Speaker wall - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-19-2012, 04:50 PM
Bruiserman's Avatar
Bruiserman Bruiserman is offline
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23122
Bruiserman will become famous soon enough
Garage
Default Speaker wall
Almost ready to put in my speaker wall. Amp is all that is left to put on and wire in. Should have it all set up tomorrow.
Old 12-19-2012, 04:52 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 is a glorious beacon of light
Garage
Looks great can't wait to see it installed.
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
Old 12-19-2012, 07:03 PM
LittleManRestos's Avatar
LittleManRestos LittleManRestos is offline
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
LittleManRestos will become famous soon enough
Looks great.Im building a wall for my 5th gen. I like the idea of the subs integrated into the wall but i dont think my 10" subs will fit. Im also running deep dish 6x9s in it. Ill have photos up once my interior is done since everyone wants to see what ive done
Old 12-19-2012, 08:24 PM
Bruiserman's Avatar
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23122
Garage
How many are you using, that's a 10" in there and could have done two easily but don't need that much for my taste. I wanted one twelve but wasn't going to fit as nicely.
Old 12-19-2012, 08:36 PM
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
i have 2 kicker comp 10''s that are deep. I think im going to build the wall out so i can run my 6x9s in there as well cause as of now im planning on doing seperate boxes for the 10s and putting my 2 amps and 6x9s on the wall. I have 4 point harness bucket seats so im gonna have a mounting bar behind the seats so that cuts a little room out. My 6x9s are about 5'' deep if not a little more. I also thought about just doing the 10s on the bottom and fiberglass the 6x9s out so they pop while still having the wall flush if that makes sense
Old 12-19-2012, 08:37 PM
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
The air space required for the subs are in a closed box 12x12 ,12x12.5, 13.5x12.5 so just over a foot cubed
Old 12-20-2012, 02:27 AM
Papasdoo's Avatar
Papasdoo Papasdoo is offline
Member
Loose Nut
Year: 1972
Region: 9 (IN,KY,MI)
NECOA #: 21783
Papasdoo will become famous soon enough
Nice work ive got one ten in my dd its a 06 hhr plenty of kick for most people
  #8
Old 12-20-2012, 04:08 AM
woody31's Avatar
woody31 woody31 is offline
Year: 1981
Region: 13(TX)
NECOA #: 14520
woody31 is just really nice
Garage
Looks nice...
hey yall,,,watch this...
  #9
Old 12-20-2012, 07:34 AM
Scottm's Avatar
Scottm Scottm is offline
Site Contributor
Year: 1977
Model: El Camino Classic
Region: 13(TX)
NECOA #: 22827
Scottm will become famous soon enough
Garage
Looks great. I enjoy the one my PO installed. It's more than enough.
Good work.
Farpotshket (Yiddish)
Something that is all fouled up, especially as the result of attempts to fix it–repeatedly making something worse while trying to fix it.
  #10
Old 12-20-2012, 01:53 PM
Bruiserman's Avatar
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23122
Garage
Alright, got it in. Here are the pics. @Littlemanristo I have buckets with harnesses as well, no bar though. You can see the back of the center console too. Had to remove it to get it in but not a big deal.
  #11
Old 12-20-2012, 02:02 PM
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
that looks really good i think im gonna do something simular. but i think im gonna do a harness since im making like a pro street and wanna have it as safe as possible. your wall looks good. im gonna angle my box out though so it the subs face up a little and my deep 6x9s fit. i got 12 sq ft of dynamat for $30 if you know someone that works at best buy they get great discounts
  #12
Old 12-20-2012, 02:32 PM
30Weight's Avatar
30Weight 30Weight is offline
Year: 1987
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 20717
30Weight will become famous soon enough
Looks great! Really complements the interior theme.Oughta sound good without the bench seat to muffle it.Buckets will make for a far better soundstage.I noticed the difference that made in mine.Nice work,congrats!
Currently Celebrating 40 yrs of Vehicular Projects.....
'71 Jensen Interceptor MK2,just finished restoration
'88 Porsche 928 S4,5 spd,upcoming supercharge project
'77 VW Beetle,extensively modified,the "Volks-Carrera"
'65 Land-Rover Series 2A,V8 equipped,expedition prepared
...and some others swimming in the motor pool.
  #13
Old 12-21-2012, 10:25 AM
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
Would you happen to have dimensions for the seat brackets for your racing seats
  #14
Old 12-21-2012, 12:28 PM
Bruiserman's Avatar
Member
Loose Nut
Year: 1979
Region: 6 (FL)
NECOA #: 23122
Garage
Actually, the PO put the seats in and made his own mounts. From what I can tell he made a box and mounted the sliders directly to that and then bolted the box down. I'll be removing the driver side soon so I can get the seat to adjust forward a little more so if you want some pics of the setup I could do that. Might be a few days though.
  #15
Old 12-21-2012, 02:44 PM
Member
Knuckle Buster
Year: 1980
Region: 13(TX)
NECOA #: 23135
Yea that will be great thanks for the knowledge. Im thinking about usin g the existing studs and making like a bench seat bracket that goes all the way across and using the bars that go over the trans hump to make a custom fabed conceal
You may not post new threads
You may not post replies
My Red Wall thosemillerboys Audio 24 03-01-2013 07:00 PM
'72 Rear Cab Wall MI2600 Interior Restoration 3 07-22-2012 10:09 AM
wall light Paulie's El camino Interior Restoration 3 01-27-2012 07:57 PM
Ok, help me off the wall 74 chick Engine Topics 18 09-02-2010 04:48 AM
Fire wall hardware on 72 SJC3087 Heating & Air Conditioning Systems 6 09-23-2004 10:13 AM
