Penitrating oils - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-05-2013, 12:21 PM
ole george ole george is offline
Motor Mouth
Year: 1972
Model: El Camino SS
Region: 9 (IN,KY,MI)
NECOA #: 11760
ole george will become famous soon enough
Default Penitrating oils
A Machinist's Workshop magazine recently published this info on penitrating oils
OIL AVE TORQUE TO LOOSEN
NO OIL USED 516#
WD-40 238#
PB BLASTER 214#
LIQUID WRENCH 127#
KANO KROLL 106#
ATF*-ACETONE MIX 53#
The ATF-ACETONE mix is a home brew mix of 50-50-automatic transmission fluid and acetone. Laquer thinner can be substituted acetone.
I don't know how scientific the tests were but I thought quite interesting. Has anyone used the ATF mix?
72 ELKY in Arizona
79 ELKY in Michigan
Old 01-05-2013, 12:53 PM
Dimitri13's Avatar
Dimitri13 Dimitri13 is offline
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
Dimitri13 will become famous soon enough
WD-40 isn't a penetration oil, it's a lubricant.
I've used both PB Blaster and Liquid Wrench, both work just as effectively.
The ATF/acetone mix is what guys use to unstick rusted cylinders. May take a couple weeks or even longer, plus heat cycling, but it usually produces favorable results. As for the mix on stuck bolts, never really had to try it. Usually an off-the-shelf penetrating fluid and sometimes some heat, plus an impact driver/hammer (ALWAYS) will do the trick.
I've undone just about every rusty and stuck bolt on my 40-year old motorcycle and have only had to slot or dremel 3.
Old 01-05-2013, 01:03 PM
1980project17's Avatar
1980project17 1980project17 is offline
Member
Twisted Wrench
Year: 1980
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17116
1980project17 will become famous soon enough
I've heard about the mix, but never tried it myself I have a friend of mine that swears by it, I stick to my cans of pub blaster, it works good enough for me.
Old 01-05-2013, 01:07 PM
Beepster's Avatar
Beepster Beepster is offline
Silver Contributor
Year: 1987
Model: El Camino SS
Region: 13(TX)
NECOA #: 20479
Beepster is a jewel in the rough
Acutally, WD40 isn't a lubricant, it's water displacement (Hince the WD). I've used Kroil Oil, and it's very good, better than PB Blaster of Liquid Wrench, but I also use both of those for different projects.
Bruce
'87 Elkie: 350CID; 700r4; B&M shifter; buckets; AC; PS; PB; PW; PL; PM; Sony Blutooth; Kenwood rear spkrs.
'56 Chevy BelAir: 350CID; 5-spd Tremec; AC; PS
'10 VW Jetta: 2.5L, 5-cyl; 6-spd auto; AC; PS; PB; PW; PM; PL.
Old 01-05-2013, 01:12 PM
Dimitri13's Avatar
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
Ah my bad on that. I've never heard of, or seen in stores, Kroil Oil. I'll keep an eye out for it, since I'm frequently trying to turn rusty bolts.
1977 El Camino Classic - Acquired 1/3/13
Build thread:
1973 El Camino SS - Acquired 4/13/13
Old 01-05-2013, 01:22 PM
LOCKJAW's Avatar
LOCKJAW LOCKJAW is online now
Year: 1964
Region: 6 (FL)
NECOA #: 19368
LOCKJAW is just really nice
Garage
Call it whatever you want, but WD-40 is a great product that can be found in most locksmith's tool tray. Countless service calls for jammed, stuck or frozen locks and panic exit devices over my 40 year career were quickly solved with a squirt of WD-40 in the right spot. It helps free up, clean and lubricate any mechanism. I believe it is kerosene based. I have found nothing to replace it.
To Err Is Human, To Forgive Is Divine...Neither Is Marine Corps Policy!
It's hard to function while constantly doubting the validity of my previous thought.
1964 restomod. Wht/red, ZZ4 w/ mods, Muncie , QFT, Hookers, Flowmasters.
Old 01-05-2013, 02:05 PM
number9 number9 is offline
Year: 1969
NECOA #: 13389
number9 will become famous soon enough
This stuff is a great penetrant too:
  #8
Old 01-05-2013, 02:34 PM
zero's Avatar
zero zero is online now
Year: 1971
Region: 5 (NC,SC)
NECOA #: 14466
zero will become famous soon enough
Garage
Quote:
http://images.lowes.com/product/conv...45324779lg.jpg
Sometimes you just can't beat the Blue wrench!!
71 El Camino Custom / Restomod
02 Subaru Impreza WRX
  #9
Old 01-05-2013, 03:10 PM
jkk's Avatar
jkk jkk is offline
Year: 1967
Region: 13(TX)
NECOA #: 21960
jkk will become famous soon enough
Garage
I like to put a little heat on a bolt / nut if possible and as it cools keep spraying it with PB Blaster and it will suck it in to the thread seems to help break it loose.
1967 - GM ZZ 383 700R4 12 BOLT 3.73 POSI . Ranchero Eater!
My motor can out run your stereo
  #10
Old 01-05-2013, 05:15 PM
Motor Mouth
Year: 1972
Model: El Camino SS
NECOA #: 11760
Default bump
Bump
  #11
Old 01-05-2013, 05:32 PM
Year: 1975
NECOA #: 13978
That Kroil brand isn't sold in stores, that I know of. It's sold direct. An aviation friend uses it all the time, & orders it direct.
AKA Pila
El Camino resto
The Malibu
  #12
Old 01-05-2013, 08:06 PM
Geoff1200's Avatar
Geoff1200 Geoff1200 is offline
Year: 1967
Region: 6 (FL)
NECOA #: 16985
Geoff1200 has a spectacular aura about
DOT3 brake fluid does wonders....used it on the body mounts of my 67 and all but 1 came out clean....the 1 was rusted in half so no chance of salvation....
  #13
Old 01-06-2013, 06:22 AM
mrblanche's Avatar
mrblanche mrblanche is offline
Year: 1986
Region: 13(TX)
NECOA #: 21555
mrblanche has a spectacular aura about
Quote:
It's also a great paint remover. A word to the wise is sufficient.
  #14
Old 01-06-2013, 07:34 AM
PFlo's Avatar
PFlo PFlo is offline
Year: 1960
Region: 12(MO,OK,KS)
NECOA #: 22514
PFlo will become famous soon enough
Garage
I have used Zepreserve for years, rust just melts off.
PFlo
my driveway:
1960 Chevy El Camino
1977 Chevy El Camino Custum
1985 Chevy C10 Silverado
2002 Buick Century(rain and snow driver)
2012 Ford Fusion SEL(daily driver)
  #15
Old 01-06-2013, 07:47 AM
Lindsay's Avatar
Lindsay Lindsay is offline
Year: 1982
Model: Conquista
Region: 14(AR,LA,MS)
NECOA #: 14482
Lindsay will become famous soon enough
I like Kroil because it works well and you can control the spray, which comes in handy when you don't need a blast of oil through the tube. My last use was on the top and bottom nuts/bolts holding the original rear shocks.
There's a 2 for offer at the bottom of this page for anyone interested:
http://www.kanolabs.com/google/
'82 Conquista 350/TH350
'91 Syclone
You may not post new threads
You may not post replies
High mileage oils - any truth? Jack_K Engine Topics 32 02-14-2011 03:51 PM
Oils thewayofdouce Performance Modifications 2 07-23-2005 05:48 PM
Synthetic Oils 72 El Camino Transmission & Drive line 16 04-03-2005 06:48 PM
