Sub install - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-02-2012, 01:12 AM
ShadowElky ShadowElky is offline
Year: 1984
Region: 14(AR,LA,MS)
NECOA #: 18803
ShadowElky will become famous soon enough
Default Sub install
Anyone know if I can safely run two 200 watt rms 4ohm subs wired in parallel (making it 400 watts at 2 ohms) on a 500 watt rms 2 ohm amp? Its a monoblock amp with one set of speaker outs but I can wire both subs to it in parallel as stated above. Anyone have suggestions or tips?
Sent from my DROID RAZR using AutoGuide.Com Free App
1984 El Camino: Crate 350, quadrajet off of a 79 'Vette with a 1" 4-hole spacer, all emissions removed, shorty headers to 2.5" side pipes, A/C removed.
Old 12-02-2012, 05:49 AM
suks2bu37's Avatar
suks2bu37 suks2bu37 is offline
Year: 1986
Region: 12(MO,OK,KS)
NECOA #: 20775
suks2bu37 will become famous soon enough
Garage
Should not be a problem. I have two JL 10's wired in parallel to a Fosgate 600 watt amp in bridged mono. Works great!!!
suks2bu37
Old 12-02-2012, 03:11 PM
Year: 1984
NECOA #: 18803
The amp peaks at 1000 watts but the subs each peak at 400 watts. That wont cause problems?
Old 01-17-2013, 10:47 AM
dazadi85 dazadi85 is offline
Junior Member
NooB
Year: 1985
Region: 3 (DE,NJ,PA)
NECOA #: 23275
dazadi85 will become famous soon enough
Sub for info.
Old 01-17-2013, 10:51 AM
Ductape's Avatar
Ductape Ductape is offline
Motor Mouth
Year: 1979
Model: Caballero
Region: 16(CO,MT,WY,UT)
NECOA #: 18375
Ductape is a jewel in the rough
it souldnt be a problem, just be sure to not turn the gain up all the way on the amp if its 1000w and the subs peak at 400w, I'd put the amp gain at just under half way, or right at half.
Old 01-17-2013, 11:22 AM
Year: 1984
NECOA #: 18803
Default Re: Sub install
Went with a pair of 8" Lanzar MAXP84's with 800 watt peak. Hooked them up as a 2 ohm load. They hit harder than my 12 with less of a power draw. On some songs though the dust cap does get rather warm. Gain is almost all the way down. But the LPF is also set at about 50 hz. Can't touch the bass boost.
Old 01-17-2013, 05:15 PM
spencersr spencersr is offline
Year: 1984
Model: El Camino SS
NECOA #: 20960
spencersr will become famous soon enough
What type of amp? And you go by rms on speakers not peak
  #8
Old 01-17-2013, 05:49 PM
Year: 1984
NECOA #: 18803
Kenwood 8105D monoblock.
  #9
Old 01-17-2013, 06:53 PM
Year: 1984
Model: El Camino SS
NECOA #: 20960
Its a little big for those speakers just keep the gain low though and you shouldn't have problem. If your like ne nothing is ever loud enough or fast enough
  #10
Old 01-17-2013, 06:56 PM
Year: 1984
NECOA #: 18803
Being that the amp is a 500 watt rms at 2 ohms and the subs are 250-400 watts rms each (cant remember which cause lanzar makes 2 different 8" subs), the amp is equal if not slightly underpowered for them. They are wired to a 2 ohm load.
You may not post new threads
You may not post replies
Got Everything Done On the Cam Install 5thGenBoyz Performance Modifications 0 11-29-2012 06:57 PM
How do these install?? Jack_K Interior Restoration 10 08-08-2012 12:09 PM
Lt1 install taz575 LT1/LS1/EFI Tech 0 01-16-2012 07:53 PM
Where to install the PCM gheck LT1/LS1/EFI Tech 6 01-18-2010 01:29 PM
install new A/C Rufh0use Heating & Air Conditioning Systems 5 02-01-2008 05:10 PM
