Just converted my '85 305 to a holley carb, need help with a throttle bracket - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > Performance Modifications
Old 07-22-2012, 07:29 AM
lukem80's Avatar
lukem80 lukem80 is offline
Member
Knuckle Buster
Year: 1985
Region: 7 (AL,GA,TN)
NECOA #: 22173
lukem80 will become famous soon enough
Default Just converted my '85 305 to a holley carb, need help with a throttle bracket
Its a '85 with a 305 engine and th200 metric trans.
I just installed a holley 4150 street avenger carb and need to know what brackets i need to buy to get my kickdown cable and throttle cable working.
Been searching around and found this:
http://www.jegs.com/i/JEGS-Performan...57310/10002/-1
Do i need the optional bracket at the bottom of that page?
And where/how do i connect my throttle cable to the carb. Looks like i need a stud of some sort.
Thanks for your time!
1985 EL CAMINO in progress!
Old 07-22-2012, 08:13 AM
mopowa's Avatar
mopowa mopowa is offline
Year: 1987
Model: El Camino SS
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 18849
mopowa has much to be proud of
Garage
You should be able to take the stud needed for the throttle cable from the old carb. As for the kick down I'm not sure about the th200 but I used both brackets you found to work with the 700R4 I have in my car. I think the lower bracket you see in the pic is only for the 700R4 and 2004R overdrive tranys with the TV system. Go to Holley.com and you'll probably be able to find the correct brackets for your application.
Looking forward to the day it's done.
Angelo V.
87 SS Choo Choo
406 cid
Old 07-22-2012, 08:37 AM
lukem80's Avatar
Member
Knuckle Buster
Year: 1985
NECOA #: 22173
That is a clean setup man!
My kickdown/tv cable looks exactly like yours so i might need the extra bracket. We'll see... I can always return it.
I checked holley and they sell a simlar setup with an optional bracket they say its for a 700r4 though.
Old 07-22-2012, 08:49 AM
mopowa's Avatar
Year: 1987
Model: El Camino SS
NECOA #: 18849
Garage
Yeh, on the Holley site you should be able to look up the street avenger carb and it will list the brackets you need. Thats what I did for mine. But as you said the lower bracket was listed as specific to only the 700R4 & 204R with the TV system. Does your trany have an overdrive?
Old 07-22-2012, 10:22 AM
lukem80's Avatar
Member
Knuckle Buster
Year: 1985
NECOA #: 22173
Nah no overdrive. Th200. I think its similar to a th350. Just need the kickdown to work when i stomp the gas pedal lol.
I guess i can hook it to the bottom of the stock holley linkage and that will probably work.
Old 07-22-2012, 11:12 AM
mopowa's Avatar
Year: 1987
Model: El Camino SS
NECOA #: 18849
Garage
Yeh you can probably make that work with a few adjustments. On the 700 & 204s Its more critical because the cable controls fluid direction and pressures in the trany and if they aren't set rite you get a fried trany.
Old 07-22-2012, 04:49 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
What CFM rating is the new carb ? Some times we have to fabricate items for linkage changes, where it's a not-stock set-up. Hope you get it figured out.
  #8
Old 07-22-2012, 05:19 PM
fixitman1's Avatar
fixitman1 fixitman1 is offline
Site Contributor
Year: 1980
Region: 13(TX)
NECOA #: 17658
fixitman1 has a reputation beyond reputefixitman1 has a reputation beyond repute
The
lowest CFM street avenger is 670 CFM not sure how it will work on a stock 305, but the built 305 i had it worked great,and i still run the Holley Street avenger carbs ! great right out of the box ............
  #9
Old 07-22-2012, 06:58 PM
mopowa's Avatar
Year: 1987
Model: El Camino SS
NECOA #: 18849
Garage
Holley is the one and only carb! I don't understand why some people shy away from them. I grew up with them and they're the only carb I want on anything I drive. The 670 Avenger is what's on my car now and it's the balls and most importantly the motor likes it.
  #10
Old 07-23-2012, 05:59 AM
lukem80's Avatar
Member
Knuckle Buster
Year: 1985
NECOA #: 22173
don't turn my thread into a Q-jet vs Holley deal that happens on here a lot.
I'm just going to rock this 305 till it explodes then probably do a 350/700r4 swap or maybe a 5.3/4L60E if I can get it cheap enough
I thought about buying a NOS plate and maybe helping this 305 reach boat anchor status even quicker! lol
  #11
Old 07-23-2012, 06:42 AM
MikesElco94's Avatar
MikesElco94 MikesElco94 is offline
Year: 1986
NECOA #: 19365
MikesElco94 will become famous soon enough
Just out of curiosity do you know what CFM it is? I always thought Holley made a 570 CFM street avenger.
-Mike
  #12
Old 07-23-2012, 11:29 AM
lukem80's Avatar
Member
Knuckle Buster
Year: 1985
NECOA #: 22173
exactly right 570cfm.
I had a edelbrock 600cfm on a 318 mopar for 10 years and its done well. i'm not too worried about mpg's. I don't drive this thing everyday
  #13
Old 07-23-2012, 02:27 PM
mopowa's Avatar
Year: 1987
Model: El Camino SS
NECOA #: 18849
Garage
Didn't mean to do that I've got nothing bad to say about the Eddy that was on my car it ran great with no problems. I guess its all about what you're used to.
  #14
Old 07-24-2012, 05:44 PM
Year: 1975
NECOA #: 13978
I had Holleys run great right out of the box too. Usually the 3310 vac secondary models, but used one 1850 that ran fine too. That's a 600 cfm if I remember correctly....
I have a Holley marine carb on my boat engine too, a spread-bore type.
I would think the 570 would be ideal for a 305....
  #15
Old 07-24-2012, 06:04 PM
mopowa's Avatar
Year: 1987
Model: El Camino SS
NECOA #: 18849
Garage
Yeh I agree the 570 should be the balls on that motor, plus with the springs you can easily adjust when you want the secondaries.
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
Holley carb and 200-4r, what size throttle stud? Richp85ElCO Engine Topics 1 07-27-2011 10:29 AM
Carb Throttle linkage Question BozCamino Engine Topics 3 08-06-2008 11:38 PM
EFI that looks like Holley Carb oldelky80 Performance Modifications 23 12-06-2007 10:01 PM
Throttle cable bracket question for 73 with 350 1973elcaminoSS Engine Topics 2 07-14-2006 08:05 PM
yes...another question, throttle bracket?? Iamopie2 Engine Topics 2 02-07-2005 02:50 PM
