LS2 in 1985 elco - El Camino Central Forum : Chevrolet El Camino Forums
Old 12-22-2012, 09:11 AM
Airman Haas's Avatar
Airman Haas Airman Haas is offline
Member
Knuckle Buster
Year: 1985
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 20798
Airman Haas will become famous soon enough
Garage
Default LS2 in 1985 elco
I recently purchased an Ls2 out of an 05 GTO with auto transmission, all belt driven accesories, wiring, ecm, etc., i am wondering what all i need to do to get this engine in. I know i need to customize my speedo and if anyone has any advice on that i would be greatful.Fuel tank i know will have to be swapped or fab'd to fit a fuel pump, has anyone done a swap similar to this that could share some info. Can i use the ECM and wiring from the GTO or will i need to get something new, also will the stock ls2 manifolds need to be swapped out. This will be my first engine swap into a car the engine was not designed for so any help i can get will be greatly appreciated
-1985 El Camino SS
-1969 Mustang coupe
Old 12-22-2012, 10:17 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
Been done a bunch of times, so sure you can get the help you need.
Here's a good thread to read ( if you've got time!). Will probably answer most if not all of your questions.
http://www.montecarloss.com/communit...=860328&page=1
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 12-22-2012, 10:22 AM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
jlcustomz has a spectacular aura about
There is someolder info on this site,ls1 tech.com has a conversion section that has a g-body thread. I also posted a pretty good swap book here.
With these kind of swaps ,there are many different options for most every issue, Different fitting positions, & many you can either buy or fab your way out. There is a tank swap thread by ccc here I reccommend,I'll eventually do it to my 2002 install. Harness can be modified by you or a shop to add on to existing vehicle with a few wires OR buy new swap harness such as from speartech. I went all aftermarket gauges in mine, set tach on 4 cyl, speedo was programmable.Mot sure about your manifolds, Long tube headers are best. there are swap models,& many use 4th gen f-body headers, all with different results. Pretty sure your pan CANNOT work, there are now factory style muscle car pans. I notched & reboxed for my f-body pan & ac low mount setup. Not familiar with gto mounts. Other info sources are Street & Performance, Retro lsx, Howell, BRP, Holley.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
Old 12-28-2012, 12:01 PM
Member
Knuckle Buster
Year: 1985
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 20798
Garage
thank yall for the information, currently deployed to afghanistan so i will not be starting until i get back but i will post updates and pictures of the progress once i get started
Old 12-28-2012, 04:03 PM
darbysan's Avatar
Year: 1985
Region: 17(NV)
NECOA #: 910
THANKS for your service When you get home, we'll all be ready to jump in and help get you the info to build your ride the way you want it.
Old 01-01-2013, 07:48 PM
greywolf greywolf is offline
Year: 1984
Region: 12(MO,OK,KS)
NECOA #: 64
greywolf will become famous soon enough
I also put in a Caprice wagon gas tank, worked like a charm. If you happen to get a tank and sender from a TBI car (didn't know they came that way), the higher pressure pump for fuel injection will slip right onto the sender in place of the TBI pump.
Old 01-15-2013, 10:03 AM
Member
Knuckle Buster
Year: 1985
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 20798
Garage
Anyone have any suggestions for an Air Intake?, i found a swap kit on eBay with engine mounts, Long tube headers, and an oil pan that you can use together that u do near to none fab work to get the engine in, im gonna try and get a 92-96 caprice tank from a salvage yard as mentioned in CCC's thread, as well as putting a ford 9" rear with disk brakes and either a 3:46 gear ratio or 3:73, still deciding how to do the guages and will have to get a custom drive shaft i imagine, cant wait to get this project started
  #8
Old 01-15-2013, 04:04 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
You could make an intake like mine in your spare time.
http://hooniverse.com/2012/11/29/tru...tion/pict3763/
Or you culd use some type of 4" tubing. if you want to just buy something, check Spectre.
My first ls1 intake was black abs drain pipe from lowes. Used a 90* angle & a straight section. took some grinding to fit maf sensor. sanded off letters & polished plastic so no one knew it was drain pipe.
  #9
Old 01-16-2013, 03:52 AM
Member
Knuckle Buster
Year: 1985
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 20798
Garage
im also trying to find some dimensions or pictures on the notching of the frame required to use the stock ac compressor, i have an aftermarket pan so i wont need to notch anything for that if anyone has any insight let me know thanks
  #10
Old 01-17-2013, 04:23 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
I now have the sanden 508 compressor with brp mounts, fits looser to frame than larger factory compressor.Much more reliable also, I wouldn't waste freon on a factory compressor again. The gto setup may be different, may even be better compressor than my 99' was.
Ls1 installs can sit in variable locations, you probably will have to test fit before cutting.
  #11
Old 01-30-2013, 05:52 PM
Bonez84 Bonez84 is offline
Member
Knuckle Buster
Year: 1986
Region: 6 (FL)
NECOA #: 16737
Bonez84 will become famous soon enough
Garage
Best of Luck with the project, I hope to be doing somewhat of the same engine mod real soon.
  #12
Old 02-28-2013, 01:32 PM
Elke87Vette62 Elke87Vette62 is offline
Junior Member
Twisted Wrench
Year: 1987
Model: Conquista
Region: 8 (OH,WV)
NECOA #: 20697
Elke87Vette62 will become famous soon enough
Garage
Default LS2 swap.
I just posted an album with pictures on an ls1 swap into an 87. I didn't have any problems. They were able to use the original wiring harness with a few mods. The engine was out of a 2000 corvette and was purchased from Fparts in Bristol Pens.
They are right about alot of them have been done. U won't have any problem getting any information. I ended up using an oil pan out of a cadilac ctsV.
  #13
Old 02-28-2013, 02:26 PM
EL S ONE's Avatar
EL S ONE EL S ONE is offline
Year: 1987
Model: El Camino SS
Region: 18(CA)
NECOA #: 10110
EL S ONE will become famous soon enough
Airman Haas, This site might be of some help. Terry
http://www.montecarloss.com/ls1montecarloss/index.html
Original owner. "04" LS1.Built 4L60E. GN 8.5 3.73's. Eaton posi. Dual 2.5 Tubes,"H"pipe & Flowmaster 50's.Full SC&C suspension.C-5 brakes. Electric antenna. Zinc plated Spurving bearings.Maggy. C.A.R.B approved
  #14
Old 03-02-2013, 08:28 PM
Member
Knuckle Buster
Year: 1985
Model: El Camino SS
Region: 4 (MD,VA)
NECOA #: 20798
Garage
Thanks again everyone for your help, im nearing the time that i get to leave this place and go home to begin working on my elco, im excited, i was wondering if anyone had any suggestions for radiator hoses, im using the radiator that autozone sells for the 85 el camino which has the stock placement for hoses im pretty sure, i need to find out what are the best hoses to hookup to my ls2 or if im going to have to get custom flex hose
  #15
Old 03-02-2013, 09:09 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
On my ls1 swap with factory rad, I hand picked hoses at an auto parts store with old hoses& a tape measure estimating what I needed. Trimmed ends to fit. When I later dropped my radiator mounting 2", I used1 1/2" stainless pipe(bathroom handrail from home depot) to extend between the 2 sections.
You may not post new threads
You may not post replies
1985 corvette in an 84 elco tjb49 Engine Topics 3 11-16-2011 09:07 AM
sub box for an 1985 mrccustoms Audio 7 11-02-2010 07:22 PM
Hi from a "new" old member-71 Elco & 87 Elco SS (pix) lilbaggie For New Forum Members Only 13 05-20-2010 07:32 AM
1985 elco Reazon Electrical Systems 2 03-17-2007 08:22 PM
Wanted: 1985 elco front end parts merc62 Wanted Items 2 12-23-2006 09:02 AM
