Starter noise - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-17-2013, 10:10 AM
86CaminoDreamKar 86CaminoDreamKar is offline
Junior Member
Member
Year: 1986
Region: 5 (NC,SC)
NECOA #: 23378
86CaminoDreamKar will become famous soon enough
Default Starter noise
My 1986 El Camino with 350 sb starter is clashing with the flex plate. I have a 153 tooth flex plate no weight. I replaced the flex plate have replaced the startor new connectors and new startor bolts. Why is it still grinding?
Sent from my SAMSUNG-SGH-I897 using AutoGuide.Com Free App
Old 01-17-2013, 10:40 AM
bonos40's Avatar
bonos40 bonos40 is offline
Year: 1980
Region: 10(IL,MN,WI)
NECOA #: 8754
bonos40 will become famous soon enough
usually ther are instructions with a new starter AND shims the idea is to be able to insert a straightened paper clip in the space between the flywheel and starter gears, thusly using the shims your starter is technically dropped down to allow clearence .....supposedly !!
Old 01-17-2013, 01:16 PM
1980SteelBeast's Avatar
1980SteelBeast 1980SteelBeast is offline
Senior Member & Belton Committee Member
Year: 1980
Region: 13(TX)
NECOA #: 16503
1980SteelBeast is of outstanding character
This sounds like what I deat with for almost a year! Are you using a stock starter?
Have you pulled the starter gear out to see if its getting an even bite on the flexplate?
Steel Beast
"I don't drink and drive,I pull over and sip!"
80 El Camino 6.3L
Old 01-17-2013, 07:18 PM
Wayne Parrish's Avatar
Wayne Parrish Wayne Parrish is offline
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Wayne Parrish has a spectacular aura about
Google how to shim the starter as this is a very necessary thing to do. WP
You may not post new threads
You may not post replies
starter 1979elcamino003 Engine Topics 3 03-01-2011 06:16 PM
starter? drifter Engine Topics 14 05-16-2010 03:33 PM
Bad noise? El Monstero Engine Topics 8 06-15-2008 01:11 AM
starter noise, shims mhamilton Engine Topics 7 03-20-2007 09:41 PM
starter mayhem Engine Topics 1 07-16-2004 07:49 PM
