need a gas cap, how to tell if tank is ECS - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-01-2012, 05:29 PM
Eotnak Eotnak is offline
Junior Member
Twisted Wrench
Year: 1970
Model: El Camino SS
Region: 3 (DE,NJ,PA)
NECOA #: 11715
Eotnak will become famous soon enough
Default need a gas cap, how to tell if tank is ECS
Hey everybody, quick question, couldn't find anything useful on google or searching here. I have a locking gas cap on my 70 SS 396 that leaks really bad. I'm looking for a non-locking replacement and I can't figure out if I need a vented, non-vented, or ECS gas cap. fuel tank, from what I can see has 2 lines leading to the engine compartment. One obviously goes to the fuel pump, the other thinner one is connected to a rubber line that someone stuck a bolt into to plug it up.
Anyone know how to tell which cap I need?
Old 06-01-2012, 06:03 PM
Bobby78's Avatar
Bobby78 Bobby78 is offline
Year: 1978
Region: 1 (NY)
NECOA #: 8173
Bobby78 has a spectacular aura about
Garage
Do you have a charcoal canister? That would be the "vent". Not really a vent but a way to send fumes to the carb and relieve pressure so then a non-vented cap would be what you need. Maybe that's where the hose goes/went?
110 Percent Auto Body and Collision Specialist, Inc.
Old 06-01-2012, 06:11 PM
Junior Member
Twisted Wrench
Year: 1970
Model: El Camino SS
NECOA #: 11715
My initial thought was that the 2nd line went to a charcoal canister originally. Currently there is no canister, so I figured I'd ask the experts here what is up...
Old 06-01-2012, 06:33 PM
Bobby78's Avatar
Year: 1978
Region: 1 (NY)
NECOA #: 8173
Garage
Yeah I don't really know either. Kinda guessing.
Old 06-02-2012, 05:00 AM
464elky's Avatar
464elky 464elky is offline
Year: 1984
Region: 6 (FL)
NECOA #: 8926
464elky has a reputation beyond repute464elky has a reputation beyond repute464elky has a reputation beyond repute
Garage
If the plugged line is a 1/4" it is a return line which would have connected to the fuel pump. If it is 5/16" or 3/8" it would have gone to a canister. Does it end on the passenger side by the fuel pump?
If it is the 1/4" line you will need a vented cap. If it is either one of the others it would have come with a non-vented cap but you would need to do something to allow the tank to vent. Maybe some pictures would help us help you.
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation-
Car Domain:
Another 3 to 9 years should finish it.
In year 10. Added FITech Fuel Injection this year. 40K miles and going strong.
Link to Garage:
Old 06-02-2012, 06:10 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 21252
ccc is a name known to all
464 is correct on this. to use the non vented cap you will need to supply some method of venting the tank. without the vapor canister i would run the vented cap until you can correctly repair your fuel system . if the line went to the fuel pump it was to help ward off vapor lock by bleeding off fuel and vapor bubles back to the tank
Old 06-02-2012, 06:28 AM
gilby's Avatar
gilby gilby is offline
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 10426
gilby has a reputation beyond reputegilby has a reputation beyond repute
Garage
...yeah,from 1964 thru 1972 are vented gas caps....
http://www.bobschevelleparts.com/196...d-gas-cap.html
..1974 Conquista
..1979 GMC Caballero
..2003 Impala
..2015 Spark
  #8
Old 06-02-2012, 08:27 AM
Junior Member
Twisted Wrench
Year: 1970
Model: El Camino SS
NECOA #: 11715
yup, the plugged line is 1/4", and the fuel supply line is 5/16". I looked at the assembly manual and saw that there are vented tanks (passenger front side of tank, 2 large vent tubes) and non-vented. I have a non-vented tank. So I'm thinking to go with the vented cap and write myself a note to get the correct fuel pump in the future.
thanks bobby78, 464elky, ccc, and gilby for setting me in the right direction
gilby, funny thing I noticed. You describe the cap (correctly) as vented, the link says vented, the title of the part says non-vented, description says non-vented, and the picture shows a vented cap. I wonder what I'd get if I ordered it?
  #9
Old 06-02-2012, 11:08 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
NECOA #: 21252
you are very welcome and good luck
  #10
Old 06-02-2012, 02:36 PM
gilby's Avatar
Year: 1974
Region: 18(CA)
NECOA #: 10426
Garage
...Funny thing,I didn't catch it either..
..if you order it,hope its the correct one..
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Gas Tank yoda_the_green Body Restoration 10 06-29-2011 09:23 PM
Gas Tank or ? elcaminothepathway Electrical Systems 7 11-18-2010 06:33 PM
Gas Tank jgold8604 Engine Topics 5 07-13-2005 09:49 PM
gas tank ? camino1 Engine Topics 5 03-09-2005 06:59 PM
my gas tank El Desperado General BS Topics 2 01-31-2005 10:35 AM
