electronic carb puking excess fuel...please help!! - El Camino Central Forum : Chevrolet El Camino Forums
Go Back   El Camino Central Forum : Chevrolet El Camino Forums > Drivetrain & Performance > Engine Topics
Old 01-05-2013, 08:37 AM
Blue 81's Avatar
Blue 81 Blue 81 is offline
Junior Member
Twisted Wrench
Year: 1981
Region: 6 (FL)
NECOA #: 23293
Blue 81 will become famous soon enough
Exclamation electronic carb puking excess fuel...please help!!
ok, so the other day i drove my 81 el camino to the store and back before work. it drove just fine with no warnings of any sort. an hour later left for work and just around the corner from my house she stalled out and would not crank back over. the engine would turn and turn and turn but not crank. I checked for spark and had no spark. had the coil and module test and both were good but still no spark. so i swapped out the entire distributor with the one from my 305 getting ready to go in.(currently a 229 original engine under the hood.) i just placed the V6 componetes on top (cap, rotor, module, and coil). now i have spark and the engine was brought to tdc when i dropped in the new distributor. but she still will not crank and my electronic carb pukes excess fuel like it is flooding its self. any ides?
Old 01-05-2013, 09:34 AM
ccc's Avatar
ccc ccc is offline
Year: 1986
Model: El Camino SS
Region: 19(AK,ID,OR,WA)
NECOA #: 21252
ccc is just really nice
i had the same carb issue once,the charcoal canister went bad and filled the carb with the charcoal and kept the float down.. you need to see what is causeing the carb to flood.did you replace the entire dist or just parts? did it have spark when re installed.did you check the carbon button in the cap?
Old 01-05-2013, 09:46 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
Welcome to the site, Ron. Sounds like you have two distinct issues.
The carb flooding could be 1) too much fuel pressure ( only an issue if you've recently installed a HP fuel pump. 2) Dirt stuck in the float pin, keeping the pin from seating. 3) Float itself is saturated with fuel, and is keeping the pin open. 4) Continued cranking , pumping the peddle trying to start, will cause it to flood as well. #3 or #4 is the most likely, #3 especially if it hasn't been replaced.
The no spark sounds like an electronic module issue. Even though they test good, they can still become intermittent. When I have mine tested, I always ask them to test it 4-5 times, so they get hot. Also, be sure to install the module with Heat Sink compound ( not dielectric grease). Also make sure the coil ground loop is in place. If electronic module is good, ECM could be bad, or the connections to the ECM could be loose. Have you pulled any codes?
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 01-05-2013, 09:51 AM
Blue 81's Avatar
Junior Member
Twisted Wrench
Year: 1981
Region: 6 (FL)
NECOA #: 23293
i changed the fuel filter the day before it stalled out. and when it would turn but not crank i discovered no spark and swapped the entire distributor which allowed me to have spark. and thats when it started puking fuel without out pumping the pedal. just everytime you turn the key.
Old 01-05-2013, 11:07 AM
JJLT1's Avatar
JJLT1 JJLT1 is offline
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
JJLT1 is a jewel in the rough
i'd say check the timing first,,
but?? would the v6 and a v8 reluctor and phasing be the same??
JJ
85 SS LT1 383 4L60 8.5 3.73
Old 01-05-2013, 08:41 PM
Blue 81's Avatar
Junior Member
Twisted Wrench
Year: 1981
Region: 6 (FL)
NECOA #: 23293
both distributors are HEI and lower halfs are the exact same
Old 01-05-2013, 10:23 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
i think?? because i dont know for sure???? (i dont know nuttin about v6's)
you would have to change the distributer shaft/reluctor and pickup coil,, maybe the module??
to the odd fire v6 stuff for it to work right???
heres a thread that talks about it some..
hope that helps a little..
Quote:
Quote:
Couldnt you just get an HEI from any SBC
Quote:
or BBC? Dime a dozen, I had several laying around. A 4.3 is basically a 350 minus 2 cylinders so unless there is something I dont realize, I dont see why a chevy V8 distributor wouldnt work to get rid of those nasty points.
[/COLOR]
We are talking about a V-6 and the SBC dizzy would fire 8 times. To the best of my knowledge even if you put the 6 cyl cap on the internals still have 8 pickup points so it would not work unless you also change the internals which would make it not practical.
link to thread http://www.hotrodders.com/forum/iden...3l-175081.html
[/COLOR]
  #8
Old 01-06-2013, 07:25 AM
jojothetattooboy's Avatar
jojothetattooboy jojothetattooboy is offline
Motor Mouth
Year: 1981
Model: El Camino SS
Region: 10(IL,MN,WI)
NECOA #: 22672
jojothetattooboy will become famous soon enough
Garage
This is true! The reluctor's are different.
  #9
Old 01-07-2013, 01:48 PM
JJLT1's Avatar
Year: 1985
Model: El Camino SS
Region: 13(TX)
NECOA #: 12122
hey Blue
did you get it going??
You may not post new threads
You may not post replies
Removing Electronic Carb and distributor cruisincarlo Engine Topics 1 08-03-2008 09:13 AM
electronic feedback carb on 267cid v8 romer4 Engine Topics 3 03-25-2007 11:45 PM
Electronic Carb Upgrades? cudacoupe General BS Topics 9 11-09-2004 04:32 PM
Puking Tranny Fluid mojowrkn Transmission & Drive line 8 03-09-2004 01:12 PM
Electronic carb control Skullzz13 Electrical Systems 9 05-27-2003 10:02 AM
