEMIX2 Body Restoration 2 09-30-2006 02:11 AM
smugglers box lowdown General BS Topics 3 04-10-2006 06:45 AM
Smugglers box dennis68 General BS Topics 9 08-21-2004 09:45 PM
