5th Gen Tailgate lighting - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-16-2013, 02:20 PM
samjudi's Avatar
samjudi samjudi is offline
Senior Member Supporting Member
Year: 1984
Region: 6 (FL)
NECOA #: 13745
samjudi will become famous soon enough
Default 5th Gen Tailgate lighting
Has anyone added an LED strip in the slot between the tailgate and bumper on a 5th Gen? I have tried and found the tailgate hinges get in the way. Above the hinges, and the lights are behind the tailgate, below, and the lights are behind the bumper. Over and around the hinges looks kind of raggedy.
I am using a 49" strip that does not completely fill the void, but goes beyond the hinges. Anything shorter looks like an afterthought. I wanted a strip that would light with the tail lites, brake and backup lites.
Sam
'79 Corvette
'84 T6 Elky
Converse All Stars
Old 01-16-2013, 02:37 PM
dakazman's Avatar
dakazman dakazman is offline
Member
Loose Nut
Name: David Kaczmarek
Year: 1984
Region: 6 (FL)
NECOA #: 22839
dakazman will become famous soon enough
Garage
Sam your 84 is an inspiration for me , very nice job on interior and engine . I cant believe we have two of the same vehicles and same years. 79 vette and 84 elky.
dakazman
Old 01-16-2013, 02:53 PM
84withzz4's Avatar
84withzz4 84withzz4 is offline
Year: 1984
Region: 14(AR,LA,MS)
NECOA #: 3532
84withzz4 will become famous soon enough
You mean like this?
This is two 60 inch LED strips mounted one on top of another. The 2nd strip wiring had to be spliced into the 1st, then it plugs into the trailer light harness. This picture was taken in near darkness for effect. The LED's are VERY visible in the day time.
1984 El Camino Choo Choo Custom Clone w/ ZZ4
1995 Buick Century S/W - wife's car
2006 Buick Lacrosse - wife's 2nd car
Old 01-16-2013, 03:11 PM
samjudi's Avatar
Year: 1984
Region: 6 (FL)
NECOA #: 13745
Thanks dakazman. If you get over on this side of the state, drop a P.M., and say hello.
Old 01-16-2013, 03:14 PM
samjudi's Avatar
Year: 1984
Region: 6 (FL)
NECOA #: 13745
84wzz4,
That is what I am trying for. Wanted to avoid the splicing if possible. My rear is stock. Do yours fit over the hinges?
Old 01-16-2013, 06:41 PM
84withzz4's Avatar
Year: 1984
NECOA #: 3532
I go out and take a close look tomorrow. maybe and try to get some pictures.
Old 01-16-2013, 07:58 PM
jarhead's Avatar
jarhead jarhead is online now
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead is just really nice
Hey clownman.. I had one of those strips on my 87. They do brighten the tail up and that the reason I got one. The mounting strip prevented the lights from being visible since it set the lights up under the tailgate. I turned mine 180* and wired them reverse of normal. That way the left/right blinkers worked properly. It only lasted about 1 1/2 years. It cost $65 or so from O'riellys auto parts. I took it off since 1/2 of the lights stopped working. I'm thinking about the fitment of a 3rd brake light from the Cadillac Avalanche. Looks like it has some similar curves to to the roofline on the camino just above the back window. Good luck..
1987 El Camino, aka Harper's cruck
1983 El Camino SS , aka Kodie's cruck
GRAB YOUR GUNS AND HEAD FIR THE HILLS!! THE LIBERALS ARE COMING! THE LIBTARDS ARE COMING!
Dang, I miss Ronald Reagan
more and more every day..
  #8
Old 01-17-2013, 05:42 AM
Classy Blu Elky Classy Blu Elky is offline
Year: 1980
Region: 22(CANADA (E. of MAN.))
NECOA #: 13261
Classy Blu Elky will become famous soon enough
Quote:
Hey Jarhead, you might take a look at "The Brakelighter"
At this site, http://www.jandlenterprise.com
I installed it on my 80, wired thru the rear window and side moldings easily and hooked into the brake switch on the brake pedal frame. It lights up nicely through my medium tint.
  #9
Old 01-17-2013, 06:03 AM
samjudi's Avatar
Year: 1984
Region: 6 (FL)
NECOA #: 13745
I had a similar strip on for about a year also. Same problems. Only some of the lights were visible. 84withzz4's lights look the way I wanted to go. Do not know if his modified tailgate/bumper setup made this possible.
  #10
Old 01-18-2013, 02:41 PM
84withzz4's Avatar
Year: 1984
NECOA #: 3532
Here are a couple of pictures of the strips mounted to the fiberglass roll pan.
I'll try my best to describe what's going on here. Note the tailgate hinge bolted to the bed (2 bolts). About 1 1/2 away from the bed is the edge of the roll pan, it's gapped to fit up to the hinges. Look to the right in the pic and see the sheet metal screw. That is the light strip attached to the back of the roll pan. For proper placement, it has to be attached in that manner. The light strip is "L' shaped. The screws go thru the flat part (black) for mounting, the protruding out part (white) is where the LEDS are. Note where the light strips touche the hinges.
The tailgate is in the "down" position. So, using the bumper, the light strip would have to be shimmed out to this position. I hope this helps.
  #11
Old 01-19-2013, 06:20 AM
samjudi's Avatar
Year: 1984
Region: 6 (FL)
NECOA #: 13745
I must have a different lite strip, as mine is flat(no 'L' shape). Also no gap between hinge and bumper. That is the look I am going for, however.
  #12
Old 01-19-2013, 12:44 PM
rnhart3's Avatar
rnhart3 rnhart3 is offline
Year: 1979
Region: 2 (CT,MA,ME,NH,RI,VT)
NECOA #: 17856
rnhart3 will become famous soon enough
Garage
X2 on the hi-mount brake light, Chev/GMC Yukon, Yahoe, Suburban etc....looks and works great
Jim
1979 El Camino, retired daily-driver,
current frame-off resto project
1986 Monte SS, mild 350, headers, elec cooling
fan,"A" Pillar gauges, subtle
modificatons,currently at the trans shop
for HD upgrades
1986 Monte SS T-Tops, for parts...
1985 El Camino
1986 El Camino
1991 S10 pick-up
1997 Chevrolet Tahoe 2 dr.
1981 Malibu 9C1 wagon...parts?...or drive?
"Too many parts cars to mention....."
You may not post new threads
You may not post replies
Lighting issues... ragan Electrical Systems 2 07-01-2012 04:28 PM
My Lighting Problem... theelcaminoman Electrical Systems 5 10-20-2011 08:00 PM
Lighting theillcamino Electrical Systems 17 08-19-2011 12:43 PM
lighting issues 400 Camino Electrical Systems 4 09-08-2008 01:31 AM
Lighting upgrade shane22 General BS Topics 0 08-19-2003 07:28 PM
