AC compressor & blower motor not working - El Camino Central Forum : Chevrolet El Camino Forums
Old 08-14-2012, 07:07 PM
TRIK-56 TRIK-56 is offline
Year: 1982
Model: Conquista
Region: 12(MO,OK,KS)
NECOA #: 603
TRIK-56 will become famous soon enough
Default AC compressor & blower motor not working
All of a sudden the AC compressor won't kick in and the blower motor won't work either on my 82 El Camino.
First thing I did was check the fuse. It was good but replaced it anyway. No help.
Replaced the blower motor resistor with a new one after checking the old one which was bad but still no help.
Took the relay off and removed the metal cover, looked ok, not burnt or anything, so I put it back on the car. How can you tell if it's bad?
There is no fan at either low, med., or high speed and AC compressor clutch won't kick in.
Would a bad fan switch on the heater controls prevent all this from working?
I actually took the two switches in the heater control assembly apart. There's really not much to them and I can't really see anything there to go bad. Again, how can you tell if these switches are bad?
What should I check next?
Bobby
56 Chevy 2-door sedan
82 El Camino Conquista
Old 08-14-2012, 07:09 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
power to the relay? and/or to the blower motor?
Don't forget to verify grounds...
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modifications to transmission, #3 son is a trans tech...
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu wagon with 9C1 drivetrain...parts?...or drive?
"Too many parts cars to mention....."
Old 08-14-2012, 09:50 PM
acauth1's Avatar
acauth1 acauth1 is offline
El Camino Central Founder/Administrator/NECOA Board of Directors
Vendor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 124
acauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond reputeacauth1 has a reputation beyond repute
Garage
http://www.elcaminocentral.com/showp...27&postcount=2
Auto A/C & Electrical Shop Owner, ASE Master
If you want a vision of the future, imagine a boot stamping on a human face - forever.
George Orwell
Old 08-15-2012, 08:45 AM
Year: 1982
Model: Conquista
NECOA #: 603
Thanks Robert!
If it is the switch thats bad, which switch are you referring to, the fan switch (one that goes up and down) or the mode selector switch (that goes side to side)?
Old 08-15-2012, 09:04 AM
acauth1's Avatar
Vendor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 124
Garage
Mode switch, side to side.
Old 08-15-2012, 04:23 PM
Year: 1982
Model: Conquista
NECOA #: 603
Robert,
Well, you nailed that one for me! I tracked down that brown wire to the plastic connector and sure enough, it had gotten too hot and melted some of the plastic and corroded some.
What causes it to get hot like that and what can be done to prevent it, anything?
Would an inline fuse be better and if so what amp?
Thanks so much for your advice!
Old 08-15-2012, 05:31 PM
acauth1's Avatar
Vendor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 124
Garage
Worn out blower motors, replace.
  #8
Old 08-16-2012, 06:21 PM
Year: 1982
Model: Conquista
NECOA #: 603
Roger that! I'll check it. Thanks again for your advice!
Quick Reply
Message:
Smilies
Options
Register Now
User Name:
Password:
Confirm Password:
Email Address
Email Address:
Postal Code
Required
Street Address
City
Your city or town
State or Province
Required
Location area within State
Country
Required
NECOA Region
Required
Year of Vehicle
Required
Make of Vehicle
Required
Model of Vehicle
Required
Real Name
Insurance
Log-in
Human Verification
You may post new threads
You may post replies
heat/air blower fan not working TRIK-56 Electrical Systems 13 01-26-2017 05:08 PM
Blower Motor jkwbrown Electrical Systems 17 09-23-2015 06:23 PM
AC Compressor Not Working Gage77 Heating & Air Conditioning Systems 6 04-03-2012 10:24 AM
Ac blower not working iwantthesun Heating & Air Conditioning Systems 6 06-20-2010 02:53 PM
74' blower motor not working... 454COR Heating & Air Conditioning Systems 6 01-17-2008 09:08 AM
