pulled apart both the v8 and v6 distributor and niether one has a reluctor or anything that looks like it. tell me more lol
| Sponsored Links | ||
Advertisement | ||
The pick up has screws holding it to the housing...the wheel with the pointed tips is the part hou need to swap to the other housing...it may have come out when you pulled the cenfer shaft....if possible you really need to put hp some pics of what your talking about...
hey yall,,,watch this... To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
They don't have reluctors, they have flux capacitors!!!!
Bruce '87 Elkie: 350CID; 700r4; B&M shifter; buckets; AC; PS; PB; PW; PL; PM; Sony Blutooth; Kenwood rear spkrs. '56 Chevy BelAir: 350CID; 5-spd Tremec; AC; PS '10 VW Jetta: 2.5L, 5-cyl; 6-spd auto; AC; PS; PB; PW; PM; PL. To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. |
its on the shaft,, the 6 or 8 pointed star..
![]() pic http://www.bing.com/images/search?q=...BC9B2D517CF8B8#
JJ 85 SS LT1 383 4L60 8.5 3.73 To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. Last edited by JJLT1; 01-13-2013 at 01:36 PM. Reason: crs |
actually the v6 had a 3 pointed star and the v8 had a 6 pointed star. but i swapped them out along with the pick up coil and now im back to no spark. so......bad pick up coil?
This new member is needing legitimate help. Please keep these comments for the b.s. section ...im sure he would appreciate it as much as i do..thanks
#8
not a easy way..
http://www.chevelles.com/techref/ftecref5.html |
#9
lol thanks. ive got the part coming to the autozone by my house in a day or so. ill let you know how it turns out. thanks for the help.
#10
woody 31 is what i get 6 times a year.....lighten-up, he had lol at the end.
#11
Blue, welcome. let us all know what you find. Dale
#12
if you put a ohm meter on both of them,,and turn the shaft you may see a difference,,
i think i read if you turn them fast enough it will make ac current???? if its open or shorted it could be bad,, i just cant remember, i'll check the book tho..
#13
that was easy,, my book says the same thing.. and it will induce a voltage if you spin it fast enough..
http://www.73-87.com/7387garage/drivetrain/pkupcoil.htm ![]() http://www.hotrodders.com/forum/hei-...ng-205999.html http://www.bing.com/search?q=testing...c=IE-SearchBox Last edited by JJLT1; 01-13-2013 at 04:41 PM. Reason: crs |
#14
Quote:
I don't know how that could work. 1 point needed for each cylinder. I don't understand how a reluctor with 6 points on it could run an 8 cylinder engine since the module fires the coil when the voltage spike goes from + to -
84 Elky with 455 Stage 2 Buick, Tremec TKO600 5 speed, 8.5 3:23 posi 98 Acura CL custom upholstered seats, Dakota Digital Instrumentation- To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. Car Domain: To view links or images in signatures your post count must be 0 or greater. You currently have 0 signatures. Another 3 to 9 years should finish it. |
#15
Quote:
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
