electrical wiring for dummies - El Camino Central Forum : Chevrolet El Camino Forums
Old 07-22-2004, 10:28 AM
spy007
Posts: n/a
Default electrical wiring for dummies
I haven't messed with electrical stuff too much, but now I have to. I anticipate having alot of accessory stuff I'm going to want to wire in in the near future. First I need to do my electric seats, and then some dash stuff, and eventually I'm going to convert to power windows. I don't know the first thing about adding things to my electrical system other than I need power from the battery and a ground.
First, where do I get power besides running a wire straight from the battery terminal?
How do I know what (like my electric seats) needs a fuse, and how big?
How do I connect a bunch of accessory stuff without creating a birds-nest of wires in my car?
Old 07-22-2004, 12:02 PM
camino81 camino81 is offline
NECOA #: 1068
camino81 will become famous soon enough
you could get an aux. fuse box from painless to hook all the accessories into, you would on have to run one wire to the battery. just a thought.
camino81
'81 El Camino (Now in less pieces all over the garage!)
Where two liters of displacement refers to soda
Old 07-22-2004, 04:09 PM
Rick's Avatar
Rick Rick is offline
Year: 1972
Model: El Camino Classic
Region: 13(TX)
NECOA #: 149
Rick is a jewel in the rough
This: http://store.summitracing.com/partde...N=120%20303529 is the fuse panel that camino81 may be refering to. If you are not comfortable with electrical stuff its a good way to go. And even if you are comfortable it makes things much simpler.
I piece mealed mine over the course of 5-6 years. I've got 2 aux fuse panels and many extra relays hidden thru-out the car. Its a MESS! Right now I am cleaning up and working on a good method to seal the "smugglers box" in my elky. I'm gonna consolidate all my add-on electrics to that area. Hopefully it will look better & be more practical.
I believe that I'm using a 10 amp fuse to protect my electric seats. You'll find that most aftermarket add-on kits (windows, locks, etc) will include a correct fuse. Good luck.
Rick Schaefer
72 TPI El Camino
Old 07-22-2004, 04:52 PM
vrooom3440 vrooom3440 is offline
Year: 1968
Region: 18(N.CA,N.NV)
NECOA #: 3296
vrooom3440 will become famous soon enough
You need to start with data...
First the internet is a wealth of information even though there is a whole lot of noise amoung the data. For example:
https://www.fleet.ford.com/truckbbas...df/204-205.pdf
In particular you want/need to know how much current the various wire gauges can carry. This will also vary by temperature, wire bundling, and wire length. I have a couple of other sites at home that provide similiar information, but you know how internet searches are: you never get the same stuff twice.
Every accessory has a current draw. This is a critical number as it determines how big the wire feeding it needs to be and what size of fuse to put in the circuit. This will also drive the breakdown of circuits to some extent. For example a logical circuit might be "lights" except that the headlights pull enough current to be a circuit all their own. Note that the current draws are often not published
So you will have to reverse engineer them by reference to existing wiring diagrams. They all were used in some vehicle, get wiring diagrams for that vehicle and extract circuits, wire sizes, and fuse sizes to get some idea how you should set them up. This will be much easier if the accessories were actually used on some variation of the same car. In this case you may already have some wiring and such present to support the accessories. For example power window wires may already be there and if not, at least a fuse block position for the windows.
Note that in general the fuse should always be rated lower than all of the wiring connected downstream. You always want the fuse to blow rather than the wire. Fuses don't emit smoke and we all know that when the smoke gets out of electronic stuff, very bad things happen.
Once you have the basic circuit and wire/fuse sizes figured out then you can figure out how to add them. Part of this is deciding if this is an always on circuit or only on with ignition or with accessory. If the accessory draws significant power you will want to utilize a relay to drive power to it's circuit so as to reduce loading on the existing accessory or ignition circuits (they will drive the relay at low current and the relay will switch the higher power for the add-on circuit). To figure out if a relay is needed you will have to also figure out how much current capacity you have in the existing circuit that you want to add on to.
Because different car models may have already had some wiring infrastructure in place, there are a lot of variations to the add-on puzzle. Presuming a complete and total add-on, you can either add an auxiliary fuse block or a new wiring harness with a larger fuse block. Painless Performance Products has both types of setups available:
www.painlesswiring.com
Although I have not read them, Painless also has a couple of books that may be helpful as well.
Geez... feels like I've written a novel and I have not even gotten into wire routing or connections or the wonders of loom tubing or...
Steve
Project: '68 El Camino SS 396 clone w/4spd
Daily driver: 2001 Mustang Bullitt
Old 07-23-2004, 04:23 PM
87ElCamino 87ElCamino is offline
Year: 1987
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 560
87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute
Default Re: electrical wiring for dummies
Quote:
Originally Posted by spy007
I haven't messed with electrical stuff too much....I don't know the first thing about adding things to my electrical system...
No offense intended here, but do yourself a favor and get a competent automotive electrical person to do the work. If you mess up you could start an electrical fire and BBQ your nice Elky.
Old 07-23-2004, 04:38 PM
spy007
Posts: n/a
Somehow I don't get the same satisfaction from opening my wallet than I do from learning something new and accomplishing it myself.
Old 07-24-2004, 09:25 PM
Year: 1968
NECOA #: 3296
Amen brother, Amen.
  #8
Old 07-25-2004, 07:38 AM
2-Elkys 2-Elkys is offline
Year: 1971
Region: 13(TX)
NECOA #: 1192
2-Elkys will become famous soon enough
I learned something new from doing my own wiring.
FIREFIGHTER SKILLS!
LOL
Just be carful if you do not know DON'T! wait to ask someone who does know.
71-Elky
Work in progress.. Me and my ElkY!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
wireing diagram for dummies Turbe Region 5 (NC,SC) 1 05-28-2008 10:08 PM
Idiot gauges for dummies? Twilight Fenrir Electrical Systems 3 04-18-2008 11:50 AM
AN for dummies... SickManSeth Brake Systems 1 10-25-2007 05:43 AM
electrical add ons diesel camino Electrical Systems 2 06-25-2007 10:06 PM
changing 83 wiring to non comp. 78-80 wiring lowrider6465 Electrical Systems 5 10-29-2005 03:13 PM
