Just installed my new recon. Q-J from Mt. Man - El Camino Central Forum : Chevrolet El Camino Forums
Old 01-18-2013, 06:21 PM
HKDUP87's Avatar
HKDUP87 HKDUP87 is offline
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
HKDUP87 is a glorious beacon of light
Garage
Default Just installed my new recon. Q-J from Mt. Man
Installed the replacement Q-J and it looks like I'm back. I don't want to jinx it so let's say .
I mentioned to Ted about the TPS and to make sure it was set at .48v but when I checked it was set at .70v Maybe that's factory but my Haynes book shows .48v so I reset it and at WOT I'm reading 4v and I have to look back to see but I thought it should be 4.5 at WOT . SET THE IDLE AT 800 RPM'S IN PARK AND WHEN IT'S LIGHT OUT TOMORROW I WILL PUT THE TIMING LIGHT AND VACUUM GAUGE ON AND GO FROM THERE. Sorry for the CAPS I wasn't looking and tired so
I have learned to never characterize any of my cars as fixed....they are just temporarily between malfunctions. .....Dan ( old_coot)
Old 01-18-2013, 06:40 PM
melissadunagan's Avatar
melissadunagan melissadunagan is offline
Year: 1981
Model: Conquista
Region: 13(TX)
NECOA #: 12939
melissadunagan will become famous soon enough
Don't worry about the caps,I am very hard of hearing. So you have to yell for me to hear,Hee Hee.
the ferret lady
Old 01-18-2013, 06:58 PM
matty man's Avatar
matty man matty man is offline
Deputy Director Region 8 (OH-WV)
Year: 1966
Region: 8 (OH,WV)
NECOA #: 13930
matty man will become famous soon enough
I like the fridge!! Matty man
Old 01-18-2013, 07:40 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Had to have a cold one or two. I had a 1/2 after work to swap carb's . I can't wait for the spring but if you have any rain send it down.
Old 01-19-2013, 07:59 AM
darbysan's Avatar
darbysan darbysan is offline
Year: 1985
Region: 17(NV)
NECOA #: 910
darbysan is of outstanding character
Quote:
I know you are smart enough to check this, but in case someone else is reading...
When you checked the TPS, was the carb cold? Could the choke have been on a higher idle step?
'85 SS, Wicked Ruby Red, Gm Crate 350, Vortec heads,TPI, Serp, TES headers, Choo Choo nose, Acura Leather heated buckets, 2004 Gp Console and Shifter, 8.5 GN rear with 3.73, GN 200-4r, Craftec Tonneau w/ Electric release, Power Mirrors, Electronic HVAC, ZQ8 rims, Blazer Front brake upgrade, LS1 rear brake upgrade.
Old 01-19-2013, 09:05 AM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
I'm good at.48 hot. I need to check all my vacuum line connections at the EFE, check valves etc. I'm plugged into the carb. correct but everything has been in and out I need to check before I time it. I'm not touching the carb NO MASS!!! It's idling off a little the tach is bouncing in park 800-801-799 but driving it's perfect all motor no problem . I had most of the emissions off but I put it back before the carb.
I don't have a exhaust heat valve or riser with the headers so the vacuum line from that to the coolant temp. sensor vacuum port I plugged the bottom port and I think I need something there for the EGR. VACUUM????
I HAVE THE DIAGRAM.
Old 01-20-2013, 09:54 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Got the wrinkles out and she is running good. I have the timing set a 8 BTDC , TPS at .48v and at WOT 4.33V, RPM'S in park 620 and 520 in gear with foot on break. it holds the RPM'S steady and acceleration is great. Now let's see if it holds. I'm very happy and on to the next project. Complete front end rebuild.
This should be a fun one.
  #8
Old 01-21-2013, 08:23 AM
Wayne Parrish's Avatar
Wayne Parrish Wayne Parrish is offline
Silver Contributor
Year: 1986
Model: El Camino SS
Region: 5 (NC,SC)
NECOA #: 19316
Wayne Parrish has a spectacular aura about
Been running mine from Ted EXACTLY like he set it up for about a year and a half and its just as nice now as it was when I put it on. He's the expert so I don't mess with it. WP
  #9
Old 01-21-2013, 12:46 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
Mine is running great no touching anything!!!!!!!
  #10
Old 01-21-2013, 02:10 PM
84elcoconquista's Avatar
84elcoconquista 84elcoconquista is offline
Year: 1984
Model: Conquista
Region: 12(MO,OK,KS)
NECOA #: 20278
84elcoconquista will become famous soon enough
Garage
Congrats!
Someone likes his beer.......
1984 - El Camino Conquista
" She may be a little old but that dont mean she's slow"
  #11
Old 01-21-2013, 04:51 PM
HKDUP87's Avatar
Year: 1987
Model: Conquista
Region: 18(CA)
NECOA #: 18458
Garage
Quote:
Originally Posted by 84elcoconquista View Post
Congrats!
  #12
Old 01-21-2013, 04:58 PM
RTT's Avatar
RTT RTT is offline
Year: 1984
Region: 18(CA)
NECOA #: 20475
RTT will become famous soon enough
Hey Robert,
My 84 runs excellent and I have the timing at 10* BTDC. You might try that. It might smooth out the idle.
RTT (Todd)
You may not post new threads
You may not post replies
new motor installed juggypile Performance Modifications 9 08-31-2012 07:23 AM
D-1SC Procharger installed on a 68 USAFquez Performance Modifications 10 12-10-2011 08:52 AM
Installed an new Gen 3 bed? Bebe Body Restoration 4 03-05-2010 06:58 PM
Installed a Flowmaster 40 No1TubaPlayer Engine Topics 17 08-24-2006 07:09 PM
FlowMasters installed workNprogress General BS Topics 5 05-24-2003 10:39 PM
