i have i 305 and i want to upgrade - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-16-2013, 12:15 AM
74redmonster 74redmonster is offline
Junior Member
NooB
Year: 1974
Model: El Camino Classic
Region: 18(CA)
NECOA #: 22488
74redmonster will become famous soon enough
Default i have i 305 and i want to upgrade
so i have a 1974 el camino with a swapped 1983 305 small block engine. my budget is about 6000 dollars what could i do with it to get more power out of it? the tranny is going to need to be replaced also as it is pretty burnt out. any advice would be helpful, i was thinking of getting it bored out but i dont quite know enough about that, so if you could shed some light it would be much appreciated!
Old 01-16-2013, 02:08 AM
Dimitri13's Avatar
Dimitri13 Dimitri13 is offline
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
Dimitri13 will become famous soon enough
305 is a bored out 262 with a 350 crank. Not much you can do with it. You can get a helluva lot for 6 grand, especially if you check out craigslist.
I just noticed your region, will you have to deal with SMOG?
1977 El Camino Classic - Acquired 1/3/13
Build thread:
1973 El Camino SS - Acquired 4/13/13
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
{ what could i do with it to get more power out of it?}
Tie a rope to it and use it for a boat anchor!!
Buy a 383 stroker or step it up to a big block!!
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
Old 01-16-2013, 03:43 AM
Junior Member
NooB
Year: 1974
Region: 18(CA)
NECOA #: 22488
could you tell me the best set up to go with a 383, i was thinking of getting one, but what would be a good transmission to match it with and also what else would have to be done to the car to get the full potential out of the car would i have to get a different rear end posi traction, what would be the ideal way to build this kind of a car for 6000-8000 dollars?
Old 01-16-2013, 04:37 AM
jkk's Avatar
jkk jkk is offline
Year: 1967
Region: 13(TX)
NECOA #: 21960
jkk will become famous soon enough
Garage
Buy a 383 Stroker saw a ZZ 383 I think it was cratemoters.com for 5800.00 for a long block. I'm running a ZZ 383 love it so far with the Fast Burn Heads.
1967 - GM ZZ 383 700R4 12 BOLT 3.73 POSI . Ranchero Eater!
My motor can out run your stereo
Old 01-16-2013, 05:24 AM
Magus Magus is offline
Year: 1981
Region: 9 (IN,KY,MI)
NECOA #: 12414
Magus will become famous soon enough
Depends on your over all goals for the car and how much power you want at the end. Also, you an put some of that money into other things to improve the car more than just power like drive train or chassis. The good thing about a 305 is they are plentyfull and people litterally give them away.
For instance I actually have too much power (sbc 406) and it's completly useless and I have no traction, not to mention all my torque has killed my transmission and now I need to upgrade that as well, and I still need POSI.
If you engine is healthy. You could invest in a 4 auto speed transmission with like a 2500-3000 stall converter and some nice gearing in the rear. Throw some flat top pistons in and some aluminum heads with like 58 cc combustion chamber ,185 cc intake chamber and keep the intake valve like around 1.85 inch(305 have intake valve shrouding issues). Put a nice comp XE series cam with new lifters, the XE 268 or xe 274 seems to perform well in 305's. Invest in Long tube headers and buy one of those dual exhause kits with mufflers. Get a decent intake manifold like a performer RPM and a decent carb like the 1406 edelbrock 600 cfm. Run like 3.73 or 4.10 ratio and you would have a pretty good running machine. with the smaller v-8 stall and gearing is an absolute MUST. My last 305 was a pretty spunky 305 but I ran it through a 3.08 rear and a low stall (2200). My guess is maybe a mid 15 second car at best, but I think if went to a slightly better cam/intake/ stalled it to 3k and ran a 3.73 rear I may have been able to muster a low 14 high 13 pretty easy maybe even better. A 305 can make a good 350 horse engine, they seem to hit a wall at that point and the cost to performance ratio just goes up there where it makes more financial sense to move up in displacement. They also sell a stroker kit for the 305 to stroke it to 335 cubes if you wan't a bit more.
406 sb/Dart shp 200 cc heads/ scat 5.7"rods, Eagle crank, Comp xe 268, Comp roller rckrs/Speed Pro flt tp floating Pistons/9.5:1 compression/EDL Perfromer intake/EDL 1406 carb/ LT header 2.5" Exh/Trush mflrs
Old 01-16-2013, 05:36 AM
p.ward7885's Avatar
p.ward7885 p.ward7885 is offline
Year: 1978
Region: 4 (MD,VA)
NECOA #: 12828
p.ward7885 will become famous soon enough
If you are looking for dependable,and driveable car I would go with and gm crate engine as you can get these turn key with a warranty for $3000 to $4000, and then spend a little to upgrade rear gear and have a car with decent performance and drive ability, increase in rear gear would enhance acceleration, and swap in an overdrive and you would be good to go.
Paul Ward
78 el camino
70 Buick GS
66 Toronado
  #8
Old 01-16-2013, 06:22 AM
fauxrs's Avatar
fauxrs fauxrs is offline
Year: 1966
Region: 18(CA)
NECOA #: 21184
fauxrs is a jewel in the rough
Garage
A '74 in CA you can do whatever you like. I would at the very least urge you to not consider doing anything with the 305. At a minimum a gm crate 350 should be in your sights. For 6000 and a little bit of hunting you could build yourself a 454 so you have a good many options. But cost wise a 350 mated to a 200r4 will give you years of service and enjoyment.
I've spent most of my money on beer, fast women, and fast cars. The rest I just wasted
  #9
Chris Nelson Chris Nelson is offline
Year: 1986
Region: 6 (FL)
NECOA #: 16658
Chris Nelson will become famous soon enough
Don't waste that money on that old 305,many have & now regret it.Zeg's has brand new 350's starting at $ 1499.99.That's all new metal block ,crank,rods,pistons,heads,etc.Manufactured by GM,with warrantee.You will be well ahead of the game.Many have spent 2 & 3 times that trying to freshen up a small block & never reached the HP of a 350.If I were you I would go for their 383.
  #10
Old 01-16-2013, 07:02 AM
jcote2010's Avatar
jcote2010 jcote2010 is offline
Member
Loose Nut
Year: 1982
Model: El Camino SS
Region: 6 (FL)
NECOA #: 22445
jcote2010 will become famous soon enough
Garage
Defff check out Jegs!!!! They have some good deals...with your budget you could even get a bigger engine and maybe invest in a trans!!!!
Sent from my HTC PH39100 using AutoGuide.Com Free App
1982 El Camino Super Sport (Nadine)
  #11
Old 01-16-2013, 07:24 AM
skinyfisher's Avatar
skinyfisher skinyfisher is offline
Year: 1969
Model: El Camino SS
Region: 6 (FL)
NECOA #: 3484
skinyfisher is a jewel in the rough
Garage
Don't put 5 cents into a 305 unless it is just transportation and fuel economy your looking for. With a budget of 6 to 8K you are able to do it right the first time, answer these questions to yourself, how long am I keeping the car, is it my dream car never to be sold this helps you look at things better. Having done this several times like others, if your keeping the car and love it and want power with a good trans than do some research, start with GM Performance Crate engines they have several that can and will do fine with some warranty that is real but in 4 of these engine SB and BB I have never had any problem, you will pay more but get more and match well. Than go to a real trans builder that does it with matched quality parts to the HP you need it to stand up to, Bowtie Overdrive, TCI Performance Transmissions, Phoenix, and there are several more once again they well run more on purchase but pay it all back when there is no second rebuild.
Look at nothing smaller than a 350 built to what ever you think is your driver need, if you go inot the Big Blocks that will in-tall more work and more money in most cases. Also with a 74 as a starter this work is more money than the car may be worth when your done. so like and drive what you do and get on the road.
El Chromeo is a "69" SS 396/350 HP with a stock outside, stock underside, stock inside and a splash of chrome and polish in the engine area.
  #12
Old 01-16-2013, 08:11 AM
Year: 1986
Region: 6 (FL)
NECOA #: 16658
Yeah,that's what I meant Jeg's not Zeg's,I wasn't awake yet
  #13
Old 01-16-2013, 08:47 AM
Year: 1981
NECOA #: 12414
What trans is already in the car? What rear? Is is POSI? How much power do you want? How fast do you want to go? If you wan't to run high mid 14's you could do it with some tweaks to the 305 with gears and trans mods. If you wan't bragging rights and big power then moving up in displacement is easier, but you will still need to mess with the rear gear, and obtain a transmission. You can do a lot with surpirsingly low power with the right set up.
OR heres an idea, be different. 305 is already low compression...why not boost?
If you wan't more it will bolt to a 350
http://www.summitracing.com/parts/vo...make/chevrolet
and you got enough left over for a transmission and maybe a rear gear change and fix some misc along the way, and maybe exhaust.
  #14
Old 01-16-2013, 10:31 AM
BillyJack's Avatar
BillyJack BillyJack is offline
Year: 1987
Model: Conquista
Region: 3 (DE,NJ,PA)
NECOA #: 13628
BillyJack will become famous soon enough
You're in an enviable position if you already have an established budget. Now it's just a matter of selecting components to fit within budget. I definitely agree going in the direction of a GM crate engine. You can spend anywhere from $1,500 on up, depending on how much power you want to buy. I'd start my planning with transmission and rear end, then see how much is left in the budget for motor. The stock rear end should be more than adequate for street use, so you'll just need to cost out a posi unit, including installation, as well as a gearset and bearings if you intend to change ratios. As for the transmission, depending on your needs and intended usage you need to decide if you're staying with automatic, would you go for a rebuilt 350 trans, or would you prefer an overdrive? Once those costs are resolved, then your remaining $$ can be spent in the engine compartment. You'll have to deal with all the peripherals such as ignition, intake and exhaust systems, starter, flywheel etc. Will you be re-using your old stuff or replacing them with fresh pieces? Once you get all that stuff priced out, see what you have left for the motor itself, then you can decide how much horsepower you can afford.
Bill
  #15
Old 01-16-2013, 11:08 AM
Dimitri13's Avatar
Motor Mouth
Year: 1973
Model: El Camino SS
Region: 20(HI)
NECOA #: 23291
The GM crate engines ya'll are talking about are the GM Goodwrench engines they sell on Jegs right?
Tags
1974, 305, build, engine, upgrade
You may not post new threads
You may not post replies
383 upgrade black_on_black Performance Modifications 51 09-13-2012 09:05 AM
Upgrade Fyjimo Suspension & Steering 8 09-05-2012 09:42 PM
383 upgrade... undress15 Engine Topics 5 04-19-2011 04:52 PM
cam upgrade!! 82 meeno Performance Modifications 24 01-17-2005 01:49 PM
upgrade to 454 ng1469 Engine Topics 21 11-28-2004 07:09 PM
