2 barel to 4 barrel carburetor swap - El Camino Central Forum : Chevrolet El Camino Forums
Old 03-05-2012, 05:24 PM
CrazyCarl50's Avatar
CrazyCarl50 CrazyCarl50 is offline
Junior Member
NooB
Year: 1970
Region: 11(IA,NE,ND,SD)
NECOA #: 21300
CrazyCarl50 will become famous soon enough
Default 2 barel to 4 barrel carburetor swap
im thinking about swaping the stock 2 barrel on the 350 in my 1970 el camino with 60,000 miles right now it seems to get good milege for a old v8 i was thinking about using a quaderajet because i heard they are prety efficent what whould you guys recmond i use for a carb to and intake to a good mix of preformence and ecnomy wise i dont do alot of work with engins so i dont want it to get to complated or expensive would it be worth it to do this swap preformence and fuel ecnomy wise
Old 03-05-2012, 05:30 PM
84elcoconquista's Avatar
84elcoconquista 84elcoconquista is offline
Year: 1984
Model: Conquista
Region: 12(MO,OK,KS)
NECOA #: 20278
84elcoconquista will become famous soon enough
Garage
This is what i am highly considering. Get a carb that is a quadrajet from mountain man carbs. No edelbrock or holley will get you good mpg. But then you will need a new intake manifold, doesnt really matter, you can get edelbrock or normal, now the heigth of the intake manifold is for performance.
Note that quads dont have specific CFM they just allow what is needed i talked to a member just last night (87next2last1).and said he is getting 2 times the mpg and good performance compared to his 650 cfm edelbrock.
Brandon
1984 - El Camino Conquista~ 305;3-Speed; 2.41
Old 03-05-2012, 08:05 PM
LOCKJAW's Avatar
LOCKJAW LOCKJAW is offline
Year: 1964
Region: 5 (NC,SC)
NECOA #: 19368
LOCKJAW is of outstanding character
Garage
I have for sale a GMPP "ZZ4" intake for a 350 SBC. It accepts either square bore or spread bore carb. It is supposed to add a little bit of performance over standard manifold. It is dual plane with no heat transfer. It is listed under Parts For sale.It was used for about 500 miles to break in my motor.
TO ERR IS HUMAN, TO FORGIVE IS DIVINE.
NEITHER IS MARINE CORPS POLICY!
1964 restomod. Wht/red, full roller ZZ4, full MSD ignition, Muncie , QFT, Hookers, Flowmasters.
Old 03-05-2012, 11:49 PM
Junior Member
NooB
Year: 1970
NECOA #: 21300
yea i heard edelbrock makes replacement q-jets but i couldnt find any on their web site are they still available
Old 03-06-2012, 05:36 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
Summitt carried quadrajets. Not sure if they still offer them or not.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 9 and really haven't had to work on it this year.
Link to Garage:
Old 03-06-2012, 07:47 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 21252
ccc is a name known to all
the performer rpm manifold was copied from the z28 manifold in the early seventies a good piece on a stock or built engine.i would go to this mountian man carbs over sumit or jegs simply because sumit or jegs are just retailers and not builders and if it has a problem they can exchange it,but a builder can acurately help diag.any problem you have instead of trusting a tech guy who may or may not know a thing about your part in question
Old 03-06-2012, 08:21 AM
87next2last1's Avatar
87next2last1 87next2last1 is offline
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 16317
87next2last1 has a reputation beyond repute87next2last1 has a reputation beyond repute
Garage
it's hard to beat Mountain Man carbs for a little over $200 !!
1987 EL Camino Conquista 4.3L (My Car)
1984 EL Camino SS V8 (My Truck)
1983 El Camino V8 (My Toy)
Check them out on link Below !
  #8
Old 03-06-2012, 09:10 AM
rxkaffee rxkaffee is offline
Motor Mouth
Year: 1982
Model: Conquista
Region: 13(TX)
NECOA #: 18511
rxkaffee will become famous soon enough
I hope this doesn't hijack the OP's thread, but I have an inquiry about 2-4 rochester swap as well. On the newer Electronically Controlled carbs, will the same ecu work for dualjet and quadrajet? Or does the quadrajet need a different ecu to control the carb?
  #9
Old 03-06-2012, 10:44 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
no the dueljet is the front half of a qjet it wont know the differance
  #10
Old 03-06-2012, 10:49 AM
iischris's Avatar
iischris iischris is offline
Motor Mouth
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 20296
iischris will become famous soon enough
Garage
I you want better MPG use the quadrajet. I've got a Holley on my rig. I love it, but when I'm at the gas pump I regularly think about rebuilding or getting a quad.
  #11
Old 03-06-2012, 11:03 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
q jets are hard to beat you can tweek them so much it isnt funny and you cant beat the fuel milage they give you.they are so good even ford used them on some of thier cars untill they came out with thier own version of the spread bore carb
  #12
Old 03-06-2012, 11:07 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
if you guys need a larger cfm electronic q jet the ones from the 80s cady with the 425 are 800 i believe.you need to put the chevy throttle lever on it and reroute the fuel line as it comes in the front but will feed those big small blocks and keep your computer working
  #13
Old 03-06-2012, 02:26 PM
theelcaminoman's Avatar
theelcaminoman theelcaminoman is offline
Year: 1980
Region: 10(IL,MN,WI)
NECOA #: 20262
theelcaminoman has a spectacular aura about
DO IT! I swapped from a 2 barrel to a 4 barrel on my old 267 and what a difference! You get twice as much power and better MPG because the "cruising" barrels are smaller than on the dualjet. Not to mention that surge of power when you lay your foot into it!
1980 El Camino
305, 200-4R, open diff
CAUTION: WORK IN PROGRESS
2004 F-250 Harley-Davidson
V10, 4x4, Daily Driver
KIDS in the back seat may cause ACCIDENTS...
ACCIDENTS in the back seat may cause KIDS...
NO BACK SEAT = NO ACCIDENTS!
Tags
carburetor sa
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
4 barrel is not opening, and I don't know why bluenitro84 Engine Topics 2 12-10-2011 05:52 PM
4 barrel for MPG? Spencer99 Engine Topics 15 05-31-2008 06:23 PM
2 Barrel to 4 Barrel swap on a 307 70SSDohn Engine Topics 6 02-22-2007 07:50 PM
2 barrel or 4 barrel for economy JimIsbell Engine Topics 16 01-13-2007 08:14 PM
2 barrel to 4 barrel Spencer99 Engine Topics 1 09-08-2006 09:43 PM
