exhaust question - El Camino Central Forum : Chevrolet El Camino Forums
Old 05-18-2003, 10:32 PM
workNprogress workNprogress is offline
Motor Mouth
NECOA #: 885
workNprogress will become famous soon enough
Default exhaust question
Ok since this is my first elkie, I am getting the exhaust put on BEFORE i put the engine in, using same type of manifolds only ones i am using have been polished in the exhaust ports, so....which looks better, exhaust exiting in front of the back tire, or out the back like stock only 1 on each side?
race prepped 350 .040, msd ignition(6-AL, billet distributer, MSD Blaster 2), L-31 vortec's, .488/.488 lift cam, 670 street avenger, air gap intake, roller rocker arms, TH350, 2500 stall, 3.73 gears. Exxon loves me!
Old 05-19-2003, 12:33 AM
airman67 airman67 is offline
Member
Twisted Wrench
NECOA #: 950
airman67 will become famous soon enough
depends on what you like for the most part...
me, i'd go with out the back, but i can see how some side-pipes, like on the early 'vettes would look nice, or a set of ground-effects with a cut-out for the tip would be nice, such as on Eleanor on Gone in 60 seconds, but just having the tips in front of the rear tires.... eh, i don't know about that...
not quite sure, but i think that there might be a problem if the engine isn't in there, don't they usually line up everything by mocking it up?
my $0.02
good luck!
got an '86 El Camino, 4.3L V6, automatic, daily driver, hoping to get more horses out of it soon...
also have a '67 Mustang coupe, soon to have these: 5.8L, 4-spd T-10, nightmist-blue, '68 GT stripes
me
Old 05-19-2003, 04:34 AM
ElkySS's Avatar
ElkySS ElkySS is offline
NECOA Founder
Year: 1987
Model: El Camino SS
Region: 7 (AL,GA,TN)
NECOA #: 1
ElkySS will become famous soon enough
Here's a third option...behind the rear tires: http://www.elcaminocentral.com/modul...view_photo.php
8O
Old 05-19-2003, 08:22 AM
ElkyPete's Avatar
ElkyPete ElkyPete is offline
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
ElkyPete is just really nice
A lot of people got the American Thunder exhaust system from FLow Master. You can get the set up with or without mufflers, in case you don't care for the FlowMaster Brand mufflers.
The system I got was for the 72 Chevelle/El Camino and used it on the 76, and the 80 Elkys. It is a complete header back system 2.5" pipes, mandrel bends and all. They exit out the under the bumper. DynoMax makes an exhaust that exits out the side of the car in front of the tires. DynoMax also make the SidePipes or Lake Pipes as they use to be called.
Tons of options out there if you look around long enough. The AT System from FloMaster cost me almost 300 with the mufflers. Came with everything I needed to hang them and connect them. I had to drill 6 holes for the 4 hangers that was it. On the 76 it took about four hours or so including removing the old exhaust.
Good luck on the hunt!
Home Site:
1972 El Camino Custom 400
1976 El Camino Classic
1980 El Camino Super Sport
E-Mail:
Old 05-19-2003, 12:13 PM
FlyMX93 FlyMX93 is offline
Member
Twisted Wrench
NECOA #: 961
FlyMX93 will become famous soon enough
Would the flowmaster system really fit '78-87 el caminos? how does this system handle the transmission crossmember that is usually a problem with dual exhuast on 78-87?? ive been looking for a good exhaust for my 78 for a while, but my local shop quotes me at $450-550
'78 El Camino
Old 05-19-2003, 12:29 PM
Elcaminonyc's Avatar
Elcaminonyc Elcaminonyc is offline
Year: 1985
NECOA #: 866
Elcaminonyc has a spectacular aura about
The crossmember has always been an issue for a true dual exhaust---I just bought a crossmember from G-force with a double hump for the exhast--it is the second one I have purchased and the part is outstanding --check it out on the net or the home page here---it is outstanding-Pete NYC
Old 05-19-2003, 01:50 PM
87ElCamino 87ElCamino is offline
Year: 1987
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 560
87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute87ElCamino has a reputation beyond repute
Quote:
That's how my 87 is, but the pipes exit on a 45 degree angle. If you're going to go with true duals, buy the www.crossmsmbers.com transmission crossmember. I've bought three of them and as Pete said "...it is outstanding". (They also sell dual exhausts)
Then bring your Elky to a good muffler shop and have them bend up a custom aluminized dual exhaust for you.
  #8
Old 05-19-2003, 06:18 PM
ElkyPete's Avatar
Venerated Member
Year: 1980
Model: El Camino SS
Region: 13(TX)
NECOA #: 3
I am pretty sure if you go to the bone yard you can use a cross member out of a 73 or earlier Chevelle, El Camino or Station Wagon and they are dual hump. However, I also got a cross member at G-Force. ** Just didn't want to be different! 8O
Not really I had to get a different cross member I went to a 700R4 tranny and didn't want to go through figuring out the new mount points etc... So I bought one that is a direct bolt on. They are really good, probably out last the truck.
  #9
Old 05-31-2003, 01:01 PM
JIM '79 TPI JIM '79 TPI is offline
Junior Member
Gear Head
NECOA #: 1004
JIM '79 TPI will become famous soon enough
IY REALLY DOES DEPEND ON YOUR TASTE.GENERALLY ANYTHING IN FRONT OF THE TIRES WILL BE LOUDER,BEING CLOSER TO THE DRIVER. OUT THE BACK WON'T BOUNCE OFF CURBS,BRIDGES ETC.IT MAKES IT HARDER TO HEAR THOSE 20 SOMETHING YEAR OLD GREMLINS THAT WAKE UP FROM TIME TO TIME.I'VE HAD BOTH,BUT REALLY LIKE THEM BEHIND THE TIRES.WE 'RE ALL DIFFERENT WITH DIFFERENT TASTES,THATS WHAT MAKES THIS GREAT! GOOD LUCK !!
You can get more with a kind word + a gun,than with a kind word. Al Capone
You may not post new threads
You may not post replies
another exhaust question MFOX Performance Modifications 8 03-14-2005 07:23 AM
Exhaust question 82 meeno Region 8 (OH,WV) 3 10-13-2004 05:42 AM
Another Exhaust type question Kool177 Performance Modifications 1 12-27-2003 07:28 AM
Another Dual Exhaust Question. Kool177 Performance Modifications 4 12-26-2003 06:37 AM
Dual Exhaust question. Kool177 Performance Modifications 7 06-16-2003 12:14 PM
