scored a big block - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-02-2013, 04:10 PM
pongo's Avatar
pongo pongo is offline
Deputy Director, Region 7 - Participating Member
Year: 1978
Model: Conquista
Region: 7 (AL,GA,TN)
NECOA #: 10091
pongo will become famous soon enough
Default scored a big block
I did some trading around with a friend of mine, and got me a 1978 1 ton dump bed chevy truck with a good running 454. Looks like a good engine swap for my 78 Camino, it is even has the same date code as my factory 350. What I have read about these truck motors is that they have crappy heads on them, I read that they flow just a little more than a 350 head, and have less than 8 to 1 compression ratio. So what do I need to do to this motor to make it come alive on a budget? Don't want anything radical, just something that sounds good, can run all day on the interstate, and show up the local youth with there modern muscle.
Put God first, and everything else will find it's place.
Old 01-02-2013, 04:21 PM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
Most likely it has the small peanut heads,, good for what you are doing,, I would bore it to clean up the cylinder walls,, the rods are a weak link but if you keep it down to a mild roar they are OK,, but I would put a good set of rods it may have a steel crank from the factory,, a fresh regrind,, the heads,, I would keep the peanut heads, I am not fimilar with the valve size but I would go with bigger valves and a lite port job,, good intake and ignition and you will need a new HD rear end,, 454 = torque monster!!!!!! Matty man
Old 01-02-2013, 04:23 PM
Keyser Sose's Avatar
Keyser Sose Keyser Sose is offline
Year: 1983
Model: El Camino SS
Region: 8 (OH,WV)
NECOA #: 15853
Keyser Sose is a name known to all
X2 on what Matty said.
but then, what's the odds that someone could make an ol' wore out truck motor run good?
WHEN YOU KNOW WHAT THE MAGICIAN KNOWS, IT'S NOT MAGIC ANYMORE!
Old 01-02-2013, 04:25 PM
jlcustomz's Avatar
jlcustomz jlcustomz is offline
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
jlcustomz has a spectacular aura about
On a budget ,a mild cam along with new timing chain,etc ,aluminum intake (keep the quadrajet) would be first up along with decent headers. If you think you have the skillset to do just a mild porting job on the heads, this would be my next budget reccomendation, a shop could disassemble & clean them for you to do your part, then do a 3 angle valve job & reassemble them . On a poor flowing set of large heads, it wouldn't be too hard to make an improvement.
With a high torque motor & a fairly small for it cam, you can make plenty of street power without reving it to much & needing expensive internals.
No true hot rod is ever finished. If it doesn,t command respect, fear will do.
Old 01-02-2013, 04:34 PM
pongo's Avatar
Year: 1978
Model: Conquista
NECOA #: 10091
ya'll make my small block build sound better already. Will probably just fix front brakes on the truck and sell it.
Old 01-02-2013, 04:44 PM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
Those Rv/Truck big blocks don't like the RPMs, but man if you push one you'll never go back!!!
(Click da pic)
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
Old 01-02-2013, 04:45 PM
jlcustomz's Avatar
Year: 1983
Model: Caballero
Region: 6 (FL)
NECOA #: 19307
Don't wimp out yet, Ever watch any of DDD's video's with the yeller big block he just sold?
EDIT,Donny typed faster than me, there you go.
  #8
Old 01-02-2013, 06:07 PM
Year: 1975
Region: 9 (IN,KY,MI)
NECOA #: 13978
One thing you may have to address is the drive train.....trans and rear end. Even a wimpy 454 has torque.
AKA Pila
El Camino resto
The Malibu
  #9
Old 01-02-2013, 06:25 PM
30Weight's Avatar
30Weight 30Weight is offline
Year: 1987
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 20717
30Weight will become famous soon enough
I'm sure someone here knows more about it than I do,but was told years back that the bigger truck engines were quite a bit different than the passenger car/light truck engines.Was looking into a BBC swap into a Jaguar XJS many,many years back and the kit supplier specifically warned against the truck engines.I remember something about the block being significantly taller,or wider (?) and wouldn't fit.Passenger car/light truck big blocks would.Might have been the 427s,can't remember.I could be wrong,wouldn't be the 1st or last time.Might want to check the dimensions before you get to far into it.
Currently Celebrating 40 yrs of Vehicular Projects.....
'71 Jensen Interceptor MK2,just finished restoration
'88 Porsche 928 S4,5 spd,upcoming supercharge project
'77 VW Beetle,extensively modified,the "Volks-Carrera"
'65 Land-Rover Series 2A,V8 equipped,expedition prepared
...and some others swimming in the motor pool.
  #10
Old 01-02-2013, 11:17 PM
1983SS454's Avatar
1983SS454 1983SS454 is offline
Year: 1983
Model: El Camino SS
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 13734
1983SS454 has a spectacular aura about
The biggest problem with he truck motors is the low compression and the small cam. The peanut port heads make great street torque, they are what I run on my engine at this moment with a port job and larger valves. Bump the compression up from 8 to 1 to 9.5/10 to 1, get the stock rods shot peened and some arp studs and that's how I would go about it. Mine was a complete overhaul from top to bottom because I wanted it capable of running a 100-200 N20 shot......
The transmission if running behind a decent small black should last for some time as long as your not too abusive and the rear will be ok with an automatic trans and no sticky tires for a long time. Manual trans and sticky tires and those 7.5 rears won't last long behind a big block
Sent from my iPhone using AutoGuide.com App
"El Camino- the mullet of cars.... All business up front, and party in the back!"
1983 El Camino SS, 468 BBC, Muncie 4 speed, Quick performance 9" rear end[SIGPIC]http://i682.photobucket.com/albums/vv188/abigda/tonyspics009-1-1.jpg[/SIGPIC]
  #11
Old 01-03-2013, 01:15 AM
Year: 1975
NECOA #: 13978
The 427 truck engine is a tall block. Not sure about the 454.
  #12
Old 01-03-2013, 05:29 AM
boogsawaste boogsawaste is offline
Year: 1981
Model: Caballero
Region: 3 (DE,NJ,PA)
NECOA #: 22119
boogsawaste will become famous soon enough
Garage
I agree with steely on the 427's in trucks being a tall deck. Haven't heard of the 454's being that way but I can definitely be wrong. If it were me I would google it and see what comes up.
  #13
Old 01-03-2013, 07:30 AM
pongo's Avatar
Year: 1978
Model: Conquista
NECOA #: 10091
I know the torque of the BB is awsome, but I love to hear a small block wind up. What kind of max rpm's will the stock bottom end handle? I have always been a small block guy, and with out sounding like I am bragging, have wooped up on a bunch of big blocks, maybe thats just because I know what it takes to make a small block go. But the looks and sound of a big block does sound very good to me. I know about the trans and rear end issues, and will have that covered either way I go. What I am looking for out of my Elky is a high 12 to low 13 secound car, like my Nova's I had in my younger years ran. That is good for fun, and reliable enough for daily driving. Maybe a mild BB will get me there.
I have a 300 hp 327 on my engine stand right now that I am tinkering with, may have to put it on hold, and do some research on thid BB project.
  #14
Old 01-03-2013, 07:58 AM
1983SS454's Avatar
Year: 1983
Model: El Camino SS
NECOA #: 13734
427's have 2 different styles, tall deck and short deck, a 454 tall deck is basically what the 502 ends up being...... I run my engine with the stock forged crank and shot peened rods with arp studs to 6000k, not all the time time but I'll run her up there. I'm chipped on my ignition for a little over that with the rev limiter
  #15
Old 01-03-2013, 08:35 AM
jkk's Avatar
jkk jkk is offline
Year: 1967
Region: 13(TX)
NECOA #: 21960
jkk will become famous soon enough
Garage
Man rebuild it put it in and start looking for rear tires that are on sale!!
1967 - GM ZZ 383 700R4 12 BOLT 3.73 POSI . Ranchero Eater!
My motor can out run your stereo
You may not post new threads
You may not post replies
MT spies have scored again!! Keyser Sose General BS Topics 6 11-09-2012 02:23 AM
Scored a 73! Flügelwagen For New Forum Members Only 21 08-07-2012 10:03 PM
Scored Like a Bad boy Today ! redflash Brake Systems 2 02-03-2011 05:22 PM
Scored a $20 Elky! FIRST ELKY 4 ME General BS Topics 32 03-13-2010 04:50 PM
Scored a 400 today! texaselky Engine Topics 2 11-20-2008 06:17 AM
