I started it, I'll finish it --someday - El Camino Central Forum : Chevrolet El Camino Forums
Old 06-24-2012, 11:06 AM
MACV MACV is offline
Silver Contributor
Year: 1983
Region: 9 (IN,KY,MI)
NECOA #: 5998
MACV will become famous soon enough
Default I started it, I'll finish it --someday
I've been at this project since '09. Just getting around to posting it. The project is a '79 Caballero. Bought it on Craigslist with no engine or tranny. I had one of each in the barn so no problem. Body was good except for some rust around the front of the bed. PS, PW, PL, air, cruise, 50/50 split bench, gauges and some other nice stuff. I'm not much of a pic taker but I'm learning to post pics so if everything goes well I'll be adding pics of progress in the near future.
Larry
83 El Camino driver
78 El Camino donor
79 Caballero project
84 Caballero donor
60 Corvette
Enjoy your spot in the sun before your sun sets
Old 06-25-2012, 04:04 PM
Silver Contributor
Year: 1983
NECOA #: 5998
Hope I got the pics back.
Old 06-25-2012, 04:35 PM
oldtinsmith's Avatar
oldtinsmith oldtinsmith is offline
Year: 1980
NECOA #: 20152
oldtinsmith will become famous soon enough
Pics look good to me Larry.
Doug
Old 06-25-2012, 04:41 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is offline
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
hang in there Larry, I started a lil after you did, and I'm still plugging away too! lol
Take joy in finishing each part. it'll all be worth it in the end
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 06-29-2012, 12:59 PM
Silver Contributor
Year: 1983
NECOA #: 5998
I was able to borrow a rotisserie to do what little work the body needed. South Carolina preserves its bodies quite well. The day after these pictures were taken I shortened the front mounting arms 8". Several hundred pounds of steel on long lever arms made me nervous.
More later.
Old 06-29-2012, 01:04 PM
Year: 1980
NECOA #: 20152
Way to go Larry! Borrowing a rotisserie will make your work so much easier.
Doug
Old 06-29-2012, 02:19 PM
84withzz4's Avatar
84withzz4 84withzz4 is offline
Year: 1984
Region: 14(AR,LA,MS)
NECOA #: 3532
84withzz4 will become famous soon enough
Default finish it someday
Hang in there, you will be pleased when your almost done. Hey, your never really finished. You will find something to fix, change or just tinker with, that's the fun of owning it. I bought mine on 2004 and started saving $$. In 2006 I started the Choo- Choo conversion, I've been working on it ever since.
1984 El Camino Choo Choo Custom Clone w/ ZZ4
1995 Buick Century S/W - wife's car
2006 Buick Lacrosse - wife's 2nd car
  #8
Old 06-29-2012, 02:49 PM
stev6343 stev6343 is offline
Year: 1982
Region: 5 (NC,SC)
NECOA #: 14194
stev6343 will become famous soon enough
MACV, try 1990..... an I'm still.... working on my 82 and enjoying! Dale
  #9
Old 06-30-2012, 10:10 AM
Silver Contributor
Year: 1983
NECOA #: 5998
Hi, all of the above replies are spot on! This is a fun hobby and it keeps me out of mischief.
Just thought I'd describe an oddity that I found in the '79 when I removed the body. It is a trailer hitch mount. It is a piece of 1/2" X 6" X 42.5" steel bar stock welded across the tops of the rear spring towers. It has a 1" dia. hole cut in the center for an attachment device that stuck up through a hole in the bed floor. If they came through, the pics will describe the design better than I can. It looks like the bar can be installed without
raising the body because the factory left a "notch" in the bed/fenderwell pinchweld that would accommodate the bar if it were slid across the tower tops from fenderwell to fenderwell. All four of my El Camino/Caballero bodies have that notch.The springs were stiffened with several coil spreaders. Now I Think I know why I had to replace both rear shafts and bearings. Quite a hitch!
  #10
Old 06-30-2012, 10:44 AM
Year: 1980
NECOA #: 20152
I have never seen anything like that before!
Doug
  #11
Old 09-07-2012, 01:55 PM
Silver Contributor
Year: 1983
NECOA #: 5998
A little more progress. The colors are '88GM Flame Red and '88 or '89GM Bright Silver. Both metallic. Click on the thumb nail to see all 4 pics.
  #12
Old 09-07-2012, 02:37 PM
Year: 1980
NECOA #: 20152
Looks awesome Larry!
Doug
  #13
Old 11-29-2012, 05:46 PM
Silver Contributor
Year: 1983
NECOA #: 5998
Just a little more progress. I fought my way to the "old photobucket format" and I hope the pics are viewable. The electrical mess you see actually works! Lights, starter, wipers, power windows and locks. It's sort of a miracle because I had removed every wire from the body over a year ago. All I have to do now is figure out how to get all this stuff crammed under the dash. Oh yeah, I can take my circuit tags off now. The steering column is from my'84 donor. I transferred the ignition, dimmer and reverse light switches from the '79 to the '84 column. http://i1041.photobucket.com/albums/...p/100_0432.jpg. http://i1041.photobucket.com/albums/...p/100_0435.jpg http://i1041.photobucket.com/albums/...p/100_0436.jpg http://i1041.photobucket.com/albums/...p/100_0436.jpg
  #14
Old 11-30-2012, 02:24 AM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
Baby steps till (One step on the moon!!)
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
  #15
Old 11-30-2012, 03:50 AM
El Diablo's Avatar
El Diablo El Diablo is offline
Deputy Director Region 16 (CO)
Year: 1973
Region: 16(CO,MT,WY,UT)
NECOA #: 12314
El Diablo will become famous soon enough
macv it could be the photo or the shadows, your photo of the rear axle assembly (amazing hitch plate btw) the upper left rear control arm and bushing seems bent .
Old's cool.
You may not post new threads
You may not post replies
i finish what started as a "will it fit ?" W!cKeD_ElK0 Audio 46 04-18-2013 07:16 PM
Finish this sentence!!! If i only had---- HKDUP87 General BS Topics 50 08-03-2012 12:37 PM
5th Generation Bed Finish Camino80 Body Restoration 4 05-23-2012 05:39 AM
Out of Body Shop to now finish it! CACowboy71 General BS Topics 16 04-09-2010 03:32 AM
what finish on 71 SS grill ssclone Body Restoration 1 05-27-2007 06:37 PM
