Headliner ? - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-17-2013, 07:45 AM
AZ78ElCamino's Avatar
AZ78ElCamino AZ78ElCamino is offline
Member
Twisted Wrench
Year: 1978
Region: 15(AZ,MN)
NECOA #: 23290
AZ78ElCamino will become famous soon enough
Default Headliner ?
Ok i have a ? for all those el camino owners out there. My headliner is falling, it is not ripped or damaged any way. The ? is can it just be re glued and if so will it last?
1978 Chevy El Camino (L98/4L60E)
1972 Chevy Monte Carlo (350/350t)
1971 Chevy Suburban (350/700r4)
Old 01-17-2013, 08:03 AM
hotrodelco's Avatar
hotrodelco hotrodelco is offline
Year: 1981
Region: 13(TX)
NECOA #: 22020
hotrodelco has a spectacular aura about
Garage
What happens is the foam backing on the material deteriorates and falls apart. The glue did not give up, the backing on the material did. So all there is to glue is dusty foam, doesn't work real well. Also don't use pins to hold the material up, the board is delicate.
I do good work, just not much of it!
Old 01-17-2013, 08:43 AM
Member
Twisted Wrench
Year: 1978
Region: 15(AZ,MN)
NECOA #: 23290
so sould i try to re glue it or is that not going to work so i should just buy new headliner
Old 01-17-2013, 09:39 AM
danktx danktx is offline
Member
Knuckle Buster
Year: 1982
Region: 13(TX)
NECOA #: 20020
danktx will become famous soon enough
If you glue it will fail immediately. The foam between the backer board and the cloth has come apart and will continue to do so. You can remove the headliner, strip the foam off and glue a new fabric to the backer board or buy a replacement. So do you have time or money?
Old 01-17-2013, 10:18 AM
OldChevysNeverDie's Avatar
OldChevysNeverDie OldChevysNeverDie is offline
Year: 1981
Region: 4 (MD,VA)
NECOA #: 11112
OldChevysNeverDie will become famous soon enough
Remove the trim around the headliner including the courtesy light and visors. Remove the headliner shell and remove the fabric and "dust" that is left. Clean the shell with a stiff brush being careful not to damage the shell. Repair any damage.
Get the good spray contact cement, sorry, the name escapes me. Coat both the shell and the fabric. Use the whole can and let each coat dry before the next one. Have a patient friend help hold the fabric over the shell and lower the fabric onto it. Once it touches, it stays so be sure of the location. Start in the middle and work your way outwards by pressing the fabric as you go to eliminate wrinkles. If you reuse the original you will have to stretch it a bit. If you are getting new stuff make sure it is at least 6" bigger on each side in case you miss the middle.
The foam backed material is much more forgiving and hides wrinkles better.
Cut new holes for the light and visors with a very sharp knife. Poke, don’t drill, the screw holes thru being careful not to pull the fabric. A soldering iron helps to keep the fabric from ripping by melting the material and acts like a grommet.
Install by reversing the procedure.
Tips:
Buy new clips for the front and rear rails.
Save all the screws, clean and polish them while you got them out.
Clean or paint the trim if needed. You already have it out.
The clips will break when you take down the rails, be gentle so you don't bend them. You may need to cut the clips or sometimes you can pry the prawl to release it from the body work. It is easier to pull it off the rail if you can see it.
Good luck.
Old Chevys never die . . . they just go faster
Headers Duels cherry bombs Make a beautiful noise
'81 305 TBI Daily Driver
'73 SS
sold to a young man, keeping the tradition alive
'73 had to sell this one too. Made the kid's day.
Old 01-17-2013, 10:46 AM
jarhead's Avatar
jarhead jarhead is offline
Year: 1987
Region: 13(TX)
NECOA #: 11248
jarhead is just really nice
OR.. you can order a NEW headliner that is made of ABS plastic and order the exact color you want. Cost is $250 or so plus new trim clips and shipping. Mine was an exact fit and it took me 30 mins start to finish to remove and replace my old brittle, nasty headliner. This abs headliner is padded and if you ever do want to recover in a different material, the backer is not broken and busted. If you plan on keeping the car, I recommend buying one. My time is more valueable than being able to say "I redid my headliner".. but thats just me. Good luck whichever way you choose.
Headliners El Camino (covered)
click to enlarge
Based on 2 customer reviews
  • Retail Price ........................................$241.95
  • OPGI Price ........................................$219.99
  • Color: Select ColorBlackBriar BrownBuckskinCamel TanCarmine/Flame RedCharcoal GrayClaretDark BlueDark GrayGarnet RedJadestoneLight BlueLight GrayRoyal BlueSaddleSage Green
  • Quantity: 123456789101112
Please select an option above to see stock status
Part ID: 99LH0Model Year: 1978-87Sold As: EACHPart Type: R El Camino (covered)
Factory-matched for fit and finish
Available covered or uncovered
Replace your old, worn-out headliner with a new one! Shaped exactly as the GM original, this premium-quality headliner is constructed of rigid ABS plastic designed to fit your El Camino, Malibu or Monte Carlo perfectly. It's finished with a foam-backed fabric identical to the factory and is available in all of GM's original colors. Requires no special tools or skills to install and comes complete with all of the necessary cut outs.
COLORS AVAILABLE: Black, briar brown, buckskin, camel tan, carmine (flame red), charcoal, claret (burgundy), dark blue, dark gray, garnet red, jadestone (green/gray), light blue, light gray, royal blue, saddle or sage green. Please specify color when ordering.
1987 El Camino, aka Harper's cruck
1983 El Camino SS , aka Kodie's cruck
GRAB YOUR GUNS AND HEAD FIR THE HILLS!! THE LIBERALS ARE COMING! THE LIBTARDS ARE COMING!
Dang, I miss Ronald Reagan
more and more every day..
Old 01-17-2013, 07:24 PM
Wayne Parrish's Avatar
Wayne Parrish Wayne Parrish is offline
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Wayne Parrish has a spectacular aura about
Why not just pull it out ,clean the old crap off the shell,go to your local auto upholstery shop and buy you some new foam backed material. You use a spray on contact adhesive like a 3-M product and you'll have it done the right way and very cheap. It takes bout 2 hours to pull,resin, reinstall.
  #8
Old 01-17-2013, 07:44 PM
DONE DEAL DONNY's Avatar
Event Master & Deputy Director, Region 13
Year: 1968
Model: El Camino SS
Region: 13(TX)
NECOA #: 12098
DONE DEAL DONNY has a brilliant future
Garage
My backing was so brittle you could blow on it and it would break!!
I guess it depends on what you have to start with!!
1968 El Camino S/S 396 " Yellow Rose of Texas"
1980 Blu Buy U
  #9
Old 01-17-2013, 07:50 PM
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Wow,thats a shame. I guess you could buy a completed shell as cheap as buying a new shell and finishing it yourself.
  #10
Old 01-18-2013, 07:59 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
Headliner material was $10 at local auto upholstery supply store. Same price for a can of Headliner Adhesive. Jo-Ann fabrics carries headliner material as well- maybe $15. Like Donny says it all depends on the condition of your shell under the existing fabric. It is brittle and fragile, but the corners can be repaired if that is all that is broken.
The same material can also be used to re-cover your visors for a matched look. You can even go crazy and install a garage door opener in the driver's visor
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
  #11
Old 01-18-2013, 08:26 AM
mrbsa mrbsa is offline
Member
Loose Nut
Year: 1987
Model: Conquista
Region: 6 (FL)
NECOA #: 20239
mrbsa will become famous soon enough
Can you tell us more about the garage door opener install. What make? Where did you get it. Do you want to start a new thread? This is the first time I have seen one installed in the visor.
Thanks, Harris
  #12
Old 01-18-2013, 08:52 AM
darbysan's Avatar
Year: 1985
Region: 17(NV)
NECOA #: 910
Harris, there's a couple of pictures in another thread. The Homelink unit was purchased off Ebay for $10. I installed it myself when I redid the headliner and visors. Easy job.
http://www.elcaminocentral.com/showthread.php?t=34674
Also some more pic's and info here, toward the bottom of the thread.
http://www.montecarloss.com/communit...424#Post795424
Any questions, just let me know
  #13
Old 01-18-2013, 08:55 AM
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Darbysan, Thanks for the info. I have one of the garage door panels in our Mercury .I need to have two new visors built for my Elcam as they were recovered in the past and poor workmanship.I think I'll run by the Pic N Pull and pick up one of the Gar.Door panels and have it installed also. Thanks for the idea and sharing it. WP
You may not post new threads
You may not post replies
headliner cslix Interior Restoration 9 07-01-2010 09:05 PM
My new headliner latts9923 Interior Restoration 3 01-16-2006 04:52 PM
My first Headliner UnclesCamino Interior Restoration 4 10-12-2005 11:38 AM
Headliner leatonla Interior Restoration 1 08-12-2005 12:40 AM
headliner El Big Joe Interior Restoration 2 03-15-2005 07:15 PM
